PS/2 keyboard & mouse to Archimedes adapter MK II
IanB
Post by IanB » Sun Mar 15, 2015 8:04 pm
A couple of years ago I posted about a PS/2 mouse and keyboard to Archimedes/A5000 adapter I'd designed using a PIC microcontroller although I didn't include any construction details.
Recently I needed to build a couple more of them and I noticed a PIC project board on ebay which would make an ideal platform for the adapter so I converted it to that board and here are the instructions on how to build one:
(This adapter is not suitable for the Risc PC but I am working on a quadrature mouse adapter for the BBC micro using the same board and that would also work on a Risc PC)
First get the following from ebay:
1. PIC board:
I actually used this incomplete one as I already had the PICs and 20Mhz crystals:
http://www.ebay.co.uk/itm/Microchip-Pic ... 1808854225
This one has the PIC and crystal fitted although it also has headers fitted to the pads:
http://www.ebay.co.uk/itm/Microchip-PIC ... 1875969279
2. PS/2 extension cables (You need 2) e.g:
http://www.ebay.co.uk/itm/1-8m-6ft-PS-2 ... 0181396341
(This is not the lead I used so cable colours in the photos will almost certainly be different to the above)
3. Case:
http://www.ebay.co.uk/itm/PLASTIC-BOX-E ... 0893383579
Construction:
1. First the board needs some slight modification.
Remove the 5V regulator U2 and Diode D1 and fit a wire link between the holes of the two removed components closest to the edge connector (See photos for detail)
After this change, the pad marked 12v will now be connected to 5v instead.
This means there will be 3 pads connected to 0v (GND) and 3 pads connected to 5v so all cables can be connected without sharing pads.
2. Connect jumper wires between the following pads:
A2 and B1
B2 and B6
3. Cut the cables in half, discard one of the ends with a PS/2 plug and trim the remaining 3 half cables to length.
I used approx 75cm for the plug cable and 25cm for the two socket cables.
Remove about 4-5cm of the outer insulation from the cables to reveal the wires and work out which colour goes to which pin.
4.On the Archimedes plug cable:
Pin 4 to pad 2 of the ICSP header (+5v)
Pin 3 to pad 3 of the ICSP header (0v)
Pin 5 to pad A3 (Arc serial in)
Pin 1 to pad A4 (Arc reset)
Pin 6 to pad B7 (Arc serial out)
cut off the unused wires
If you intend to use the adapter with an early A3x0 or A4x0 machine then you might want to connect the pin 4 cable above to pad 2 via a small 2 Amp fuse. (These early machines didn't have a fuse in the keyboard power line and a short circuit would melt the cable!) Later A4x0/1 machines and subsequent designs had a fuse.
5. On the mouse socket cable:
Pin 4 to pad +12v (actually +5v after mod above)
Pin 3 to pad GND (next to B7)
Pin 1 to pad B0 (Mouse data)
Pin 5 to pad B5 (Mouse clock)
6. On the keyboard socket cable:
Pin 4 to pad +5v
Pin 3 to pad GND (next to +5v)
Pin 1 to pad B3 (Keyboard Data)
Pin 5 to pad B4 (Keyboard Clock)
again cut off the unused wires
Testing:
First thing to do is to check for any short circuit between 0v and 5v (pins 5 and 14 of the PIC socket)
Then plug the board into the Archimedes without the PIC fitted and check for 0v on Pin 5 and +5v on pin 14 of the PIC socket.
If these tests go OK, fit a PIC16F628A programmed with the attached code below, connect your PS/2 keyboard and mouse or KVM and power up the Archimedes and see if the keyboard and mouse work.
If you have problems, first check that you haven't swapped the keyboard and mouse connectors.
Then check your wiring matches the attached diagram.
Two of the unused pads can be used to diagnose any protocol problems:
Normally A0 and A1 are at 0v but if a protocol error occurs, they will go to +5v so you could connect leds and resistors to indicate this.
A0 at +5v means a PS/2 keyboard error
A1 at +5v means a PS/2 mouse error
both A0 and A1 at +5v means an Archimedes error
If it tests OK you can fit it in the case:
First cut 3 slots in the case to pass the cables. These should be slightly less than the diameter of the cable so that the lid grips them when fitted. I also used cable ties to prevent the cables from being pulled out. If the cables are too loose, use hot melt glue to secure them.
