I have a pair of 4.39 ROMS in my RiscPC I'd like to make a backup of in case anything happens to my RPC as I understand they're not easy to get hold of and to use in Arculator (assuming I can) to create a fresh SD build
How can I extract the ROMs from the command line and is it just a case of burning to 27c160s if needs be?
RISCOS 4.39 ROM Backup
Re: RISCOS 4.39 ROM Backup
To save the ROM into one file for emulator use, do the following:mattdy4 wrote: ↑Mon Dec 30, 2019 2:48 pmI have a pair of 4.39 ROMS in my RiscPC I'd like to make a backup of in case anything happens to my RPC as I understand they're not easy to get hold of and to use in Arculator (assuming I can) to create a fresh SD build
*save rom 3800000 3c00000
Important: RISC OS 4.39 will not run in Arculator, as Arculator is emulating pre-Risc PC machines (i.e. up to RISC OS 3.19).
Have fun
hubersn
Thanks hubers, looks like I might have trouble formatting the card on a PC using an emulator like rpcemu anyway.
Anyone know of a copy of the RISCOS 4.39 CD? The only one I can find on the webs is a dead link and the 3DQ documentation assumes that you already have a live set up and doesn't cover
- geraldholdsworth
- Contact:
I do believe I have a physical copy and, maybe, even a digital ISO copy.
Gerald.
Thanks Gerald - great to know they're not eternally lost. I'll take you up if you don't mind in some form once I've fixed some new VIDC issues on my RPC
The 4.39 !Boot seems to be downloadable: http://www.riscos.com/ftp_space/439/index.htmmattdy4 wrote: ↑Tue Dec 31, 2019 6:28 pmThanks hubers, looks like I might have trouble formatting the card on a PC using an emulator like rpcemu anyway.
Not the full CD content of course!
Have fun
hubersn
- geraldholdsworth
- Contact:
I'll have a hunt on my PC for it and send you the Dropbox link - probably best and easiest way.
