TurboMMC / SmartSPI, CoPro, OSWord 7F loads to wrong address
Post by sweh »
Based on some testing I did with the matchbox CoPro and TurboMMC I think I may have found an issue with OSWORD 7F routines. I did the same test with Smart SPI and got identical results. So it's possible this error has been there since the early MM code days...
Here is my test code:
   10DIM BLOCK% 100
   20D%=&2000
   30?BLOCK%=0
   40BLOCK%!1=D%
   50BLOCK%?5=3
   60BLOCK%?6=&53 : REM READ SECTOR
   70BLOCK%?7=0   : REM TRACK
   80BLOCK%?8=0   : REM SECTOR
   90BLOCK%?9=&22 : REM TWO SECTORS
  100X%=BLOCK%
  110Y%=X%/256
  120A%=127
  130CALL &FFF1
Now if I run this on a non-copro Beeb (*FX151 230 6) it works correctly. The first 2 sectors are loaded into &2000
If I turn the CoPro on (*FX151 230 1) and run it... the data loads at &130A instead. In testing with TurboMMC, and using BeebEm for comparison:
1) BeebEm no CoPro: works
2) BeebEm with 65C02 CoPro: works
3) BBC B with no CoPro and TurboMMC: works
4) BBC B with Matchbox CoPro and TurboMMC: loads at &130A
5) Master with no CoPro and TurboMMC: works
6) Master with John Kortink's internal 65C102 and TurboMMC: loads at &130A
(in fact there were two BBC B's; one issue 4, one issue 7, both the same results).
It doesn't matter what I set D% to, it always loads at 130A which makes me wonder if the OSWORD 7F routine is corrupting the address value somewhere.
I was told SmartSPI also worked with TurboMMC (it seems to!), so I tested that (tests 3 and 4)... exactly the same results. The sectors are loaded at &130A. This makes me think there might be a problem with the code going all the way back to Martin's original routines.
This normally has no impact (it seems to require OSWORD 7F and a copro to exercise it) so I'm not too surprised it hasn't been seen before. The Z80 copro uses it to try and load CPM, which is where I saw it.
Can anyone else verify this? Is my code just bad and wrong (it works on BeebEm...) or is there a bug?
Duikkie? Dunno if you're in a position to test/verify...
Re: TurboMMC / SmartSPI, CoPro, OSWord 7F loads to wrong address
Post by hoglet »
Stephen,
It would be interesting to try the same test with MMFS, which is derived from a more recent 2.xx version of DFS.
I can try that today.
Post by tricky »
Perhaps Tom could add SPI support to beebem, he has MMC, but I don't think it does it through SPI, that would make debugging easier.
Post by hoglet »
hoglet wrote: It would be interesting to try the same test with MMFS, which is derived from a more recent 2.xx version of DFS.
It seems a similar bug also exists in MMFS.
What I observe is that the tube transfer address is incorrect, and in my case seems to be defaulting to that of the last loaded program.
For example, if do the following:
LOAD "OS7FTST"
RUN
OS7FTST (your test program) gets clobbered by and you end up with a Bad Program.
However, if I do:
LOAD "OS7FTST"
*LOAD OS7FTST 2000
RUN
Then OS7FTST actually loads sectors 0 and 1 to &2000 and &2100.
I've got the ICE-T65 debugger available in BeebFPGA (on the Altera DE1) with a 65C02 Co Pro, so I should be able to single step through MMFS and see where it's going wrong.
Post by jgharston »
Is the source code available anywhere?
PDP11 BBC BASIC IV Version 0.36
Post by sweh »
jgharston wrote:Is the source code available anywhere?
viewtopic.php?f=3&t=10526&p=127672&hilit=mmfs#p127672
Post by hoglet »
Right, I've tracked down the bug in MMFS and fixed it in version 1.06:
https://github.com/hoglet67/BeebFpga/co ... 8a6f6bdb6e
With this fix, I Stephen's test program works, and I can boot CP/M from the MMC Card from two .ssd images loaded into drives 0 and 2:
*FX151 230 1
<break>
(that should take you to the Z80 * prompt)
*DIN 0 16
*DIN 2 17
*CPM
Here's the Master 128 build of MMFS 1.06:
MAMMFS_1_06.zip
(9.52 KiB) Downloaded 69 times
The bug that MMC_BEGIN2 was being called before CopyVarsB0BA, where as it needs to be called after, so that the load address is in &BC, &BD. It would be interesting to check if the same code is present in SmartSPI and TurboMMC.
