Torch MCP Versions
Torch MCP Versions
Post by Pernod » Thu Sep 19, 2019 9:59 pm
There are various versions of the Torch MCP ROM, each followed by a 2 or 3 character code. I'm trying to document the variants and to determine what the code means. Some of this is already know from http://mdfs.net/System/ROMs/Torch/TORCH.TXT
Known MCP versions:
MCP 0.41 (CBL)
MCP 1.01 (AB) - Unicorn banner.
MCP 1.01 (AI) - not yet dumped, see http://www.computinghistory.org.uk/user ... 104670.jpg
MCP 1.01 (CI) - Torch Model 301
MCP 1.20 (CBL)
MCP 1.21 (ABL)
MCP 1.21 (ABW)
MCP 1.22 (ABW)
MCP 1.22 (ABM)
MCP 1.22 (CIL) - Torch Model 735
Code abc where:
a = Machine type
b = Keyboard
c = FDC
Machine type:
A = BBC Micro
C = Torch C-Series (or later)
Keyboard:
B = BBC B
I = Torch, the CIL variant has completely different keyboard when emulated.
FDC:
L = BBC B 8271 (Legacy?)
W = BBC B/B+ 1770 (WD)
M = BBC Master (Master)
The ABc variants were likely shipped with the Z80 Communicator board for the BBC range.
Note that the codes AB and AI don't seem to have a FDC code. Maybe they pre-date the B/B+ 1770 and so wasn't required.
Anyone have anything to add to this?
Re: Torch MCP Versions
Post by jgharston » Fri Sep 20, 2019 11:55 am
Keyboard:
B = BBC B
Interesting, all the ROMs I have are xBx versions that came from Torch machines based on a BBC+8271 with this keyboard:
                                                            Torch keyboard layout
        copy  left  right down   up   left  copy  right
|     |     |     |     |   |     |     |     |     |     |     |     |     |     |     |lower|upper|move |move |move |   | del | del | del |
| f0  | f1  | f2  | f3  |   | f4  | f5  | f6  | f7  | f8  | f9  | f10 |     |     |     |     |     | <-- | past| --> |   | <-- | line| --> |
|  para  |  file  |redo |   | esc |  1  |  2  |  3  |  4  |  5  |  6  |  7  |  8  |  9  |  0  |  [  |  ]  |  |  |  ^  |   |  7  |  8  |  9  |
|        |        |under|   |        |  Q  |  W  |  E  |  R  |  T  |  Y  |  U  |  I  |  O  |  P  |  {  |  }  |        |   |     |     |     |
| window | screen | line|   |tabulate|  q  |  w  |  e  |  r  |  t  |  y  |  u  |  i  |  o  |  p  |  (  |  )  |  line  |   |  4  |  5  |  6  |
|        |        |     |   |          |  A  |  S  |  D  |  F  |  G  |  H  |  J  |  K  |  L  |  :  |  "  |            |   |     |     |     |
|  word  |  line  |undo |   | capitals |  a  |  s  |  d  |  f  |  g  |  h  |  j  |  k  |  l  |  ;  |  '  |   return   |   |  1  |  2  |  3  |
|     |     |     |     |       |         |  Z  |  X  |  C  |  V  |  B  |  N  |  M  |  ?  |  !  |  +  |         |         |  £  |     |  $  |
|insrt|begin| end |ctrl |       |  shift  |  z  |  x  |  c  |  v  |  b  |  n  |  m  |  ,  |  .  |  -  |  shift  |         |  _  |  0  |  .  |
                                             |                                               | exact space |
Editing keys:
&A0 exact space   &A1 line   &A2 undo     &A3 window   &A4 screen      &A5 para     &A6 file       &A7 redo
&A9 begin         &AA end    &AB insert   &AC word     &5F underline   &08 <--del   &7F del line   &07 del-->
Wot? Shift-dot for ! Shift-1 gives * ?!?!?!?
(Edited with corrected keyboard layout)
Post by Pernod » Fri Sep 20, 2019 12:12 pm
The whole matrix seems very different, not even normal characters match so not able to type anything until I remap everything.
Can you add anything about where each version was found, ie. from a specific Torch machine or BBC with Z80 board?
It'll be interesting to see what we find in the Torch Model 301 tomorrow.
Post by jgharston » Fri Sep 20, 2019 9:17 pm
The matrix is here, and it is well different. I can't see why they changed the matrix, go ahead and extra keys in the spare columns yes, but why shuffle everything around? It's not even as though they made an effort to simplify decoding like with the Atom keyboard where the keycode is the raw ASCII code.
Hmm. That schmatic I've linked to is labelled with "normal" keycodes, 1! 2" ,< .> etc. I'll have to get an actual keyboard out of the cupboard and check with reality!
Post by Pernod » Mon Sep 30, 2019 2:07 pm
I've implemented the keyboard according to your schematic, and the SHIFT characters match the schematic rather than the actual keyboard, which is odd :?
