trying to track down a one-line game, possibly called "One Line"
scruss
Post by scruss » Sun Jul 01, 2018 5:06 pm
Hi - I've asked this a couple of other places without success. From the posts I see here, I probably should've asked here first.
Circa 1985 in our school BBC Micro lab, we wasted much time playing a tiny type-in game that looked a bit like this:
One Line, as ported to the Amstrad CPC
The playfield was filled with a random arrangement of asterisks, and the player controlled a continuously-growing diagonal line that could be switch from falling down to going up by pressing a key. The game played similarly to later games like SFCave (Palm) and Flappy Bird, except the screen didn't scroll. There were ports to other systems, such as one to the Dragon 32 (written by Alan Cook) and another to the Amstrad CPC (written by me, published in Amstrad Computer User in 1988).
I'm trying to find the original. Here's all I know:
  • It was written in BBC BASIC
  • It was most likely called "One Line", but I have a faint memory of it perhaps being called "Whirly"
  • It was one — quite long — line of BASIC
  • It was most likely published in one of BEEBUG, The Micro User, Acorn User, etc
If it helps jog your memory, here's a version running on an emulated Amstrad CPC: http://scruss.com/cpc/6128s.html?stardo ... 22stardoj2
Any suggestions gratefully received.
VectorEyes
Re: trying to track down a one-line game, possibly called "One Line"
Post by VectorEyes » Sun Jul 01, 2018 5:25 pm
Talk about a blast from the past! I remember playing this in our school computer lab as well!
I don't think it was a one-liner though. Or if it was, somebody had later split it into multiple lines because I'm sure it was easy to find the BASIC line that defined the angle of the line (default 45°) and if you set it to zero the line would never hit an asterisk, and just go on forever.
No idea where the source might be unfortunately. I wish I'd kept all my discs from school!
leenew
Post by leenew » Sun Jul 01, 2018 6:45 pm
Hi
I can't check at the moment, but could it be one of these?
http://bbcmicro.co.uk/game.php?id=2718
Lee.
scruss
Post by scruss » Sun Jul 01, 2018 6:55 pm
Sadly, it's not. I think I've checked all of the typeins in that archive. Thanks for digging that one out, though.
It was one of those "you're not supposed to play this until you've finished the lesson" games. That didn't exactly always happen.
Post by lurkio » Mon Jul 02, 2018 5:16 pm
I have no memory of this game, but for a lark I tried converting your CPC listing to BBC BASIC (press Space to control the line):
 70 q=5
180 xm=4:ym=4:CLS:P.'"Press a key";:*FX15
181 IFGET IF RND(-TIME)
190 MODE 1
195 GCOL0,1:VDU19,1,7;0;
200 DRAW 1279,0
210 DRAW 1279,435
220 MOVE 1279,590
230 DRAW 1279,1023
240 DRAW 0,1023
250 DRAW 0,0
260 DRAW 0,ym
270 DRAW 1279-xm,ym
280 DRAW 1279-xm,435
290 MOVE 1279-xm,590
300 DRAW 1279-xm,1023-ym
310 DRAW xm,1023-ym
320 DRAW xm,ym
380 VDU 5
390 FOR s=1 TO q
400 MOVE 101+RND(1139),51+RND(921)
410 PRINT"*";
420 NEXT
430 VDU 4
440 N%=4:X%=0:Y%=512:MOVE X%,Y%
450 dy=N%
470 Y%=Y%+dy:X%=X%+N%:PLOT 5,X%,Y%
480 IF INKEY(-99) dy=N% ELSE dy=-N%
490 t=POINT(X%+N%,Y%+dy)
500 IF t=1 GOTO 550
510 IF t=-1 GOTO 620
520 GOTO 470
550 PRINTTAB(0,0)"GOOFED on Screen ";STR$(q/5);" !":VDU7:END
620 PRINTTAB(0,0)"YES!":TIME=0:REPEATUNTILTIME>100
650 *FX15
660 IFGET
670 q=q+5
680 GOTO 190
My version isn't as quick and frantic as yours, though, which may or may not be a good thing -- depending on the state of your reflexes.
scruss
Post by scruss » Mon Jul 02, 2018 8:10 pm
Thanks, Lurkio! Good times!
sbadger
Post by sbadger » Wed Jul 04, 2018 6:51 pm
Ive definitely got this somewhere... I archived all my beeb discs a few years ago so should have it. I'll have a look
When I saw 'flappy bird' a few years back it made me think RipOff😜!!
sbadger
Post by sbadger » Wed Jul 04, 2018 7:05 pm
I think i've found it...but , it doesn't work in beebem?, maybe my archiving missed something.