Post by hoglet »
This is now fixed, at least in MMFS:
duikkie
Post by duikkie »
i will look if i can locate the error in my smart SPI rom :) , but i have only a bbc iss 4 board , no copro or anything else ( the SMART USB is hanging on the tube :shock:
i i heard from bill gate that i was telling all that SMART SPI was out of day , no update anymore :lol:
Lardo Boffin
Post by Lardo Boffin »
Hello all
I have tried to download the updated MMFSM ROM but without much success! I managed to find a file mm-fsm.rom on the link in this topic but it killed BeebEm when I tried it there and also killed my Beeb (flashing cursor and nothing else after reboot) when I loaded it into sideways RAM and then did a control-break.
At the risk if sounding like a 'numpty' where is the correct download file or could some kind person attach it to a message in this topic please? It is for a model B.
I also tried the one 'MAMMFS' just in case but that also kills it.
Many thanks
Lardo
Adventure Language on GitHub
Atom, issue 5
Elk
Post by danielj »
That's the master build - does it work on the beeb?
Post by hoglet »
Lardo Boffin wrote: At the risk if sounding like a 'numpty' where is the correct download file or could some kind person attach it to a message in this topic please? It is for a model B.
The version attached four posts up is actually the Master 128 version and won't work on the model B (hence the MA prefix to MMFS, sorry slightly obscure....)
I've just built you the Model B version:
MMFS_1_07.zip
(10.69 KiB) Downloaded 72 times
I've not tested it, because I'm a bit in the middle of something else, but give it a go.
Post by DutchAcorn »
MMFS_1_07.zip
Reading the old thread I understand there is also a model B SWR version?
I wonder if the model B version is compatible with Econet and how it behaves with solidisk sideways ram..
Lardo Boffin
MMFS_1_07.zip
Thanks Dave.
That loads into sideways RAM and shows when I do *Help. I can do *MMFS but it just says 'Card?' afterwards.
I am using a turbo mmc card reader so am probably being hopelessly naive to think this ROM would work with that hardware?
Do I need to get the guy who makes them to update his software?
Thanks, Lardo
Atom, issue 5
Elk
Post by hoglet »
SWMMFS_1_07.zip
(10.35 KiB) Downloaded 59 times
Feel free to give it a try.....
SWMMFS_1_07.zip
This uses sideways RAM (in the same slot as MMFS is loaded to) from B600-BFFF as file system workspace. So you need to avoid write-protecting this slot.
And again, I have not tested this myself.
Post by sweh »
Lardo Boffin wrote:Do I need to get the guy who makes them to update his software?
Steve Picton is aware of the bug, but he doesn't have a fix available yet.
Post by hoglet »
Lardo Boffin wrote: Thanks Dave.
Quite possibly - I don't know if Turbo MMC uses the same user port connections as MMBEEB/MMFS needs.
Edit: Is seems TurboMMC is wired differently.
Is it Steve Picton? He's usually quite helpful.
Duikkie worked it out and implemented it in his SmartSPI FS: viewtopic.php?f=2&t=9208&hilit=Smart&start=90#p112183
Post by jgharston »
There's another bug in there. It contains the TUBE 2.30 host, which calls OSBYTE &E9 in its HELP routine at SERVICE09_TUBEHelp. That should be OSBYTE &EA to read the Tube Presence flag, not the VIA interupt mask, so that the HELP message is displayed if the Tube is present.
	CMP #&0D
	BNE Label_AED3
	LDA #&E9 ; should be &EA - Tube Presence Flag
	JSR osbyte_X0YFF
and later on:
	LDX #&06
	LDA #&14
	JSR OSBYTE	; Enable ESCAPE pressed event
No, OSBYTE &14 is explode character set. OSBYTE 14 is enable events. See link.
duikkie
Post by duikkie »
to understand the problem. the problem is only if you use the OSWORD call with a=&7f, anything else is good ?
you can load/save to tube(co-pro) if you are using normal *load or load ???
the osword7f in mmc and other roms are replaced by a osword7f in file 8-cow. and this is called only in the dfs rom at &94ff.
it use bptr% (what is &B0) and so on.
so tell me more :)
your file loads wrong in memory from beeb. and the other param. are allways corect ? if sec load are 3 then you have 3 sectors in memory(in the wrong place?)
if you use other then drive 0 is it correct ?
duikkie
Post by duikkie »
more questions
if you load your program at &5000
is the 2 sectors then in 5000 and 5100 ?? or at 2000.. 2100 ?
duikkie
Post by duikkie »
oke i know where the error is and why you get a file at &130A
in the file 8-cow at osword7f the resultbyte is at fvars%=&be and the stript commandcode from &53 and #&3f=&13 stored in fdcop%=fvars%+1.
and &be and so on are the parameters from your file
&be=load,exec,length,sector.
i have to look further in the osword7f call to see if i can replace result% to &bc and fdcop% to &bd leaving &be ans on free for fvars% of the file.
maybe there will be an update :shock: , but i have to do this while bill is not looking :) , because mmc is so 2015.
