Screen Modes 0-7 Demo
The Lavian
Post by The Lavian » Tue Dec 03, 2019 11:02 am
Hi All,
Some time ago, I wrote the following quick demo for a YouTube channel as the channel owner liked to demonstrate character sets on each of his machines, yet I saw he hadn't done so for his Beeb, possibly due to the many screen modes. I thought you guys might find the demo interesting (and perhaps useful) as well.
It starts in mode 0 and displays as many of the visible characters as possible, then waits for a keypress before moving on to the next mode and doing the same, all the way up to (and including) mode 7.
As can be seen from the code, the screen mode number is assigned to an incremental variable within the main program loop. This loop is defined in lines 40-100 (read REMark). There are two FOR/NEXT loops: "M" to set each screen mode, and "C" to display each character value.
The main grunt work is done in line 110 which first prints the character code, an equals sign then the corresponding character. These values are then incremented for the next character to be shown and are defined by the "C" loop as mentioned above.
10 FOR M=0 TO 7
20 MODE M
30 PRINT "Screen mode "TAB(0,-1);(M):PRINT
40 FOR C=33 TO 255
50 REM *****************************
60 REM Following line prevents the
70 REM output of non-visible control
80 REM codes in modes 0 to 6
90 REM *****************************
100 IF M<>7 FOR C=33 TO 128
110 PRINT TAB(0,-1);(C)"=";CHR$(C);" ";
120 NEXT C
130 IF M=7 GOTO 170
140 PRINT:PRINT:PRINT "Press any key . . ."
150 KEY% = GET
160 NEXT M
170 IF M<>7 MODE 7
180 PRINT:PRINT:PRINT "All modes have now been displayed."
190 END
The Lavian
Re: Screen Modes 0-7 Demo
Post by tricky » Tue Dec 03, 2019 1:20 pm
It might be nice to add the unofficial MODE 8.
Post by jgharston » Tue Dec 03, 2019 8:24 pm
I did this to demo the standard screen MODEs, software extended screen MODEs and hardware extended screen MODEs:
https://www.youtube.com/watch?v=1ZcvE2WL_bk
The Lavian
Post by The Lavian » Wed Dec 04, 2019 8:46 am
Interesting: I can't say I'm familiar with that - do tell!
The Lavian
Post by The Lavian » Wed Dec 04, 2019 8:51 am
Looks fantastic - unfortunately, I don't have access to actual hardware, so I doubt I'd be able to use a nuLA ROM. :(
Post by tricky » Wed Dec 04, 2019 6:11 pm
B-em (and maybe beebem now) has some nULA support, maybe the extra modes, but maybe not the scrolling.
The Lavian
Post by The Lavian » Mon Dec 09, 2019 12:14 am
Thanks for that - I'll check it out! :)
