bbc master 512 keyboard acting funny
avtovaz
Post by avtovaz » Wed May 09, 2018 1:08 pm
Just switched on the master for the first time in a while, and when i type bottom 2 rows of the keyboard dont do anything, and the top 3 rows sort of show the bottom two rows. So as in you may press 3 and you get an x...
Whats up with it? Is this common? thanks!
Re: bbc master 512 keyboard acting funny
Post by danielj » Wed May 09, 2018 2:54 pm
Start by unplugging it and cleaning the connectors on both ends! If it's still misbehaving it's time to start looking for broken things.
avtovaz
Post by avtovaz » Wed May 09, 2018 4:20 pm
ah i had taken off the conections to the board, didnt know the ones on the keyboard came off too, will take it apart and have a look!
thanks
Post by 1024MAK » Wed May 09, 2018 5:31 pm
Also check that both the connectors are correctly aligned.
avtovaz
Post by avtovaz » Fri May 11, 2018 9:35 pm
conections properly aligned, the ribon cable is soldered to the keyboard end, and all conections "look" good.
The only thing i havnt said is, ages ago, one or two of the keys where not working so i sprayed the lot with electrical cleaner... I wonder if that has done something?
Post by 1024MAK » Fri May 11, 2018 11:28 pm
avtovaz wrote: The only thing i havnt said is, ages ago, one or two of the keys where not working so i sprayed the lot with electrical cleaner... I wonder if that has done something?
Depends on the chemical makeup of the "electrical cleaner"...
Next, have a good look at the tracks on the keyboard PCB.
What test gear do you have?
avtovaz
Post by avtovaz » Sat May 12, 2018 5:19 pm
contact cleaner was DP-60, I have a fluke 116 multi meter, and a few other bits too, but not sure how to use them in this case really.
thanks for the reply.
avtovaz
Post by avtovaz » Sun Jun 10, 2018 9:08 pm
oh right, took it apart again, and noticed when id put the 2 ribbon conectors back on, id bent a pin, its all working again now except for the delete key... Ill sort that later... But ive found the problem atlast..
