A5000 using Wifi Dongle
mark71
Post by mark71 »
Hi All
Just something as an experiment on getting the A5000 on wifi, of sorts, Bought a Wifi Dongle on Ebay, connected it up and it worked!, see picture below. Connected to a few BBS's, using Hearsay2, one thing could only get the max baud rate to 19200, can the A5000 do higher 115200?.
Next steps set up a local BBS on a Pi for file transfers, rather than zip discs...
richw
Re: A5000 using Wifi Dongle
Post by richw »
I think you might be able to use a higher rate, but you might need to switch to mode 0!
thecellartroll
Post by thecellartroll »
Is it serial to WiFi?
mark71
Post by mark71 »
thecellartroll wrote:
Sat Sep 19, 2020 8:51 pm
It is a Serial to WiFi, from Simultant works ok.
