Acorn ADFS Desktop utility
rharper
Post by rharper » Mon Jun 12, 2017 7:26 pm
This is a utility for ADFS systems.
I have several machines with MMC cards but also some Electrons, Master 128's and a Compact with Floppy discs and IDE CF cards for which this is designed.
Navigation is with the cursor keys, analog joystick or switched joystick.
An analog joystick can be used directly or in switched mode - movement simulates cursor keys, useful for self-centering joysticks.
The latter also works for switched joysticks with an analog port interface.
It has context sensitive menus for files and directories.
It has an applications menu.
The drives and applications menu are set in a configuration file.
There is a top panel for menus and status, central panel for catalog listing and a bottom panel for transient information.
Ray :)
desktop.zip
(7.26 KiB) Downloaded 51 times
Raycomp
rharper
Re: Acorn ADFS Desktop utility
Post by rharper » Thu Jun 29, 2017 2:58 pm
An update that includes file RENAME.
Ray :)
desktop.zip
(6.94 KiB) Downloaded 30 times
Raycomp
mjforbes
Post by mjforbes » Sun Jul 02, 2017 10:32 pm
BeebEm seems not to like .adm files. Can't try it on my Master as I'm 700 miles away in Arcachon.
M.
"We're happy as fish, as gorgeous as geese, and wonderfully clean in the morning."
rharper
Post by rharper » Mon Jul 03, 2017 2:00 pm
Does renaming it to .adf make a difference?
Ray
Raycomp
