Open source A5000 RAM
cmorley
Post by cmorley » Tue Sep 03, 2019 6:31 pm
Schematic & gerbers here
As per the A3020 RAM I've drawn an open source A5000 RAM module. Again Zarchos is funding the prototypes then I will release all the files once it is working.
There is a small blunder with the prototype PCB - it turns out that 2x 0.1" isn't 0.3"... who knew? I can get the connector on well enough to prove them electrically.
Since the A5000 uses a separate MEMC like the A3000 does I put provision in for the buffers I had to add to the A3000 RAM boards to cover over the poor signal integrity on the A3000. This might or might not be needed on the A5000 so they are optional on the prototype.
Once tested assuming it works I will draw the release PCB with the correct connector footprint and buffers/no buffers as required.
I don't have an A5000... so a volunteer for testing would be appreciated. Someone who can perform IanS' file copy test.
It'd be nice to get some testing in soon so this and the A3020 RAM can be demoed at the next ABUG.
Chris
Re: Open source A5000 RAM
Post by steve3000 » Tue Sep 03, 2019 7:04 pm
Oh, exciting!
I'd happy to volunteer and have an 8mb A5000 so can test with/without the 8mb upgrade fitted.
I also have an old 'prototype' 1mb A5000 in the loft, but suspect your design requires 2mb on-board...or does it replace the on-board RAM completely?
Post by IanS » Tue Sep 03, 2019 7:07 pm
Nor do I, or I'd be happy to help. (I don't own an A3020 either)
Is this and the A3020 boards a full 4MB, completely disabling the on-board RAM?
cmorley
Post by cmorley » Tue Sep 03, 2019 7:39 pm
Oh, exciting!
Splendid thank you. It has 4MB on card and you disable the motherboard RAM with LK23 & LK24 so it is supposed to work with a 1 or 2MB A5000.
I will PM you and sort out getting the cards to you.
cmorley
Post by cmorley » Fri Sep 06, 2019 8:26 am
One board built up for now. No buffers fitted. If they aren't required I will delete them from the PCB when I fix the footprint of the DIN connector.
Kazzie
Post by Kazzie » Fri Sep 06, 2019 4:23 pm
I may be having a dumb afternoon, but I can't see where the buffers would have been placed, based on the tracks seen on the boards. :?
myelin
Post by myelin » Fri Sep 06, 2019 6:23 pm
Zoom in on the photo of the back of the board above... the buffers go on those 14 SOT-23-5 footprints (which have solder blobs bridging the input and output right now). Plus one for Ra9 on the front of the board, by the looks of things.
Kazzie
Post by Kazzie » Fri Sep 06, 2019 8:00 pm
Ah, thanks. I hadn't zoomed it, and presumed that they were surface-mounted passives.
I'm still soldering things at 1970s scale, when I get the choice! :P
cmorley
Post by cmorley » Tue Sep 17, 2019 6:53 pm
Testing by Steve has shown it doesn't work without buffers. I am not surprised because the A5000 has a discrete MEMC just like the A3000 (which didn't work either). So solder the buffers on next for a retest on the spaces I put on the the board for this very eventuality!
I had hoped the A3000 problems were PCB layout but I think they are MEMC. I suspect it doesn't actually have enough ground pins. You get away with it with slow RAM from the 90s but not with 2018 tech. I wonder if Acorn knew about this BITD? (rhetorical)
cmorley
Post by cmorley » Thu Sep 19, 2019 12:01 pm
Steve sent the boards back so I soldered the buffers on this morning (which arrived from RS yesterday). Flipping things are twice the price they were last year - but amusingly buying 150 is cheaper than buying 75 :lol:
I'll bring it to ABUG at the weekend then post it to steve3000 again for further testing. This fix worked on the A3000 so I am hopeful it will fix the problems.
cmorley
Post by cmorley » Sat Sep 21, 2019 6:56 pm
Testing at ABUG today the RAM with buffers on works flawlessly so far. I will post it to steve3000 next week to see if it is fixed in his machine too. If so I will tidy up the PCB layout and release the Gerbers :D
cmorley
Post by cmorley » Tue Sep 24, 2019 9:32 pm
I redrew the board today to fix the connector pitch :oops:. I had to move all the buffers because they didn't fit where I'd put them. I've moved them all onto the component side leaving an almost intact ground plane 8)
Top:
Bottom:
Assuming the buffers fix everything for steve3000 I'll order up some of these boards. Might jig the silkscreen around a little but otherwise I think we have success :D
dp11
Post by dp11 » Tue Sep 24, 2019 9:35 pm
might as well put all the smt on one side. Looks good.
dp11
Post by dp11 » Tue Sep 24, 2019 9:40 pm
I'd also add a little decoupling for the buffers easy not to fit if it isn't required.
cmorley
Post by cmorley » Tue Nov 05, 2019 4:27 pm
Fixed connector footprint, assembled and ready for steve3000 to confirm it works (I don't have an A5000).
Top:
Bottom:
It should just work because it is simply a layout modification of the working design.
Once Steve has had a chance to test I'll release the gerbers. I'll also take orders for anyone who wants a board assembled (same for the A3020/A4000 RAM). There might be some blank PCBs spare too so brave souls can assemble their own.
alexgibson
Post by alexgibson » Mon Dec 30, 2019 3:54 pm
This is a brilliant development. I would love to get involved in the testing, I have a couple of A5000s
cmorley
Post by cmorley » Wed Jan 01, 2020 8:50 pm
Do you intend to try overclocking the A5000?
steve3000 has both of the assembled boards at the moment. As soon as I get the green light from him I will release all the sources.
I need to talk to XLT but it is likely I will assemble some to order for stardotters who want one.
alexgibson
Post by alexgibson » Sat Jan 04, 2020 9:56 pm
I am definitely open to overclocking one of the A5000's :)
Good excuse to get it out - it's my best machine for 26-bit games.
I am currently sorting out a lot of my Acorn hardware, and even plotting making some new upgrades of my own...
cmorley
Post by cmorley » Sun Jan 05, 2020 12:55 pm
OK testing has gone well & they seem fine. Only question left is how well the overclock. I'm not sure if Steve3000 is going to have a go overclocking the A5000 or not.
I will make one batch of these by order for stardotters. They won't be an ongoing product from me. Please don't respond to this thread I will post a sales thread soon.
Schematic:
A5000_2.pdf
(104.45 KiB) Downloaded 17 times
Gerbers:
A5000_4MB_2.zip
(197.25 KiB) Downloaded 11 times
There are so few parts I didn't put a BOM together per se. All the part numbers are on the schematic. Contact me if you need more details. The source is open and I can send the original diptrace files (or export to another CAD system) on request. Thanks to Xavier Tardy for commissioning this project on behalf of the 32-bit Acorn community.
