A3000 IC3 chip
mattdy4
A3000 IC3 chip
Post by mattdy4 » Mon May 28, 2018 7:23 pm
Doing a repair on an A3000 and I need to replace IC3 which is a Fairchild Semi DM7438N. Not because this chip was hit by battery acid but I accidentally chopped it while I was desoldering the affected ROM sockets and IC4/IC5 (maybe it's the lead [-o< )
Anyway in the process of buying a new one and socketing it. There is a second number on the chip which doesn't turn up anything which seems quite common for this chip. Can I replace DM7438n with any part bearing that number or will that just not work?
TIA
Re: A3000 IC3 chip
Post by danielj » Mon May 28, 2018 7:27 pm
Second number will be a date code - this should do the job: https://www.ebay.co.uk/itm/401472004402
mattdy4
Re: A3000 IC3 chip
Post by mattdy4 » Mon May 28, 2018 7:30 pm
Thanks Daniel, I read it was a date code but wasn't sure if it made a difference to it's function. Does it go off? :lol:
Re: A3000 IC3 chip
Post by danielj » Mon May 28, 2018 8:08 pm
No, it just tells you when it was made :D - some batches get a reputation for being rubbish :)! Some ICs are quite collectable and early date codes are worth more. Clearly these don't fall into that category!