There are lots of keys that I haven't mapped, specifically those to the left (para, file, redo, window, etc.), though expect these to be shortcuts for CTRL codes. Similarly for the top row after the function keys. There's also no BREAK key!
The schematic has 3 keys I'm unsure about above Shift, Ctrl, Alt labelled D3, D2, D1. I've mapped D3 as Tab but not sure what the other are?
Post by jgharston » Wed Oct 02, 2019 4:49 pm
Yeah, though there's a spare wire in the curlycord, so I used that for the break line and snaffled one of the keys
I'm away from home at the mo, I'll dig a keyboard out over the weekend and map out reality.
Post by jgharston » Fri Oct 04, 2019 12:29 am
Those aren't keys, they are diodes that seperate the modifier keys from the keypress keys. The modifier keys on row zero do not generate keypress interupts, the keypress keys generate interupts - see the multi-NAND at the right. The diodes disconnect the modifier keys from the keypress keys to prevent them ghosting the keypress keys. If you look at the BBC keyboard schematic you can see them on every column as columns 2 to 9 are the keyboard configuration links which are functionally modifier "keys".
I've buzzed out a Torch 300 keyboard - the one used with Torch systems that use a BBC motherboard - and worked out the schematic: http://mdfs.net/Info/Comp/Torch/torchbbcbd.gif
The previous schematic appears to be the keyboard for the Torch TX.
Post by Pernod » Fri Oct 04, 2019 2:30 pm
Yep, realised that after I posted.
Excellent =D> There's now too many keys to conveniently map to a PC keyboard, but at least I can document them and let the user map any as required.
I'm still to find a version of MCP that produces those shifted characters. The Model 301 from CfCH with MCP 1.01 (CI) doesn't produce the shifted characters shown on the keyboard.
Post by jgharston » Fri Oct 04, 2019 9:16 pm
I've worked out that MCP041cbl is the host ROM for the Torch 300 series: the Torch behemoth and the Torch "slice" box, that use a BBC motherboard and the weird Torch keyboard. MCP120cbl is the host ROM to use when using the BBC's own keyboard.
From going through the disassembly I've corrected the keyboard schematic, the keys I had labelled "blue 1" to "blue 4" are actually f0-f3, and the rest of the blue keys are f4-f10 and the cursor keys with Torch-specific labelling. This brings torrents of memories flooding back, fighting to work out WTF each of the unlabelled blue keys did, and where on earth the cursor keys were. I've also worked out the keypress codes for the edit control pad as well, they are mostly &Ax characters. I thought that the keypad numbers would have special keypress codes, but they're just duplicates of the main numbers. And a surprising memory that flooded back: the key that looks like "£" (ie underline and pound) is actually minus and pound! Underline is, would you beleive it, the key labelled "underline" !
I've also gathered together my unprocessed scans (reprocessed a bit to squash them down a bit) at http://mdfs.net/Info/Comp/Torch/Source/ I've got a few more sheets that I haven't scanned yet, mostly just component lists.
Post by Pernod » Fri Oct 04, 2019 9:36 pm
Thanks for all the info, and schematics. Should keep me quiet for awhile!
Multiwizard
Post by Multiwizard » Tue Apr 28, 2020 7:28 am
Known MCP versions:
MCP 0.41 (CBL)
MCP 1.20 (CBL)
MCP 1.21 (ABL)
MCP 1.21 (ABW)
MCP 1.22 (ABW)
MCP 1.22 (ABM)
I don't know, I might... :?
I installed a Torch board a few years ago in one of my Beebs which was:
MCP 0.41 (0A)
Greetings, Wim... :-)
Post by Pernod » Tue Apr 28, 2020 10:15 am
MCP 0.41 (0A)
The 0A is not part of the version. Your 0.41 probably matches what we already have, maybe with dumping though to confirm. It doesn't have the CBL suffix as it predates the different hardware configurations.
Thanks for checking.
Multiwizard
Post by Multiwizard » Wed Apr 29, 2020 10:55 am
MCP 0.41 (0A)
What type of DIP is the Torch rom I do have a prommer otherwise I would be able to read out this rom.
I also found a old pic of it does Torch CCCP (V0.94) say anything?
Post by Pernod » Wed Apr 29, 2020 11:06 am
The earlier Torch ROMs were 8K, so 2764.
CCCP refers to the ROM on the Z80 board, and CCCP 0.94 is the partner to MCP 0.41. What you have will very likely match those at http://mdfs.net/System/ROMs/Torch/
Multiwizard
Post by Multiwizard » Wed Apr 29, 2020 11:45 am
Ok done...
TER: Torch Eurocard Rom
TBR: Torch Beeb Rom
TER.rar
(6.88 KiB) Downloaded 5 times
TBR.rar
(11.48 KiB) Downloaded 6 times
Post by Pernod » Wed Apr 29, 2020 11:56 am
Ok done...
TBR: Torch Beeb Rom
Both bad dumps, the byte ordering is switched.
Multiwizard
Post by Multiwizard » Wed Apr 29, 2020 12:04 pm
Ok done...
TBR: Torch Beeb Rom
a pity... :-(
