Acorn AKA20 We32206 Floating Point Co-Processor
egel
Post by egel » Tue Feb 25, 2020 2:14 pm
What can you do with a Acorn AKA20 We32206 Floating Point Co-Processor? I know it is a FPU. Is it usable with RISC OS or only with RISC iX? In which machines would it work?
Re: Acorn AKA20 We32206 Floating Point Co-Processor
Post by danielj » Tue Feb 25, 2020 2:17 pm
That's rather unusual!
http://chrisacorns.computinghistory.org ... CoPro.html
Looks like it came in with the R140 - I'm personally not aware of any software that used it specifically (but that doesn't mean too much!)
Post by IanS » Tue Feb 25, 2020 7:43 pm
... In which machines would it work?
Officially R140 A400 only. It relies on the middle row of pins on the backplane connector for the full 32-bit data bus, which was only on the A4xx backplanes.
Middle row of pins on the motherboard were used for power on the A540/A5000, so won't work on them.
With the right backplane it should work on A3xx machines.
Boydie
Post by Boydie » Wed Feb 26, 2020 7:28 am
RiscIx detects and uses it automatically (at least 1.21c does). There’s a special version of the FPE module for RiscOS - I’ll dig it out if it’s not available.
It only works on ARM2 A400 series machines AFAIK. Don’t think the 300 motherboard had the copro lines fitted, regardless of what backplane is installed.
It won’t work with an ARM3 because Acorn changed the copro lines.
Beware when installing it - it only works in one podule slot. And it’s not the one you instinctively assume (or at least not for me). The Acorn software disc has a test program on it, to check it out.
egel
Post by egel » Wed Feb 26, 2020 8:08 am
I had once seen that the backplane connector on an A3xx motherboard only has the outer rows connected, so more is needed than just an A4xx backplane.
Post by IanS » Wed Feb 26, 2020 8:42 am
The middle row are shown on the circuit diagram - http://chrisacorns.computinghistory.org ... 300_SM.pdf. Maybe they didn't fit a 3 row connector, but the pcb looks capable. I'll check my A3xx later.
Boydie
Post by Boydie » Wed Feb 26, 2020 12:52 pm
Looking at the respective service manuals, the A300 specifies a 64-way connector in its parts list, the A400 a 96-way.
I thought it’d been officially nobbled in some way, if for no other reason than to polarise the budget and high-end models.
Post by Richard Russell » Wed Feb 26, 2020 12:52 pm
Ah, the nostalgia of an ARM FPU that supports extended precision (64-bit mantissa). Sadly all modern ARM CPUs with integrated FPUs can manage nothing better than double-precision (53-bit mantissa).
Boydie
Post by Boydie » Wed Feb 26, 2020 1:06 pm
Looks like the support disc may be MIA. I’ll upload when I get chance.
As for what can be done with it, disappointingly little in practical terms. Given that it’s a choice between the copro (and faster FP) or ARM3 (and faster everything), it’s usually a no-brainer. The only advantage is faster FP in a machine you otherwise want to keep as original as possible (mine’s in an R140 that I don’t want to upgrade).
Edit: Alarmingly, that R140 is either the 3rd or 4th best Acorn machine I have for FP (behind A540 and A5000 with FPA10, and possibly RPC-SA). More alarmingly, the next fastest may be the ACW with 10MHz 32081!
waldorfmuppet
Post by waldorfmuppet » Wed Feb 26, 2020 1:14 pm
Can the FPU podule not co-exist with the ARM3? I do remember with the RiscPC some software that allowed the x86 cards (assuming not the SX versions) to be used as a pseudo-FPA, but that became obsolete with the StrongARM as the overhead of getting it across the DPOB made the latency greater than just using the FPE.
Post by davidb » Wed Feb 26, 2020 1:22 pm
You don't own an A7000+? :shock:
I found that for some tasks - OK, FP-heavy tasks - the A7000+ was at least as good as a StrongARM RPC of the period.
