Updated - BBC Micro .MMB
sweh
Re: Updated - BBC Micro .MMB
Post by sweh »
sydney wrote:I'd quite like to see the Mick Brown collection in an mmb file.
Because Mick has been pretty consistent with his menu's on each disk (I used this in https://github.com/sweharris/split_md_dsd to split the games out) it'd be quite easy to build a master menu list of game title, disk number, program to run.
All we'd need is a good menu program to display them; I don't really like the one on STH disk, but maybe that's just me :-)
Rgds
Stephen
Post by lurkio »
sweh wrote:Mick has been pretty consistent with his menu's on each disk (I used this in https://github.com/sweharris/split_md_dsd to split the games out)
Btw, you've reminded me that Lee and I recently realised that because the splitter script assumes that each game will fit onto a single .SSD, it won't handle games that have files on both sides of the DSD! The Secret Diary Of Adrian Mole is one such game. (I don't know if there are any others.)
sweh
Post by sweh »
Hmm. What of Mick's disks is this on? There may not be anything flagging this information. And does the result need to be a dsd? If so, this would stop the easy creation of an MMB file as well 'cos it'd require loading drive 0 and 2 from the separate SSDs. Lots of special casing needed for such images!
Rgds
Stephen
Post by sydney »
Could you not split the dsd and have each 'half' next to each other in the mmb and load both ssd every time removing the need to deal with a special case?
Post by lurkio »
sweh wrote:What of Mick's disks is this on?
It's here, but my update includes Master-compatibility.
sweh wrote:There may not be anything flagging this information.
No, I don't think there is.
sweh wrote:And does the result need to be a dsd?
The game's too big to fit onto a single .SSD.
sweh wrote:If so, this would stop the easy creation of an MMB file as well 'cos it'd require loading drive 0 and 2 from the separate SSDs. Lots of special casing needed for such images!
Yep, tricky!
leenew
Post by leenew »
I think Adrian Mole is the only game in the 112 discs that spans both sides of a disc. In this case it's simply because it's too big, but I don't think any other game has files on both sides of the DSD to keep to the 31 file limit, or any other reason, so I *think* the problem is just this one game.
Lee.
sweh
Post by sweh »
sydney wrote:Could you not split the dsd and have each 'half' next to each other in the mmb and load both ssd every time removing the need to deal with a special case?
Yeah for the MMB file I had been thinking something like:
Title,MMB_number,FILENAME
Then the menu could simple *DIN 0 number and CHAIN "FILENAME". Each side of the disk would be it's own MMB_number.
Instead we may need
Title,MMB_number,side,FILENAME
So now we do *DIN 0 number and *DIN 2 number+1 and *DRIVE side and finally CHAIN "FILENAME". Now each DSD image gets a number (incremented in 2's) and that's the base number.
This should work for the MMB, but doesn't help with the split problem.
Rgds
Stephen
sweh
Post by sweh »
Is there a "zip of all zips" so I don't have to downloaded 100+ files? Then I can focus on the MMB builder side :-)
Rgds
Stephen
sweh
Post by sweh »
So I made a start with just the first 5 ZIP files. So far it builds the MMB and then throws DATA lines to the screen
% ./build_mb_mmb.pl
Processing SRC/Disc001.dsd
Processing SRC/Disc002.dsd
Processing SRC/Disc003.dsd
Processing SRC/Disc004.dsd
Processing SRC/Disc005.dsd
DATA "Cylon Attack (A&F)<87>(STD)",10,0,CAINTRO
DATA "Dogfight<87>(2P)",12,0,DGINTRO
DATA "Pinball Arcade<87>(STT)",14,0,PINLOAD
DATA "Star Soccer (AKA Five-A-Side)<87>(2P)",12,0,SOCCA
DATA "Twin Kingdom Valley<87>(STT)",18,0,TWIN
DATA 3D Bomb Alley,16,2,BOMB
DATA Wallaby,16,0,WALLABY
DATA Winged Warlords,18,0,WINGED
DATA Zalaga,14,0,ZALAG-L
DATA Zany Kong,10,2,ZANY
% beeb dcat
 10: Disc001a
 11: Disc001b
 12: Disc002a
 13: Disc002b
 14: Disc003a
 15: Disc003b
 16: Disc004a
 17: Disc004b
 18: Disc005a
 19: Disc005b
So we can see that each disk has been split into its two halves and the DATA lines report the base image, the size and the game to run. The <87> is where there's a mode7 character in the data in Mick's original :-)
One gotcha I can see coming would be two games have the same name, across two different disks. I've written a trap for that, but we need to decide how to handle this. At the moment I just add an _ to make the second one unique.
Rgds
Stephen
sweh
Post by sweh »
sweh wrote:One gotcha I can see coming would be two games have the same name, across two different disks. I've written a trap for that, but we need to decide how to handle this. At the moment I just add an _ to make the second one unique.
Fewer collisions than I expected, but a few!
Sea Wolf (Disc051) already exists on Disc018
Duck! (Disc058) already exists on Disc026
Reversi (Disc082) already exists on Disc076
Darts (Disc087) already exists on Disc057
Adventure (Disc095) already exists on Disc092
Robin Of Sherwood (Disc100) already exists on Disc055
Battleships (Disc113) already exists on Disc082
Lunar Run (Disc114) already exists on Disc113
Fruity (Disc114) already exists on Disc107
Napoleon (Disc115) already exists on Disc114
Rgds
Stephen
duikkie
Post by duikkie »
emperor on *din156 needs page=&1100
jumbo on *156 needs allso page=&1100
inu works on page=&1900
problems solved ?