Usage:
You need a 3 button PS/2 mouse or two button with scroll wheel to act as the third button.
The PS/2 keyboard is quite different from a standard Archimedes keyboard so it operates in 3 different modes depending on usage.
1. "Normal" mode
In this mode all keys on a normal UK PS/2 keyboard produce the correct characters on the Archimedes when pressed. This is achieved using special translation code that changes the actual key or shifted key you press into the one required for an Archimedes keyboard
2. "Game" mode
No translation is done in this mode and the physical position of the key gives the same result as an Archimedes keyboard. Among other things, this means that caps lock and ctrl are swapped.
3. "Partial" mode
Some keys are moved to their translated position such as caps lock and ctrl but none of the special shifted/unshifed translation is done.
To switch between these modes, press either of the two special "windows" keys and "N", "G" or "P" as appropriate.
To force a hardware reset, press either of the windows keys and the BREAK key
If your PS/2 keyboard doesn't have windows keys, hold down the right ALT and CTRL keys instead.
If you fit a jumper to the "reset" header on the board, the converter will startup in game mode instead of normal mode.
PIC programming
You have to program a PIC16F628A with the attached code.
If you don't have a PIC programmer there are some really cheap programmers on ebay for around £5 to £7
I wouldn't recommend them if you intend to do any serious work with PICs but they are just about adequate for doing occasional programming.
e.g.
http://www.ebay.co.uk/itm/USB-PIC-Autom ... 1320977878
The software for it is here: http://buyhere22.com/components/k150/
You may need to replace/reprogram the PIC16F628A on the programmer itself with the hex version included in the software to get it fully functional.
ARC2PS2-v0-16.zip
(158.43 KiB) Downloaded 164 times
sirbod
Re: PS/2 keyboard & mouse to Archimedes adapter MK II
Post by sirbod » Mon Mar 16, 2015 11:15 am
That's really useful. I don't suppose you fancy making them to order for a premium as not many people either have the time/skills or PIC programmer required.
I need four :wink:
Prime
Post by Prime » Mon Mar 16, 2015 11:28 am
Any chance of posting the source code as well as the hex file, would make it easier to port to other micros.
Phill.
jmellidg
Post by jmellidg » Tue Feb 16, 2016 11:00 am
Hi, thank you very much for the post, Works great!! Greatings from Spain
Post by Zarchos » Tue Feb 16, 2016 11:21 am
If sbdy had the time and the will to build and sell some, I'd be interested to buy in buying a dozen, depending on the price.
JonC
Post by JonC » Tue Feb 16, 2016 1:22 pm
Zarchos wrote:If sbdy had the time and the will to build and sell some, I'd be interested to buy a dozen, depending on the price.
It cost me about £26 for two (not including the PIC Programmer), and that's unassembled. That should give a rough idea of the cost.
I recon the hardest part of the assembly will be figuring out which wire colours are connected to which pins on the cable. :lol:
Jon
Post by Zarchos » Tue Feb 16, 2016 2:10 pm
Prime wrote:Any chance of posting the source code as well as the hex file, would make it easier to port to other micros.
Phill.
Seconded, having some knowledge of how a PIC works is on my 'to do before dying' list ;-)
I think it would be great to tell Charlie about this project : it could be available on his Qube RISC OS projects page.
IanB
Post by IanB » Sun Feb 21, 2016 7:11 pm
Zarchos wrote:Seconded, having some knowledge of how a PIC works is on my 'to do before dying' list ;-)
It seems to be pretty stable now so here's the source:
Source-arc2ps2v0-16.zip
(9.2 KiB) Downloaded 168 times
Post by 1024MAK » Mon Feb 22, 2016 7:59 am
8) =D>
Thanks :D
Post by Zarchos » Mon Feb 22, 2016 8:35 am
Seconded !