EDIT: nope, that wasn't it
Post by lurkio » Wed Jul 04, 2018 7:58 pm
   10MODE1:VDU23,1,0;0;0;0;:VDU19,0,2;0;:VDU19,1,0;0;:VDU19,2,1;0;
   20PROCF(1)
   30DEFPROCF(A%):FORL%=0TO38STEP4:FORM%=0TOL%/2:X%=L%:Y%=256-(M%*8):CALLS%:X%=M%*2:Y%=256-(L%*4):CALLS%:X%=76-L%:Y%=256-(M%*8):CALLS%:X%=76-(M%*2):Y%=256-(L%*4):CALLS%:X%=L%:Y%=M%*8:CALLS%:X%=M%*2:Y%=L%*4:CALLS%:X%=76-L%:Y%=M%*8:CALLS%:X%=76-(M%*2):Y%=L%*4:CALLS%:NEXT,:ENDPROC
The variable S% isn't assigned any value. So the "CALL S%" isn't going to do anything. Is there another program on the disc that initialises S% and/or includes some assembler?
The fact that there's a CALL suggests that this isn't really a one-liner because it relies on some machine code that isn't part of the main program.
sbadger
Post by sbadger » Wed Jul 04, 2018 8:03 pm
Scratch that goose chase, that must have just been something else. I think I've found the proper one ...
1L=0:REP.L=L+3:MO.4:DR.1279,0:DR.1279,452:MOVE1279,572:DR.1279,1023:DR.0,1023:F.I=1TOL:V.31,RND(32)+5,RND(31),42,30:N.:P.(L-3)/3:X=0:Y=512:REP.PL.69,X,Y:X=X+4:Y=Y-(INKEY-74+.5)*8:U.PO.X,Y)=1ORX=1280:U.X<1280:V.7:REP.U.INKEY-99:RUN
stew
sbadger
Post by sbadger » Wed Jul 04, 2018 8:07 pm
I should have said , that is from Beebug Vol3, Issue 7, Page 9
Hope it's the one you were after?
Post by lurkio » Wed Jul 04, 2018 8:10 pm
Yes, that looks like the one!
Here's the corrected code:
scruss
Re: trying to track down a one-line game, possibly called "One Line" [RESOLVED]
Post by scruss » Thu Jul 05, 2018 1:45 am
Yes!
thankyouthankyouthankyou!
I don't think I've played that since 1986!
So it's called Asterisk Tracker. Not Whirly. Not One Line.
blown away … thank you so much!
You can play it too now: https://bbc.godbolt.org/?autorun&loadBa ... 76ee/ASTER
Post by lurkio » Thu Jul 05, 2018 1:07 pm
Here are all three games on that page:
They're also online at bbcmicro.co.uk:
Commie_User
Post by Commie_User » Fri Jul 06, 2018 4:58 pm
These tiny games are amazing.
This isn't the version I'm thinking of but there was also 1K Chess for the ZX81 and a 4 line chess game for the Amstrad (I think): https://arstechnica.com/gaming/2015/01/ ... 487-bytes/
487 bytes, that one.
OneSwitch
Post by OneSwitch » Wed Jul 11, 2018 8:56 pm
INKEY-99:RUN
Could anyone make this fully playable (and possible to restart after a brief pause) with the SPACE bar alone, please? I imagine it would not be possible to do in 1 line.
