Right . . . From looking at the above posts it seems that there are at least 4 revisions! Does anyone have a higher revision than 4?
Attached is a spreadsheet for revision 1. If you don't have this revision please don't order a kit . . . yet!
NEEDED! Anyone with a different revision could you please make a list of the capacitors and Semiconductors (see the note below). Then I'll be able to merge the spreadsheet and offer kits for the appropriate revision (see notes).
Note:
I've only listed parts that come under stress or that have a finite life e.g. the major semiconductors, optocoupler and electrolytic capacitors. I have included, in the parts list attached, the mains input DC filter capacitor as it sits right up against the bridge rectifier e.g. it probably gets warm!
One part I've not fond: EGP30D - However, looking at the Datasheet for the
EGP20D I would guess that the EGP30D is a 3A part as the EGP20D is a 2A part. As this diode supplies the -12V rail specified at 250mA I feel the EGP20D would be an adequate replacement (?).
By the way, RS has the best 'search' engine bar none, so far! But it still takes an age to do this - like 9 hours plus up to now
There are just too many specs to consider e.g. Ive limited the range of suppliers, maximum temperature and life of the the capacitors . . . I've still to triple check before ordering.
If you've indicated that you would like a kit - please check your revision number and confirm your request. Thanks.
Dave H
P.S. I'll move on the the main board later . . .