Boydie
Post by Boydie » Wed Feb 26, 2020 3:26 pm
Nope. The plus model never came down into what I considered an acceptable price range. The bulk of my collecting was done when the stuff was worth bog-all, which the A7000+ never really dropped to.
dp11
Post by dp11 » Wed Feb 26, 2020 6:06 pm
On the RIscPC I did write the software to using the x86 card as the FPU. So if you have an 586-133MHz card that is probably the fastest FP Acorn machine.
Boydie
Post by Boydie » Thu Feb 27, 2020 9:34 am
Back in the day, it was asserted that it wouldn’t work in ARM3 machines. What wasn’t stated was why or in what circumstances. ie Does this only apply to native ARM3 machines due to copro bus differences on the backplane, or is there something about the ARM3 itself?
Since the FP podule essentially just has a version of FPEmulator which traps FP code and sends it to the podule rather than the ARM, it *may* play nicely in a machine which has an ARM3 wired to sit in place of an ARM2.
Alternatively, the designers of the ARM3 board may not have bothered to implement the relevant lines for a copro, given that almost nobody owned one.
Or the FPEmulator module itself may break on an ARM3.
Only one way to find out if it works. When I get chance, I’ll try it in my ARM3-equipped A400-series and feed back.
egel
Post by egel » Thu Feb 27, 2020 10:11 am
And I have to try to get an A400-series. ARM3 is not the problem to get.
SarahWalker
Post by SarahWalker » Thu Feb 27, 2020 10:41 am
The backplane copro bus relies on the copro instruction being present on the main data bus. This will be the case on arm2 as it would have just been fetched, but won't be the case on the arm3 due to the cache. Arm3 has a separate copro bus to work around this, but this extra bus isn't connected to the backplane.
Boydie
Post by Boydie » Thu Feb 27, 2020 10:43 am
Thanks for the explanation. You’ve just saved me from a couple of hours of futility. =D>
Post by RobC » Thu Feb 27, 2020 12:16 pm
Was this the one marketed by Warm Silence Software? I've looked around for it for years but it seems to be MIA.
dp11
Post by dp11 » Thu Feb 27, 2020 12:48 pm
Yes WSS sold it. I have the builds and source code in the loft. I'll dig it out if you are interested.
hubersn
Post by hubersn » Thu Feb 27, 2020 1:36 pm
WSS' website is still (a)live, although Robin Watts does interesting things working for Artifex Software (Ghostscript, MuPDF...) nowadays.
Here's the link to FPEPC: http://www.wss.co.uk/products.html#FPEPC
Have fun
hubersn
CJE-4D
Post by CJE-4D » Fri Feb 28, 2020 12:52 pm
What about the FP speed of an Aleph1 486Podule with CX83S87 fitted?
mr-macrisc
Post by mr-macrisc » Fri Feb 28, 2020 1:03 pm
I imagine the best cpu for the x86 card for FPU in RISC pc would be the Cyrix 5x86 (if you can find a Cyrix or ibm version capable of running at 133Mhx) the FPU should be noticeably faster than 160Mhz AMD
CJE-4D
Post by CJE-4D » Fri Feb 28, 2020 2:44 pm
Is the FPU built into a 5x86 then?
I sold hundreds of our 5x86 133MHz 512k cache RISC PC cards at about £500 each so I probably did know the answer!
SarahWalker
Post by SarahWalker » Fri Feb 28, 2020 3:51 pm
Both AMD and Cyrix/IBM 5x86s have FPUs built in. The NexGen 5x86 doesn't but as that chip doesn't fit a 486 socket and bus you won't see it in a RiscPC PC card.
The Cyrix FPU will be faster per clock than the AMD one, but AMD clocks faster. In any case the difference will probably be unnoticeable once you consider the overhead of bouncing FP instructions from the ARM to PC side and the results back again!
dp11
Post by dp11 » Fri Feb 28, 2020 4:00 pm
FPEPC only moves results across domains with LD ST instructions so if you do lots of trig one after another you can get a good speed increase.
I don't think I ever tested the AMD so it may not even boot.
TimoHartong
Post by TimoHartong » Sat Feb 29, 2020 9:49 am
It would fit nicely in my R140 :D . But indeed it is true because a real floating chip was ( horribly ) expensive and the emulation software was relatively slow in comparison with the real thing not much floating-point intensive software was written.
