I have upgraded with MEMC1a+PAL, an Econet card and added a backplane and a spare Cumana SCSI card.
With/without Econet the system then gives an error on startup: Error from $. SWI &41504 not known.
I swapped the card (rev'n 4, SCSIFS 1.17) for the one in my A5000 (rev'n 3, SCSIFS 1.19) where it worked fine so the A310 now has the one from the A5000 and gives the same error.
*podules shows the podule but
*devices gives DRIVE EMPTY when it should list the card as a host.
SCSIFSDiscs is set to 0.
Is this card not compatible with Risc OS2?
Some other problem?
Ray
