Acornsoft Workshop inlay instructions?
pau1ie
Post by pau1ie » Sat Nov 11, 2017 11:06 pm
A UEF of this is in Flaxcottages educational archive, but without instructions. It seems impossible to play without instructions. Does anyone have the cassette inlay that they could scan/photograph/transcribe?
Hoglet may have had it at some stage?
hoglet wrote: E23 Workshop (BBC 198?, Electron 1984)
Re: Acornsoft Workshop inlay instructions?
Post by hoglet » Sun Nov 12, 2017 9:40 am
pau1ie wrote: Hoglet may have had it at some stage?
Sorry Paul, I just checked (and looked at the pictures in the thread above again), and I don't think I ever had this.
The list I quoted seems to be the full list from here.
billcarr2005
Post by billcarr2005 » Sun Nov 12, 2017 11:55 am
I'll try to get this sorted, when time permits, unless somebody posts it in the meantime...
Any specific settings i should be using when scanning?
It's a little A5-ish size booklet.
I've got the keystrip too!
And the disk image :)
Post by lurkio » Sun Nov 12, 2017 12:32 pm
billcarr2005 wrote:Any specific settings i should be using when scanning? It's a little A5-ish size booklet.
If you're scanning monochrome (black and white) text -- and if you DON'T want high-resolution archive-quality scans -- then use your scanner's "Text" setting (image bit-depth = 1). And 300 dpi. If there's too much "noise" in the scanned image, adjust the scanner's "Threshold" setting.
But if you're scanning in colour... you're on your own!
pau1ie
Post by pau1ie » Sun Nov 12, 2017 8:47 pm
billcarr2005 wrote:I'll try to get this sorted, when time permits, unless somebody posts it in the meantime...
Wow, Thanks, that would be brilliant.
I don't know. 300dpi seems reasonable. I will probably create a PDF version.
billcarr2005 wrote:I've got the keystrip too!
Yes please, I will include that too...
billcarr2005 wrote:And the disk image :)
I think the disc image I have is assembled from a tape image, so that would be handy if you have time.
billcarr2005
Post by billcarr2005 » Sun Nov 26, 2017 7:01 pm
Enjoy! :)
WORKSHOP INSTRUCTIONS.zip
WORKSHOP function key strip & booklet
(1.35 MiB) Downloaded 27 times
WORKSHOP.zip
WORKSHOP Disk image
(16.25 KiB) Downloaded 20 times
pau1ie
Post by pau1ie » Mon Nov 27, 2017 12:03 am
billcarr2005 wrote:Enjoy
Thanks! That is excellent!
