Which Raspberry Pi to purchase?
Square Mezzmer
Post by Square Mezzmer » Fri Aug 10, 2018 11:50 pm
I've been struggling with Acorn RISC PCs for a bit now (leaking battery, crashing hard drive) and think my excursion to RISC OS would be a lot simpler if I purchased a Raspberry Pi to install it on - with a comfortable installation I can finally start my project!
I'd puchase https://thepihut.com/products/raspberry ... del-b-plus though looking at the RISC OS Open site there were early internet connection issues with the Pi 3B+?
Is there a definitive model to get? Should I just go ahead?
Any other tips or essential advice is much appreciated!
Thanks.
Phlamethrower
Re: Which Raspberry Pi to purchase?
Post by Phlamethrower » Sat Aug 11, 2018 1:44 am
"were", past tense.
The 3B+ uses a new LAN chip, and we didn't have a driver for it until a few weeks after the 3B+ was released. Now that we have the driver, it should work just as reliably as any other Pi model.
sirbod
Post by sirbod » Sat Aug 11, 2018 7:35 am
As you're developing commercial software, I'd advice going with the latest Pi model as the CPU has more deprecations than most cores. ie If it runs on a Pi3, the code will at least be compatible with all other CPU's.
Square Mezzmer
Post by Square Mezzmer » Sat Aug 11, 2018 11:53 am
@Phlamethrower Ah, that's all good to hear.
@sirbod Thanks for the recommendation, I'll go ahead and purchase the Pi 3B+
scruss
Post by scruss » Sun Aug 12, 2018 3:31 am
Unless things have changed radically, RISC OS will only use one out of the 3B+'s cores.
