RTFM Joystick interface
sirbod
Post by sirbod » Wed Mar 28, 2018 10:07 am
Does anyone have any documentation on how this interface works?
EDIT: I believe the interface came with a floppy, that contains an example program "ReadJoy" - that may contain the info, or the floppy may have some documentation on it.
EDIT2: I've been directed to www.retro-kit.co.uk which contains a copy of the floppy that came with the interface. Be aware that it contains the Extend virus - I've notified Paul.
EDIT3: I have now figured out how the interface works and have it working in the next release of ADFFS.
Re: RTFM Joystick interface
Post by DutchAcorn » Wed Mar 28, 2018 11:46 am
From the name of this interface it is indeed obvious that the manual is needed for using it. :D
cliffh
Post by cliffh » Fri Mar 30, 2018 8:45 am
I looked out the manual that came with my RTFM interface but it turned out to be a single information sheet with no technical details at all. I think it is not much use, but might have some curiosity value if you haven't already seen it:
RTFM.pdf
(187.86 KiB) Downloaded 21 times