USB is the new standaard :lol:
sweh wrote:Based on some testing I did with the matchbox CoPro and TurboMMC I think I may have found an issue with OSWORD 7F routines. I did the same test with Smart SPI and got identical results. So it's possible this error has been there since the early MM code days...
   10DIM BLOCK% 100
   20D%=&2000
   30?BLOCK%=0
   40BLOCK%!1=D%
   50BLOCK%?5=3
  100X%=BLOCK%
  110Y%=X%/256
  120A%=127
  130CALL &FFF1
Post by sweh »
duikkie wrote:but i have to do this while bill is not looking :)
Bill believed in legacy support for successful products; just look at how long XP was supported for. It was only after Bill moved on that XP was retired.
Bill didn't believe in supporting bad products (Microsoft Network; WIndows ME Harder; etc) but successful products (XP, SmartSPI) were supported for a long time.
duikkie
Post by duikkie »
:shock: :oops: :roll: , i changed mmc/turbo rom last year in smart spi , maybe if i live long , somewhere i can support smart spi :?:
Post by sweh »
And Bill also believed in code re-use. Windows 10 has a lot of code of XP in it. Probable that the new super-duper USB code has the same bug, so fix it there and "backport" :lol: :lol: :lol:
duikkie
Post by duikkie »
i don't no way if tube is there it loads from &be and &bf. the osword7f in 8-cow point to &b1 and b2 ??
i can change it that both load from &be and &bf , upload &b1 and &b2 , from BLOCK to &BE and &BF
but that is not the solution , something , somewhere with coprocessor it loads from &be.... (fvars%) and without from bprt% ??
still looking where the bug is
Post by tricky »
Are you sure it isn't the same bug that was in the other MMC based versions? and that the fix for them won't work?
duikkie
Post by duikkie »
i am not sure what the bug really is, because i don't have a coprocessor. when i look at the osword7f in 8-cow and debug it , it works oke.somehow if coprocessor is present it use &be and &bf to read the load adress and not &b1 and &b2 (bprt%+1.bprt%^+2) , the osword7f calculate total param. adc #7 in result that is for read/write &0a in &be, and parm &53 and #&3f=&13 in fdcop% what is in &bf.
i do not understand why with copro the osword7f get the load adress from &be..&bf what is &130A ? it is bprt+1 in the routine(=&b1).
i can fix it so that &b1 and &b2 is copyed to &be,&bf, and i think that will work
BUT why reading and writting from &be .. &bf. i am looking where the coprocessor is doing that and where ???
somewhere the memory to load/write is moved by coprocessor from &b0 to &be ???.
tricky wrote:Are you sure it isn't the same bug that was in the other MMC based versions? and that the fix for them won't work?
Post by hoglet »
Hi Duikkie,
duikkie wrote:somewhere the memory to load/write is moved by coprocessor from &b0 to &be ???.
In MMFS there appears to be some additional code that is missing from SmartSPI:
https://github.com/hoglet67/BeebFpga/bl ... 7F.asm#L32
	\ Copy buffer address to &BC-&BD;&1074-&1075
	STY byteslastsec%
	INY
	LDX #2
	JSR CopyVarsB0BA
Here's the CopyVarsB0BA code:
https://github.com/hoglet67/BeebFpga/bl ... 0.asm#L304
.CopyVarsB0BA
	JSR CopyWordB0BA
	DEX
	DEX 				;restore X to entry value
	JSR cpybyte1			;copy word (b0)+y to 1072+x
.cpybyte1
	LDA (&B0),Y
	STA MA+&1072,X
	INX
	INY
	RTS
.CopyWordB0BA
	JSR cpybyte2			;Note: to BC,X in 0.90
.cpybyte2
	LDA (&B0),Y
	STA &BA,X
	INX
	INY
	RTS
Maybe something like this is needed in SmartSPI?
But the two code bases are actually quite different (though they do share some common code fragments).
duikkie
Post by duikkie »
no problem to do that in my rom, but i want to understand why with copro , it loads from &be instead of &b1 what the rountine is telling ???
#-o
hoglet wrote:Hi Duikkie,
	STY byteslastsec%
	INY
	LDX #2
	JSR CopyVarsB0BA
.CopyVarsB0BA
	JSR CopyWordB0BA
	DEX
.cpybyte1
	LDA (&B0),Y
	STA MA+&1072,X
	INX
	INY
	RTS
.CopyWordB0BA
.cpybyte2
	LDA (&B0),Y
	STA &BA,X
	INX
	INY
	RTS
