A3000 repair -- keyboard connectors
SteveBagley
Post by SteveBagley »
I'm in the middle of repairing an A3000 and everything seems to work except that it seems the keyboard connector no longer make contact with the keyboard properly. Does anyone know where I can order a replacement?
Thanks,
Steve
Boydie
Re: A3000 repair -- keyboard connectors
Post by Boydie »
Available from Mouser (or were in November) - part no. 571-7-520355-0.
Worked fine in my A3000
CJE-4D
Post by CJE-4D »
ADVERT MODE ON
If you are in the UK then we are cheaper after postage and will be quicker:
http://www.cjemicros.co.uk/micros/indiv ... TRA3K-2x13
Though the pins will need straightening which hasn't caused us any issues when fitting.
Chris
Post by flaxcottage »
Nice idea, that. :D
Boydie
Post by Boydie »
Mouser had them in uk stock when I ordered, so carriage was free as part of a bigger order).
It would seem Farnell also stock them for £1.03 each (+vat & carriage), which they didn’t when I bought mine.
The manufacturer’s (TE Connectivity) part number is 7-520355-0. Google throws up a few possibilities...
Edit: Ignore the Farnell one. It’s for 1800 pieces! :oops:
Boydie
Post by Boydie »
How many do you need - is it just one that’s bad or both?
If it’s only the one, I’ve got one left over from my repairs.
mattdy4
Post by mattdy4 »
Also looking for a couple. Unless someone wants 1798 pieces, then I'm pretty sure we could arrange something :wink:
philpem
Post by philpem »
I wouldn't mind getting a couple for my spares box (maybe half a dozen). Anyone up for a bulk order? :)
mattdy4
Post by mattdy4 »
TE website has it's own storefront and these are listed as in stock so ordered 5 units for just under 11USD with free delivery (in fact I made two cents on that delivery apparently).
Says 2-4 days to the UK so will let you know how that and connectors themselves turn out. I shouldn't have any problems with customs and VAT delaying things either hopefully due to their low value
mattdy4
Post by mattdy4 »
Delivered fresh from Omaha in a little over 48 hours. Look good to me!