Post by lurkio » Wed Jul 11, 2018 9:15 pm
1L=0:REP.L=L+3:MO.4:DR.1279,0:DR.1279,452:MOVE1279,572:DR.1279,1023:DR.0,1023:F.I=1TOL:V.31,RND(32)+5,RND(31),42,30:N.:P.(L-3)/3:X=0:Y=512:REP.PL.69,X,Y:X=X+4:Y=Y-(INKEY-99+.5)*8:U.PO.X,Y)=1ORX=1280:U.X<1280:V.7:REP.U.INKEY-99:RUN
OneSwitch
Post by OneSwitch » Wed Jul 11, 2018 9:40 pm
Champion. Many thanks. :)
Post by jgharston » Wed Jul 11, 2018 10:01 pm
One-line LOGO:
    1 MODE0:VDU28;31,6479;29,640;512;:PLOT69,0,0:REPEATINPUTLINE">"A$:FORX=1TOVALA$:B$=A$:REPEATC=ASCB$AND31:N=VALMID$(B$,2):IFC=3RUNELSEIFC=10ORC=28OSCLIB$:B$="":UNTILFALSEELSEPLOT4*-(C=8),0,0:P=PEOR-(C=16):A=(A-N*(C=18)+N*(C=12))MOD360:D=N*(C=2)-N*(C=6):PLOT1-P,D*SINRADA,D*COSRAD(A+.1):B$=MID$(B$,INSTR(B$+";",";")+1):UNTILB$=""ORC=24:NEXT:UNTILC=24
sbadger
Post by sbadger » Thu Jul 12, 2018 9:21 am
One-line LOGO:
I can't get this to fit in the keyboard buffer even using abbreviations :?:
1MO.0:VDU28;31,6479;29,640;512;:PL.69,0,0:REP.I.LINE">"A$:F.X=1TOVALA$:B$=A$:REP.C=ASCB$A.31:N=VALM.(B$,2):IFC=3R.ELSEIFC=10ORC=28OSCLIB$:B$="":U.FA.ELSEPL.4*-(C=8),0,0:P=PEOR-(C=16):A=(A-N*(C=18)+N*(C=12))MOD360:D=N*(C=2)-N*(C=6):PL.1-P,D*SINRADA,D*COSRAD(A+.1):B$=M.(B$,INS.(B$+";",";")+1):U.B$=""ORC=24:N.:U.C=24
EDIT:a few of the abbreviation don't parse either?!, yet on a single line they do.
Post by lurkio » Thu Jul 12, 2018 11:44 am
I think some of your abbreviations were a bit off (e.g. MID$ and INSTR). Here's the prog with correct abbreviations. It still can't be typed onto one line though*:
1MO.0:VDU28;31,6479;29,640;512;:PL.69,0,0:REP.I.LINE">"A$:F.X=1TOVALA$:B$=A$:REP.C=ASCB$A.31:N=VALM.B$,2)
2IFC=3RUN EL.IFC=10ORC=28OS.B$:B$="":U.0EL.PL.4*-(C=8),0,0:P=P EOR-(C=16):A=(A-N*(C=18)+N*(C=12))MOD360:D=N*(C=2)-N*(C=6):PL.1-P,D*SINRADA,D*COSRAD(A+.1):B$=M.B$,INS.B$+";",";")+1):U.B$=""ORC=24:N.:U.C=24
Try commands like
F100
R90
F100
C
etc.
Here's the reference for minimum abbreviations in BBC BASIC 2:
* However, it can be typed onto two lines, as shown above, and then compressed onto one line, e.g. by using the Pack feature of the PRES Advanced BASIC Editor ROMs.
sbadger
Post by sbadger » Thu Jul 12, 2018 12:43 pm
Try commands like
F100
R90
F100
C
etc.
Thanks for that, the minimum list is very handy too!
sbadger
Post by sbadger » Thu Jul 12, 2018 3:13 pm
It's pretty good this mini logo PU and PD work too!
Commands i've found that work so far...
Fn	Forward by n
Rn    Rotate clockwise by n degrees
Ln	Rotate anticlockwise by n degrees
PU    Pen Up
PD    Pen Down
H     Home
Post by lurkio » Thu Jul 12, 2018 3:43 pm
Neat!
Here it is, compressed down to one line:
Post by jgharston » Fri Jul 13, 2018 10:45 pm
Here's the full documentation:
 Program : MiniLOGO
 Purpose : One-line Implementation of LOGO Turtle Graphics
 Author  : (C) Jon Ripley, 1999-2001
 Version : 0.08 (24th August 2001)
Commands:
  F <distance> Move turtle forwards <distance>
  B <distance> Move turtle backwards <distance>
  L <angle>    Turn turtle left <angle> degrees
  R <angle>    Turn turtle right <angle> degrees
  H            Home turtle (move to centre of screen)
  P            Toggle Pen Up / Pen Down
  C            Clear screen and home turtle; rest of line is ignored
  X            Exit MiniLOGO
  *<command>   Do *<command>
  : <comment>  Short comment; can be included in compound statements
  | <comment>  Long comment; rest of line is ignored
  ;            Command separator
  <iterations> Repeat command, must be first command in a line
Commands can be upper or lower case. No spaces are required in commands but can be used
anywhere except immediately before a command. Invalid commands have no effect. Numbers
must be in decimal.
Multiple commands on one line can be separated with ';', eg. f100;r90;f100;r90;f100;r90;f100;
The terminating ';' is not required.
Repeat is enabled by prefixing a line with the number of repeats followed by ';', eg. 4;f100;r90;
Comments, suggestions, beer tokens...
Contact : <mailto:jon@stryker.freeserve.co.uk>
Web     : <http://www.stryker.freeserve.co.uk/>
ICQ     : 59461687
