Burn RISCOS roms
cyberfox_it
Burn RISCOS roms
Post by cyberfox_it » Wed Apr 24, 2019 11:21 am
I think, I've broken one of the rom of my RPC...
I've found on the net the image files of the 3.71 rom, I've an eprom programmer, what kind of eprom I need ?
I think I've to split the rom file into even and odd parts, anyone can confirm this ?
Anything else to do before try to burn ?
Please help...
Thank you
keropi
Re: Burn RISCOS roms
Post by keropi » Wed Apr 24, 2019 5:21 pm
what are the chances?
I also killed my 4.02 ROM2 rom , I inserted it 1 pin to the left :x
I know 4.02 uses an otp eprom similar to 27C160 but I have no data to burn so my rpc is just dead atm :x
cyberfox_it
Post by cyberfox_it » Wed Apr 24, 2019 6:53 pm
I've done exactly the same ... :(:(
keropi
Post by keropi » Wed Apr 24, 2019 6:56 pm
and now your rpc just powers without any video signal , correct? mine does that
cyberfox_it
Post by cyberfox_it » Wed Apr 24, 2019 8:29 pm
Yes...
Only a beatifull blank screen...
Post by danielj » Wed Apr 24, 2019 8:52 pm
https://www.utsource.net/itm/p/426796.html
You'll need something that can deal with a 42pin DIP though :/ - 3.71 is fairly easy, the images are available. 4.02 less so as it's still sold (albeit not as a ROM, just as images).
keropi
Post by keropi » Wed Apr 24, 2019 9:09 pm
which is total bs
I bought 4.39 from risc-os.com , why not have the rom images as well?
I found their softload 4.39 to lack several things:
- DHCP INFO utility does not work because they did not include the needed toolbox update - that's a bundled app
- there is an error in installation regarding scicalc , again a bundled app that works ok afterwards
- it needs 4.02 boot partition - why? do a rom check if you only want to sell it as a "4.02 upgrade only"
I guess it could be worse... :lol:
lcww1
Post by lcww1 » Wed Apr 24, 2019 9:15 pm
There are a few pointers on burning RO ROMs for RiscPC here https://www.riscosopen.org/forum/forums/5/topics/870
And it seems to be possible to deal with 42 pin 27C160s using a cheap minipro TL866 and an adapter board described here http://digicoolthings.com/eprom-program ... it-eproms/
cyberfox_it
Post by cyberfox_it » Wed Apr 24, 2019 9:56 pm
I've that programmer, the adapter, and the rom images...
I'm going to try to burn a 4.02 eprom...
Only a question, the image should be splitted in even and odd of a word ?
Post by IanS » Wed Apr 24, 2019 10:03 pm
Yes, the ROMs are 16-bit, so one rom needs bytes 0 and 1 (D0-D15), the other ROM needs bytes 2 and 3 (D16-31).
keropi
Post by keropi » Wed Apr 24, 2019 11:50 pm
I have found an archive of 4.02 that has inside 4x 1mbyte roms - the actual devices though on rpc are 2x 2mbytes ... what's the deal here? any tips? I want to rebuild my ROM2 if possible...
thanks
myelin
Post by myelin » Thu Apr 25, 2019 6:10 am
Archived copies of roms often aren't in the same format as the chips. Usually they're just the rom image from memory, split into 1MB chunks. In your case to get the actual images for the two 2MB chips, you need to concatenate the four files and then split so that the 32-bit words are divided over the two chips.
i.e.
file 1 = byte 0, byte 1, byte 2, byte 3, ..., byte 1048575
file 2 = byte 1048576 ...
file 3 = byte 2097152 ...
file 4 = byte 3145728 ... byte 4194303
but:
chip 1 = byte 0, byte 1, byte 4, byte 5, byte 8, byte 9, ... byte 4194300, byte 4194301
chip 2 = byte 2, byte 3, byte 6, byte 7, byte 10, byte 11, ... byte 4194302, byte 4194303
keropi
Post by keropi » Thu Apr 25, 2019 12:43 pm
so basically you merge all files in one and then do a "Wordwise 16bit" split to LO and HI so you get 2x 2mbyte files ? No need to byteswap correct?
myelin
Post by myelin » Thu Apr 25, 2019 8:06 pm
Sounds right, yes. You'll have to check the circuit diagram for the machine you're burning the ROMs for, although I *think* bits 0-15 go in ROM 1 and 16-31 go in ROM 2.
When you download a ROM image, it'll be in little endian format, i.e.:
byte 0 = word 0 bits 0-7
byte 1 = word 0 bits 8-15
byte 2 = word 0 bits 16-23
byte 3 = word 0 bits 24-31
byte 4 = word 1 bits 0-7
byte 5 = word 2 bits 8-15
byte 6 = word 3 bits 16-23
byte 7 = word 4 bits 24-31
As long as your eprom programmer expects bytes in little endian format, you shouldn't need to do any byte swapping.
BBCNoob
Post by BBCNoob » Mon Jul 15, 2019 8:44 am
Does anyone have a little program that does such a thing?
I'm wanting to flash 3.11 on an A3010.
Going by viewtopic.php?t=14110, I've bought 2x 27C160-100. Since the A3010 take two chips. I've already got a eprom programmer and correct board, since I've already flashed Amiga A1200 chips before.
And going by where to get RiscOS 3.11 from - viewtopic.php?f=16&t=17390#p241081
Some help would go a long way! :)
Post by danielj » Mon Jul 15, 2019 8:52 am
I've not seen anything. Pick your preferred language and then:
open outputfile1;
open outputfile2;
open inputfile;
while inputfile.HasMoreBytes() {
    outputfile1.write(inputfile.read-2-bytes);
    outputfile2.write(inputfile.read-2-bytes);
close everything;
BBCNoob
Post by BBCNoob » Mon Jul 15, 2019 8:57 am
I'm not a coder so, sadly I don't have a language to pick from.
There also seems to be four files in question, not just two.
Post by danielj » Mon Jul 15, 2019 9:04 am
That bit is easy to deal with, you just concatenate the files. In windows, from the command prompt,
copy /b file1+file2+file3+file4 outputfile
Post by danielj » Mon Jul 15, 2019 9:07 am
There we go, google is your friend:
http://eab.abime.net/showthread.php?t=21599&page=14
"winhex, wordwise 16 bit split" - that's what you need to do to that concatenated file to give you the two files you need to burn.
BBCNoob
Post by BBCNoob » Mon Jul 15, 2019 9:47 am
Thank you - but WinHex costs £35, so it can output files larger than 200K. Not, really an option when I'm trying to do this upgrade cheaply.
Post by danielj » Mon Jul 15, 2019 10:10 am
Personally speaking, I'm very very happy to help someone who's trying to code something, but I'm not going to write the code for them unless it's something that I'm doing already (that'd cost £50/hour :D) :)
BBCNoob
Post by BBCNoob » Mon Jul 15, 2019 10:18 am
I can fully understand that - that's why I'm wondering if someone had a file kicking about that does it, because they've already done this project.
I'm not expecting someone to create a program especially for me.
Thank you for your help though.
I'll keep looking for something that'll do what I need. As you say, Google is my friend, I'm sure I'll end up finding something. :D
Post by danielj » Mon Jul 15, 2019 10:25 am
Use it as an opportunity to learn to code :)
This also looks like it *might* do the job - I have no idea how though: http://www.keil.com/support/docs/963.htm
philpem
Post by philpem » Mon Jul 15, 2019 10:50 am
You can use the "Srecord" tools (specifically srec_cat) to split wordwise images into bytewise ones and vice versa. There's an example in the manpage :)
Post by danielj » Mon Jul 15, 2019 2:25 pm
Perfict - that was what that other link I posted seemed to be talking about (not that I had a clue :D) :)
