Using an FPA10 @ 33MHz
CJE-4D
Post by CJE-4D » Wed Feb 28, 2018 4:35 pm
I've an FPA10 that has come out of a 33MHz A5000. AIUI the FPA10 is rated for 26MHz use and the FPA 11 at 33MHz. I presume the A5000 will have been running it at 33MHz. Any suggestions for software to test the FPA10?
IIRC !Sick will confirm its presence.
Re: Using an FPA10 @ 33MHz
Post by crj » Wed Feb 28, 2018 5:53 pm
!Draw will give floating point a reasonable workout, and everyone has a copy. If things stay the same shape when you rotate them, floating point is working at least somewhat. (-8
sirbod
Post by sirbod » Wed Feb 28, 2018 5:58 pm
If it’s any use, I detailed all the games that use the FPA here
CJE-4D
Post by CJE-4D » Thu Mar 01, 2018 2:19 pm
Thanks for the suggestion and info. I've had more information from the previous owner that they are not sure if they ever actually used it! So I think 25MHz use is appropriate.
