Help - Philips CM8833 fading in and out
Post by steve3000 » Fri Jun 29, 2018 10:10 pm
My trusty Philips CM8833 has developed an intermittent fault - the picture, which is pretty much perfect, randomly fades to black after using for a while (usually between about 20 minutes and an hour's use).
When the screen fades out, if I peak through the back grill of the monitor, I can see the orange light from the electron gun fades out in time with the picture. If I tap the monitor case, the picture sometimes fades back in briefly, but usually fades out again shortly after...
So loose connection or dry joint perhaps? Any likely places I should check first?
Re: Help - Philips CM8833 fading in and out
Post by 1024MAK » Fri Jun 29, 2018 10:52 pm
If the glow at the rear of the tube is going dim or out, that is the cathode heater. It is most likely a dry joint somewhere in the circuit.
Post by steve3000 » Tue Jul 03, 2018 5:13 pm
Hey, thanks Mark. I'm planning on taking a look this weekend, will have the soldering iron on standby :)
