How do you say CONT in BBC BASIC?
Commie_User
Post by Commie_User » Thu Oct 11, 2018 4:20 pm
On the CBM, you hit RUN STOP to break into a program and then type CONT to restart where you broke off.
cmorley
Re: How do you say CONT in BBC BASIC?
Post by cmorley » Thu Oct 11, 2018 5:36 pm
I don't think that is possible in BBC BASIC. I think it whacks the state (FOR stack etc) if you STOP or END. I'd be fascinated to know if there is a work around (or my memory is false!). Variables remain intact.
AndyF
Post by AndyF » Thu Oct 11, 2018 5:38 pm
ESCAPE key if its not been otherwise disabled is about the equivalent for Basic. At least as far as my very vague understanding of the CBM workings.
Hopefully the output "Escape at line xyz" assuming its shown will be helpful in restarting it via a GOTO, although I do see what you mean as other dialects have a CONTINUE command to (usually but not always!) carry on, ZX Basic etc. The only issue is that I see if said 'Escape line' contains multiple commands separated via a colon, there's no easy way to tell whereabouts it was in said line.
If it does not say anything try REPORT , if this shows 'Escape' then type P.ERL to get the line number it was stopped at.
Will be interested to read others replies on this as I'd never really thought about it that much until you mentioned it.
Andy
Post by jgharston » Thu Oct 11, 2018 6:08 pm
If you have carefully written your program so that every line is solely a single statement, and every line increments by 10, then then GOTO ERL+10, bearing in mind that all structures (FOR/NEXT, REPEAT/UNTIL, GOSUB/RETURN, PROC/ENDPROC, FN/=) will have been abandoned.
If you are finding youself trying to write your error handler to jump back into the erroring code, than you are at the point where you need to back up and re-examine your requirements and assumptions and rewrite the code.
Post by lurkio » Thu Oct 11, 2018 7:02 pm
Warning! Extreme GOTO-usage ahead:
lurkio wrote:
Sat Oct 08, 2016 5:21 pm
... If you load the game as usual and wait for the data values to be read in, you can then save off all the memory between PAGE (&E00) and VARTOP (&7A36 in this case): this area of RAM stores all the values of the variables that the running program has assigned so far. You also have to save off the variable-pointers in Page 4 (&400 - &4FF).
Then, for the next time you want to play the game, you create a loader that reloads all the saved RAM, relocates the main-prog-plus-variable-storage down to &E00, sets up the BASIC pseudo-variables so as to "fool" BASIC into thinking it's already part-way through running the main program, and then does a GOTO to the jumping-in point in the program, bypassing the file-input routine. (It was actually much trickier to engineer all this than I'm making it sound. Believe me, this is the TL;DR version of the story.) ...