Thanks a lot, something else to learn it's really great.
olivierb
Post by olivierb » Tue May 10, 2016 1:57 pm
Hello,
I just wanted to thank you for sharing your design. Las week, I built the adapter and I was able to revive my A4000.
paulv
Post by paulv » Thu May 19, 2016 8:16 am
Just a cautionary note, the PIC programmers based on the Prolific 2303HX or 2303HXA are not supported on Windows 8.1 or 10...
vectorlight
Post by vectorlight » Fri Apr 28, 2017 5:50 am
I'd like to give this a go as CJE have lost all their stock of keyboard/ps2 adaptors :oops: , but the main board on ebay has sold out. Any idea where to get an alternative from?
vectorlight
Post by vectorlight » Fri Apr 28, 2017 9:49 am
Ignore my request, I asked the ebay seller and he has relisted them for me :D
vectorlight
Post by vectorlight » Thu May 18, 2017 1:41 pm
Can anyone recommend a cheap but reliable PIC programmer? I grabbed this from ebay only for it to refuse to work correctly. (It'll be going back to the seller). Something that works on Win 10 would be perfect :D :
http://www.ebay.co.uk/itm/232306834954? ... EBIDX%3AIT
Post by 1024MAK » Thu May 18, 2017 6:30 pm
I use the PICkit 2, an earlier version of the current PICkit 3 available direct from Microchip https://www.microchipdirect.com/Product ... s=PG164130.
The modern PIC microcontroller chips can be programmed in circuit if there is a programming header. If not, it's not hard to solder the required connector, and a turned pin DIL socket to some stripboard or matrix board.
vectorlight
Post by vectorlight » Thu May 18, 2017 7:03 pm
Thanks Mark :D
I've just realised that my regular eprom programmer can also do PIC, something I never new, so will try that now. :D
aotta
Post by aotta » Fri May 26, 2017 10:20 am
Very interesting DIY! i ordered weeks ago the hw needed, spent yesterday night to follow your tutorial and, at dawn time, ready to test my works....
But... A3000 has 9 pin minidin connector? :shock: :roll:
Before wiring all 9 wires from alternative mouse point at lk4 to the unused serial port D9 socket... i wonder it this project will work for my Archi (i mean, only as ps2 mice adaptor..).... anyone tested it with a 30x0 ones?
Post by danielj » Fri May 26, 2017 11:11 am
This isn't for the A3000/A30x0 machines, it's for the archimedes/A5000 :(
There are a few options for the A3000/A30x0/A4000/RiscPC for mice? Many PS/2 mice can be fitted to an archimedes... This one, for example:
https://www.ballicom.co.uk/-ms-04-ps2-.p886897.html
It does need some surgery though:
viewtopic.php?t=6869
RS components sell a ready-wired 9-pin minidin lead (bit pricey in itself at around £8 or so, but you can build a mouse for about £10-£12)
aotta
Post by aotta » Fri May 26, 2017 2:11 pm
Thank you.. maybe one day i will get an A5000... for testing this adaptor! :)
In the meanwhile... i'll start modding my ps2 mice as suggested in the post you reported.
aotta
Post by aotta » Tue Jun 06, 2017 7:59 am
If someone interested.... I used the board bought for this adapter, to make.... a USB to Mini DIN 9 (Archie's one) adapter for my A3000!
Very simple after all.... i follow one of the tutorials for the Amiga adapter (i found on the net the tutorial by Henryk Richter.. it works fine for me), but soldered the mini din cable following the A3000 pinout... ;)
update (13/6/2017): for using Amiga mouse too (and the usb & ps/2 adaptor for Amiga i have) i added also a DB9 port near the original mini Din 9, and used the Amiga pinout in wiring to the alternative mouse points on A3000 pcb... this is the results! :)
IanS
Post by IanS » Sat Oct 26, 2019 9:44 pm
So I finally got round to trying to build one of these. With a view to getting a few PCB's made.
This is what I've got so far.
(this explains my interest in the ps/2 sockets from Dave - viewtopic.php?f=8&t=17861)
I'm not sure what the Reset link for the mode selection on the original PCB does to pin 4. Is it pulled high/low or open circuit. Does it need pulling high or low to change mode?
So far it works really well, I should have done this ages ago. Thanks for sharing the design.
