Straker Suite
pau1ie
Straker Suite
Post by pau1ie » Sun Mar 04, 2018 10:33 pm
Still on the Anita Straker directory, file STRAK2.ssd.
The menu lists (From the data lines, filename is the second):
  • Bango,BANGO
  • Chains,CHAINS
  • Change,CHANGE
  • Criss-Cross,CRISS
  • Find Me,FINDME
  • Flags,FLAGS
  • Line Up,LINEUP
  • Links,LINKS
  • Make 57,MAKE57
  • Mallory Manor,MALLORY
  • Squares,SQUARES
  • Stars,STARS
  • Tiles 1,TILES1
  • Tiles 2,TILES2
  • Tiles 3,TILES3
But the files CHANGE, MALLORY and SQUARES are not on the disc (Not in the catalogue this time). Do you think they were always missing, or is it a problem with copying the image?
I have CHANGE already, and I think SQUARES is on a later image. Which version of Mallory Manor do you think it would have been? As noted in another thread there are two versions, and I have both.
strak2.zip
(134.98 KiB) Downloaded 17 times
Re: Straker Suite
Post by flaxcottage » Mon Mar 05, 2018 7:24 am
Straker 2 is one of those amateur compilations which I archived. There is no way to know which version of Mallory Manor would have been included. It would be most likely that it would have been the earlier version.
Amateur compilations often have files missing or corrupted. :(
pau1ie
Re: Straker Suite
Post by pau1ie » Mon Mar 05, 2018 10:25 pm
OK, Thanks. I will just make a note of the facts.
