RiscPC/Archimedes Monitor recommendations?
mark71
Post by mark71 »
Hi All
A quick question but most likely a complex answer, what are your recommendations for sourcing a LCD replacement montiors that will work with RiscPC's?, having a AFK18 monitor that still works but am looking for something a bit more modern and not so bulky to use on my venerable 32bit Acorn kit.
MArk
Re: RiscPC/Archimedes Monitor recommendations?
Post by danielj »
BenQ BL912 or BL702 both have VGA connectors and also can display the 15kHz modes without needing an adaptor.
mark71
Post by mark71 »
danielj wrote:
Sun May 24, 2020 10:22 am
Thanks for the tip, bought a BL702A from Amazon for 94.99, works a treat on the A420/1 and the RiscPC, 1280x1024 for the the latter really nice picture too.
Post by danielj »
mark71 wrote:
Tue Jun 02, 2020 5:47 am
Brilliant - thanks for reporting back! Great little monitors those.
mark71
Post by mark71 »
danielj wrote:
Tue Jun 02, 2020 8:12 am
Hi Daniel
A quick question about this monitor, a good monitor, works a treat on my RiscPC and through an adapter on the A420/1 but when connecting to the A5000 or A3010 it doesn't detect an output from these machines, both running 3.1 and monitor set to Auto i have a feeling may need some changes to monitor type for it to work?.
IanJeffray
Post by IanJeffray »
Holding a numeric keypad key during power-up changes the monitor type to that value - a quick and easy way to get an Arc to deal with a monitor when you can't see what's going on. I expect you'll want monitor type 0, 3 or 4.
https://www.riscosopen.org/wiki/documen ... or%20Types
mark71
Post by mark71 »
IanJeffray wrote:
Mon Sep 07, 2020 10:29 am
Hi Ian
The secret source seems to be Sync, if on Auto for the A3010 and A5000 changing Monitor type has no effect, set it to 0 and it works!
IanJeffray
mark71 wrote:
Thu Sep 10, 2020 8:47 pm
Doh. Sync is toggled with Keypad 'dot'. IIRC Glad it's sorted.
Post by 8271 »
I use a Dell LCD screen (1708FPt) on the RiscPC and A5000. You can get them second hand on ebay for £20. I have bought about 4 from IT recycling firms and they have all been perfect.
Serial computer hoarder & econetophile
2 x BBC-B, 4 x Master128, Master Viglen, Master Domesday, A310, A4, A5000, RiscPC700 Level 4 Server, RPC_SA233 & RPC_SA200, RiscOS_Pi, Econet & Ethernet
