software troubleshooter for beeb hardware SelfTestOs
marcusjambler
Re: software troubleshooter for beeb hardware SelfTestOs
Post by marcusjambler » Fri Aug 17, 2018 11:23 am
I spent a bit of time making this test OS run on one of my masters recently.
Its a bit rough... But works fine.
It utilises a standard 27c128 programmed with the standard image posted above.
Once programmed I modified the chip by bending 3 pins clear of the socket and soldering some alternate connections :
Post by tricky » Fri Aug 17, 2018 1:24 pm
Those look like mods that would still allow the chip to work in a B or am I missing something?
Post by 1024MAK » Fri Aug 17, 2018 6:24 pm
The Beeb's OS ROM socket uses both /CE (/CS) and /OE, with the different signals coming from separate sources. So no, I don't think it would work without problems.
marcusjambler
Post by marcusjambler » Fri Aug 17, 2018 7:11 pm
I've just tried it in my Nula beeb and it wasnt happy...
Continuous tone.
Post by tricky » Fri Aug 17, 2018 10:42 pm
Thanks Mark, I should have realised that those pins might be there for a reason :oops:
Post by 1024MAK » Sat Aug 18, 2018 6:43 am
Hi Tricky
For the BBC A and B machines, the following applies for the OS ROM socket.
/CE ( /CS )
CPU address lines A14 and A15 are decoded by IC21 to map the ROM to the C000 - FFFF range. This is the primary address decoding. This signal tells the ROM chip to get the data from it's memory at the address on it's address line inputs.
/OE
This signal enables the output driver in the ROM for it's data pins. In a Beeb, IC20, IC22, and IC24 perform the address decoding for the I/O device area. IC25 makes it's pin 6 output low only when the CPU is NOT addressing the I/O area. This circuitry is what causes the I/O 'hole' in the ROM area. Note that /OE active with /CE (/CS) inactive has no effect, as the ROM is disabled.
The B+ uses different circuitry, but still has seperate and different signals for /CE (/CS) and /OE.
Post by Elminster » Mon Aug 20, 2018 8:55 am
Interestingly I just ran the Tricky ROM on my Beeb with issues, I shall have put a video over in the relevant thread, not sure I understand what it is telling me. Does all the relay clicking, led flashing and playing tunes as expected. Video result, not surprisingly, are not as they are meant to be.