Higgy wrote:Hi.
I don't know how to correct individual games on a STH disk, or make compilations. My BBC knowledge is from about 1992 ;)
For example on:
GAMES DISC M4_r1
LORD OF THE RINGS (Melbourne House)
EMPEROR (Molimerx)
JUMBO (Molimerx)
INU (MRJ)
If Emperor did not work, I would just re-link the Menu M4_r1 reference to another slot on the .MMB which contained a working disk image.
Higgy
Post by Higgy »
Hi all,
Long time I know. Just to say I have been told Uridium does not work so I can going to re-link that to a working version which was shown on Stardot.
I just have to remember how I edited the MENU. I thought I wrote a guide that I could understand, somewhere...
Regarding this:
I don't know how to add this command before a game boots. Can it be added/edited into the !Boot file? Does a !BOOT file contain a startup-sequence?
I am not sure if the MENU allows additonal commands before the *EXEC !BOOT etc
Again my BBC knowledge is limited, but as I understand to load for example emperor WITHOUT THE MENU, you would:
*DIN 156
page=&1100
*EXEC !BOOT (or whatever CHAIN "emperor")
Post by tricky »
My memory is a little hazy on that menu system.
!BOOT is the automatically EXECuted file when the disc is "booted", but if there is room, you could add any file and point the menu at it.
If it is *EXECed you could prepend your stuff, or if it is CHAINed, you could add a check at the beginning of the program, setting PAGE and CHAINing again if necessary.
If it is *RUN and still needs these changes, it is a little more work as there may not be room in the CATalogue to add another file.
Higgy
Post by Higgy »
Hi all.
After some encouragement and finally being able to understand my old notes the old MMB has been updated to v1.2
Bitshifters and recent Retro Software releases features heavily along with some BBC Master Content.
I've just PM'd an Admin, so hopefully the updated file will get the go ahead, and a link + new games/demos shown.
Higgy
Post by Higgy »
Here we are:
http://www.stardot.org.uk/files/mmb/hig ... b-v1.2.zip
Additions:
Added: Astroblasters from Retro Sofware - Disc 283
Added: Centipede from Retro Sofware - Disc 284
Added: Circus from Retro Sofware - Disc 285
Added: Frogger from Retro Sofware - Disc 286
Added: Carnival from Retro Sofware - Disc 287
Added: Phoenix from Retro Sofware - Disc 288
Added: Ripcord from Retro Sofware - Disc 289
Added: Scramble from Retro Sofware - Disc 290
Added: SpaceInvaders from Retro Sofware - Disc 291
Added: Sprint1 from Retro Sofware - Disc 292
Added: BBC Tetris from Charles Reilly - Disc 302
Added: Evil Influences from Bitshifters/Desire - Disc 304 (BBC Master)
Added: Fletcher's Castle from Fernleaf Educational Software - Disc 303
Added: Stunt Car Racer from Bitshifters - Disc 305 (BBC Master)
Added: Prince of Persia from Bitshifters - Disc 306 (BBC Master)
Added: Teletextr from Bitshifters - Disc 314 (BBC Master)
Added: Beep Step from Bitshifters - Disc 315
Added: Twisted Brain from Bitshifters - Disc 316 (BBC Master)
Added: Wave Runner from Bitshifters - Disc 317 (BBC Master)
Enjoy
DamoJay
Post by DamoJay »
Thanks for this, brilliant, really appreciate it. Just wondering , does this Image have Match Day on by Ocean. Going through all the old games since getting the Acorn a World In Pixel books for Xmas !!
Post by tricky »
Nice, but I didn't think that Prince of Persia worked from MMC.
tga
Post by tga »
Thanks Higgy for that Archive 1.2,
clearly the best I've found for now
and the very first that runs CastlQuest on my BBC-B+Turbo MMC
I've found that the graphical menu in https://jubberbbcmicro.webnode.com/ was interresting too in that it is capable if running directly certain games that are in compilations (eg. E-Type, Hi-Ar Kung fu....)
And also, you can remember what type of game it is with the icon.
It is an interesting selection (many "cheap games" have been removed, But it misses somme important ones : eg. Repton1 et 2 !!!
I Tested your Archive today.
I Write here the game that don't work (in the selection I made) in case someone want to try to fix them.
But Of course, I am more than happy with all this, as most of the "must have" games work very well
So thanks again for letting me re-discover the games of my childhood !
So, games NOK on my BBC-B32+Turbo MMC :
Ailift
Cholo (too bad that one does not work : well it works but as soon as you get out the first room, it looks on the disk and it crashes...)
Clogger
Dunjunz
Elixir
FelixInTheFactory
HoledOut (Starts ok but when calculating the landscape, the game crashes)
MouseTrap
PipeLine
Qwak
SpyCat
Thomas.
tga
Post by tga »
... Just discovered that Elite does not work either
I get that "Bad command" message when getting in or getting out of the station
someone got Elite runing on a BBC B with Turbo MMC ?
do I have to install another version of Elite ?
where is the best place to download the right version ?
thanks for any advice.
Thomas
