Monitor suggestions for an A7000+
johnha
Post by johnha » Thu Mar 07, 2013 11:40 pm
Hi All,
Having bought an A7000+ I'm now looking for suggestions for a suitable monitor and I'm torn between a modern LCD Vs original Acorn monitor (and also TVs that might be suitable through VGA - My beebs need a SCART too).
As I'm not that familiar with the A7000+'s requirements (I understand there are some limitations with my A310 - but my TV works with that). I've tried the SD TV with the A7000+ but get an 'out of range' error from the TV (I've tried blind-typing to set mode 15 but it didn't work).
Any suggestions or considerations?
Regards,
John.
SarahWalker
Re: Monitor suggestions for an A7000+
Post by SarahWalker » Fri Mar 08, 2013 8:17 am
You can get TV resolution modes out of an A7000+, however the machine was shipped with a normal SVGA monitor and it's probably best to stick with something like that.
If you want the TV res modes you need to pick a suitable monitor type in !Boot - *configure monitortype doesn't work on the newer machines.
retroclinic
Post by retroclinic » Fri Mar 08, 2013 10:31 pm
Acorn AKF53 FTW.... true multisync (or something similar).
caluser2000
Post by caluser2000 » Sat Mar 09, 2013 3:45 am
Try setting the sync to 0
And monitor type to 3
I think I used Mode 21
That works fine on LCD monitor and LCD TV with my RiscPC.
Guide at the bottem of this link- http://www.snowstone.org.uk/riscos/docu ... ewold.html