IanB
Post by IanB » Sat Nov 02, 2019 10:08 pm
The "reset" line is just used as a normal input port in this design, actual power on reset relies on internal timeconstants in the PIC.
If the line is pulled high on power up then normal keyboard mode is selected, if the line is tied low on power up then game mode is selected.
If you are looking at a PCB design, it might be worth using another PS/2 connector for the Archimedes side as you could use a ready made PS/2 to PS/2 lead to connect it to the Archimedes rather than have to make up a lead.
BTW It's possible to use USB mice and keyboards with this converter if you use an Aten CS1734B or CS1732B KVM switchbox with the optional PS/2 leads as the Aten will convert the USB signals to PS/2 signals which are compatible with the converter.
You can actually take this further and daisy chain that KVM to a more modern DVI switchbox such as a CS1764A via an OSSC converter to make it possible to switch between three PC style DVI/HDMI/USB systems and four VGA/PS2 or USB systems all from one monitor and USB keyboard/mouse.
Let me know if you want further info on how to setup something like that.
IanS
Post by IanS » Sat Nov 02, 2019 11:55 pm
Thanks for the reply.
Pin 4 appears to have a fairly high input resistance. I tried adding a 4K7 pull-up, with a jumper to pull it low, but with just the resistor, the voltage on pin4 was only about 1.5V, which wasn't enough to register it as high.
Are you open to feature requests? As you can set the mode via the keyboard, would it be possible to re-purpose pin 4 as a dedicated DELETE key. The idea being that if you were trying to fix an archimedes, you could just use one of these with the (dedicated) DELETE key pressed to reset the machine on power-up, without neededing a keyboard or mouse connected.
Not a show-stopper, but was supprised that with only a mouse connected the mouse buttons don't work, it appears to need a keyboard connected to allow any button presses (keyboard or mouse) to register.
I've already orded a few test PCB's and will look into pre-made cables for the archimedes side. It's a trade-off between cost of cable and connector and faff of making up a cable. The 2x3 IDC is a way of using 6 way ribbon cable for the PCB and, then only need to solder the 6-pin DIN end.
IanB
Post by IanB » Sun Nov 03, 2019 2:21 am
The prototyping board I used above had a 10K pullup on that line and I never noticed any problem with it although I never measured the voltage at the pin.
I'll have a look at that sometime, I can see it would be quite useful.
The protocol sends mouse buttons as if they are key presses and looking at the code, a flag prevents keypress data from being sent if the keyboard is not detected / initialised. I think that was to stop power up keypress data from the PS/2 keyboard from messing up the Archimedes keyboard initialisation sequence but it should be possible to make an exception for mouse "keys".
IanB
Post by IanB » Sun Nov 03, 2019 9:44 pm
Here's V0.17 with the mouse button bug fixed:
arc2ps2-v0-17.zip
(12.65 KiB) Downloaded 10 times
IanS
Post by IanS » Sun Nov 03, 2019 10:13 pm
That works, Thank you.
IanS
Post by IanS » Tue Nov 05, 2019 7:25 pm
As you can see here the !Sonar software causes the keyboard adapter to crash when clicking record.
viewtopic.php?f=16&t=18182&p=252809#p252809
On a real Arc keyboard the mouse freezes during recording, but then moves again after the recording has finished.
With the PS/2 adapter, when you click record, both error lights come on, and the mouse and keyboard won't work again until after a power cycle.
The !Sonar software works with or without the hardware, so it should be possible for anyone with the PS/2 adapter, to check I haven't done anything stupid.
IanB
Post by IanB » Wed Nov 06, 2019 8:54 pm
Two leds means an error occurred with the Archimedes side of the protocol and if the mouse freezes then maybe interrupts are disabled during recording which would cause such a protocol error as there would be no reply from the Archimedes to any new mouse movement packets. This would cause the PIC to timeout, flag the error and restart but maybe the restart code is not working properly thus causing a lockup.
Is a normal keyboard also frozen during recording as well as the mouse?
i.e. does caps lock still work on a normal keyboard?
IanS
Post by IanS » Wed Nov 06, 2019 9:06 pm
It does look like interrupts are disabled (makes sense, as they are probably polling the A/D converter). With an original Arc keyboard the caps lock doesn't respond during recording.
