As I mentioned here I'm not keen of the 'Look' of the current MMC Menus. Here are screen shots of those Menus: OK, I'm biased and not ashamed to say so
If non MGC users would like to 'play' with the current MGC Menu (?) I've attached a zip containing two files - these will/should work on Master and Electron hardware as will as my development platform BeebEM3 [in Master Mode]):
(1) is the INDEX - Load into sideways bank #0
(2) is the MenuROM - load into sideways bank #1
From there select the ROMFS (*ROM) and then *RUN !BOOT
Note: You can use sideways pair #2 and #3 as an alternative.
I've been looking at the Indexing for the Menu system. Although different from the MGC Indexing (due to different hardware requirements) I don't see why it couldn't be adopted for the MK II using the MK I Menu. I currently don't know what the column headings are or what some of the data fields represent, but I'm sure someone will point me in the right direction.
I'm not asking anyone to do the Menu integration (but I wouldn't refuse any help, if offered), however, assistance with the Indexing would be appreciated.
Dave H
