Any short type-ins for unattended Beebs?
Re: Any short type-ins for unattended Beebs?
Post by lurkio » Sat Apr 06, 2019 4:06 pm
The Persian rug program from the Beeb user guide:
0MODE1:D%=4:VDU19,2,RND(3)+1,0,0,0,19,3,RND(3)+4,0,0,0,29,640;512;:J%=0:FORK%=400TO280STEP-40:REPEATA%=RND(3):UNTILA%<>J%:J%=A%:GCOL3,J%:FORI%=-K%TOK%STEPD%:MOVEK%,I%:DRAW-K%,-I%:MOVEI%,-K%:DRAW-I%,K%:NEXT,:TIME=0:REPEATUNTILTIME>500:RUN
Run in JSBeeb:
:idea:
AndyF
Post by AndyF » Thu Apr 11, 2019 3:30 pm
Some quite similar ( and shameful quality :oops: ) small randomness:
patterns.ssd
(3 KiB) Downloaded 15 times
Consists of:
Blocks / Characters / Bricks / Letters / Squares / Numbers / Solid
Preview combi-pics:
:oops:
I don't think there was a great deal of point in having a 'numbers' and 'letters' and 'characters' as separate files actually, oh well. Having said that I did try in Mode7 to have random text characters and teletext graphic blocks but despite my efforts it always added a space after, even when forcing a backspace I could not get it to behave properly. I must revisit that, hence why the above are all Mode2...
Andy
AndyF
Post by AndyF » Fri Apr 12, 2019 12:16 pm
You know it might of been more sensible thinking about this (aside from just pressing BREAK and not saving the Basic!) to either of put them all into one piece of Basic where either one choice would be selected at random and then perhaps cycled every few minutes (so ti was completely unattended) or have a cheapy menu choice of which pattern/effect to use.
By the latter I don't mean a 'Menu' Basic which loaded the appropriate file, merely a choice in the single file itself. Anyway does not matter too much I guess.
Andy awaits other's new "short type-in's" in much anticipation! :D
Andy
Post by BigEd » Sat Apr 13, 2019 12:02 pm
That's great!
Post by lurkio » Tue May 14, 2019 1:10 pm
This is a bit of a long type-in (but it's a variation on an earlier theme in this thread):
REM Set up a pseudo-array of integer values 0..1278
 10 MODE7:PRINTTAB(11,10)"Preparing... ";:C%=0:B%=0:O%=0:J%=0:A%=0:DIM S% 2558:FORI%=0TO1278:S%?(2*I%)=I%MOD256:S%?(2*I%+1)=I%DIV256:NEXT:VDU23;8202;0;0;0;
REM Shuffle the values to create a random order for later
 20 FORI%=0TO1278:R%=RND(1279)-1:T%=(S%?(2*R%))+256*(S%?(2*R%+1)):S%?(2*R%)=S%?(2*I%):S%?(2*R%+1)=S%?(2*I%+1):S%?(2*I%)=T%MOD256:S%?(2*I%+1)=T%DIV256:PRINTTAB(24,10);1278-I%;"   ";:NEXT
REM "Screensaver" pattern begins
REM Define two colours and two UDG characters
 30 MODE1:VDU23;8202;0;0;0;19,3,2;0;0;0;19,2,6;0;0;0;23,128,1,2,4,8,16,32,64,128,23,129,128,64,32,16,8,4,2,1
REM Main loop
 40 REPEAT
REM Colour 3 to print pattern, colour 0 to erase
 50  C%=C%EOR1:IFC%=1COLOUR3ELSECOLOUR0
REM Fill in bottom-right corner "manually"
 60  IFC%=1ANDB%=0VDU31,39,31,127+RND(2),31,0,0,11
 70  B%=0
REM Count upwards when printing pattern
 80  IF C%=1 A%=J%:Z%=1278:P%=1
 REM Count down when erasing pattern
 90  IF C%=0 A%=1278:Z%=0:P%=-1
REM Loop to print (or erase) pattern
100  FORI%=A%TOZ%STEPP%
REM Calculate which value to pick from shuffled sequence
110   U%=(I%+O%)MOD1279
120   R%=(S%?(2*U%))+256*(S%?(2*U%+1))
REM Convert value to X,Y text-coordinates
130   Y%=R%DIV40:X%=R%MOD40
140   VDU31,X%,Y%
REM Sometimes switch colours when printing pattern
150   IFC%=1ANDRND(1280)>1100COLOUR2:VDU127+RND(2):COLOUR3ELSEVDU127+RND(2)
REM Sometimes erase part of pattern rather than entire pattern
160   IFC%=0ANDRND(1280)>1278J%=I%:I%=-1:B%=1
170  NEXT
REM If entire pattern has been erased, CLS to clear bottom-right
180  IFC%=0ANDB%=0J%=0:CLS:VDU19,3,RND(7);0;0;0;:TIME=0:REPEATUNTILTIME>100
REM When erasing, start at random point in shuffled sequence
190  IFC%=1O%=RND(1279)-1
REM Repeat indefinitely
200 UNTIL0
Run the program in JSBeeb:
The shuffle algorithm is a bit slow. Is there a quicker shuffle (or passable "fake" shuffle) I can use?
Post by lurkio » Wed May 15, 2019 11:40 pm
From the January 1984 issue of Computer Answers magazine, a program that generates the sound of what the article calls a "car engine", but it has echoes of Daredevil Dennis:
Article
 10 FORI%=1TO40
 20 SOUND&100,-15,3,2
 30 SOUND&101,-8,80,1
 40 NEXT
 50 SOUND0,-15,3,50
 60 FORI%=10TO150STEP10
 70 SOUND1,0,I%,1
 80 NEXT
 90 X%=50
100 REPEAT
110 A$=INKEY$(0)
120 IF A$="Z" THEN X%=X%-2
130 IF A$="X" THEN X%=X%+2
140 IF A$="G" THEN X%=X%-30
150 SOUND1,0,X%,1
160 SOUND0,-15,3,1
170 UNTILA$="S"
Run in JSBeeb:
:idea:
Post by BigEd » Sun Oct 20, 2019 12:16 pm
I was at TNMoC (The National Museum of Computing, on the Bletchley Park campus) yesterday and managed to type in dv8's version of Valentin Alibillo's Pi Spigot program:
