Baildon Electronics ICS ideA A3000 board & CD Drives?
Joka80
Post by Joka80 » Sat Feb 02, 2019 12:17 am
Hello all!
I hope your all well and I have been reading quite a few threads relating to the Baildon Interface for the A3000. I just want to discuss a couple of things as I feel getting the thread started on expanding the interface would be good... :D
I have a Baildon Electronics ICS ideA A3000 mini podule currently in my A3000 and I think it's great! I remember it was around 1993 when I bought mine new whilst I was having computer lessons after school and my teacher persuaded my dad to buy one for my A3000 so it got sent off to have the upgrade fitted. About a week later it came back with the upgrade and a 340MB Connor hard drive which still works to this day!
Modernising it somewhat to use compact flash was quite easy, in-fact the interface seems to be so flexible with the card adapter and manufacturer of compact flash card. Even the ICS software recognises a range of cards and formats them with no problems. An A3000 with flash storage!
Now for my questions...
Presumably the port on the back, I could connect a CD-ROM drive and this acts as the 'slave' and the hard disk/flash card internally acts as the 'master' as when I tried a twin compact flash adapter on the internal interface it didn't like it. With a twin adapter it took ages to boot and kept saying hard drive failure or bad drive. But when I put a single compact flash interface, it works no problem...
I want to add an IDE CD/DVD drive at the back port, would that involve a simple firmware update or changing over the ROM underneath? In all honesty I haven’t even tried it to see if it works ok it’s current configuration as I don’t have a drive but if it did I would get one from eBay...IDE hard/optical drives nowadays command a high price but worth the coolness factor if it worked...
On the topside of the board it says:
A3000 IDE INTERFACE V5
(C) 1992
BAILDON ELECTRONICS
On the underside of the card on the ROM chip it says:
(C) 1993 ICS LTD
IDE3V5 3V06
Look forward to discussing this! :roll:
Re: Baildon Electronics ICS ideA A3000 board & CD Drives?
Post by steve3000 » Sat Feb 02, 2019 7:50 am
(C) 1993 ICS LTD
IDE3V5 3V06
A CD drive should work fine as slave, if your version of IDEFS includes CDFS driver software. And if not, it should just be a case of updating your IDEFS ROM with a later version of the ICS IDE software..they went up to 3V22 I think, which definitely included CDFS, and there is now the alternative ZIDEFS which is compatible with the interface, although I'm not sure it includes CDFS?
Post by IanS » Sat Feb 02, 2019 11:31 am
...and there is now the alternative ZIDEFS which is compatible with the interface, although I'm not sure it includes CDFS?
ZIDEFS is not compatible with any 8-bit ICS cards.
ZIDEFS does not support CDFS (afaik)
Post by steve3000 » Sat Feb 02, 2019 2:19 pm
Ah ok, only the 16bit ICS cards then...!
Joka80
Post by Joka80 » Sat Feb 02, 2019 3:15 pm
Was 3V22 the last version released for this interface? :roll:
Post by daveejhitchins » Sat Feb 02, 2019 7:28 pm
I’ll check what I have tomorrow - Won’t necessarilyy be the latest, though!
Joka80
Post by Joka80 » Sun Feb 03, 2019 10:34 am
Thank you Dave! :wink:
Post by daveejhitchins » Mon Feb 04, 2019 5:55 pm
Sorry for the delay . . .
The only ROMs I have seem to be (as written on the ROM label):
ARCIN.3 version: 1V5/3V13 (ICS 1995)
ARCIN.3 1V5a/3V15 (ICS 1995)
A3IN IDEFS 3V15 CDFS 2.V21/0.14 (BE 1996)
I may have other versions on Disc, however, that may take a while to sort out, as most of them have mould on their surfaces.
Joka80
Post by Joka80 » Sun Feb 10, 2019 11:10 am
No worries Dave!
I’m sorry for the subsequent late reply...was it possible to upgrade an earlier version ROM to say, for instance, the latest version produced? Presumably using !Snafu ?
:roll:
Post by daveejhitchins » Sun Feb 10, 2019 6:01 pm
IIRC the V5 IDE board did have a firmware update but it came with a revised PCB e.g. V5a. The only difference was pin 1 was given an address line instead of being tied to +5V. I did a conversion for someone, a few years ago. You just have to remove the ROM, isolate pin 1 then add a link. The details are on the forum somewhere.
