HxC Firmware for Gotek
Jeff_HxC2001
Post by Jeff_HxC2001 » Sat Feb 24, 2018 1:53 pm
New firmware !
25 February 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.16.1a
- User interface part : Code Refactored
- Better buttons behavior.
- Better/faster rotary behavior.
- Normal mode : Press both buttons shortly to jump to the first entry of the current folder. ("..")
- Normal mode : When returning to parent folder ("..") the position in the folder is restored.
- Autoboot mode :
--> Press both buttons shortly to jump to Autoboot.hfe
--> Press both buttons more than 2 seconds eject/insert the disk.
- Indexed mode :
--> Press both buttons shortly to jump to DSKA0000.HFE
- 7 segments screen : Now show when an image is inserted ("---") or ejected (" - ")
- OLED : init algorithm revised for diymore.cc screens.
(Press the right button at power up at the first diymore.cc screen installation).
- Various user interface fixes.
If you have any comments or suggestions, requests or issue to report please contact me :
Email : hxc2001 <at> hxc2001.com
Forum : http://torlus.com/floppy/forum
Facebook : https://www.facebook.com/groups/hxc2001
http://hxc2001.com/download/floppy_driv ... rmware.zip
http://hxc2001.com/download/floppy_driv ... _notes.txt
Last edited by Jeff_HxC2001 on Tue Feb 27, 2018 10:42 am, edited 3 times in total.
KenLowe
Re: Open source firmware for Gotek floppy emulator released
Post by KenLowe » Sat Feb 24, 2018 3:27 pm
Jeff_HxC2001 wrote:Someone want to test it with HxC Firmware ? I can provide you a firmware license for free if you want. :)
Happy to test for you, but I won't be able to test until later tomorrow.
Jeff_HxC2001
Post by Jeff_HxC2001 » Mon Feb 26, 2018 6:33 am
HxC Firmware for Gotek user Manual :
http://torlus.com/floppy/forum/viewtopi ... =33&t=1683
Last edited by Jeff_HxC2001 on Tue Feb 27, 2018 10:46 am, edited 2 times in total.
KenLowe
Post by KenLowe » Mon Feb 26, 2018 9:33 am
I've got a few GoTek drives, and currently have FlashFloppy firmware installed on them all. I don't have the HxC firmware, but would plan to install on one drive to help with testing.
Jeff_HxC2001
Re: HxC Firmware for Gotek
Post by Jeff_HxC2001 » Tue Feb 27, 2018 10:51 am
Citadel on BBC Master loading through Gotek HXC :
https://www.youtube.com/watch?v=wwRxUA1mD20
Post by danielj » Tue Feb 27, 2018 10:57 am
I'm not quite sure why the original content of the posts I split out has been edited, but just to note that it has.
Jeff_HxC2001
Post by Jeff_HxC2001 » Tue Feb 27, 2018 12:14 pm
Sure they was edited. These messages became meaningless/off-topic since they have been moved out from their original thread.
(I couldn't delete them...)
Jeff_HxC2001
Post by Jeff_HxC2001 » Mon Mar 12, 2018 6:38 am
Et hop la ! :)
11 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.18.1a
- End part of the read output pipeline reworked (pulses generator).
- Akai S20 IMG images : sectors gap and tracks skew aligned to the real machine.
- Casio FZ1 IMG images : sectors gap and tracks skew aligned to the real machine.
4 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.16.3a
- Fix last the v3.1.16.2a compilation option !
Please update if you have the v3.1.16.2a released yesterday !
3 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.16.2a
- Autoboot mode + 3 Digits Gotek screen : Fix slot number.
Jeff_HxC2001
Post by Jeff_HxC2001 » Mon Apr 02, 2018 1:05 pm
turlututu chapeau pointu ! :D
Jeff_HxC2001 wrote: 15 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.18.1a
- Normal mode : Remove unwanted key delay when entering in direct mode.
17 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.20.1a
- USB Direct Access mode code refactored :
- Read/write performance increased (hxcmount).
- Command/Write indications printed on the LCD.
- USB access cache : Write timeout value set to 2 seconds.
18 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.21.1a
- Indexed mode : Ignore file extension. You can now use any file extension
as long as the file is supported by the floppy emulation engine.
(Can be DSKA0000.HFE/IMG/DSK/ADF/ADL...)
- Acorn machines (*.ADL, *.ADM, *.ADF):
Sectors gap, interleave and tracks skew aligned to the real machine.
19 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.21.2a
- USB Direct Access mode code : Index gap increased
(Amiga File selector & HxC copy utility under WB fix)
1 April 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.22.1a
- TI99/4A : Direct support of *.DSK/*.PC99/*.V9T9 sectors dump images
SD/DD/HD density support (Read & Write).
- New embedded menu entry : You can now force the user interface mode
(Normal/Indexed or selector mode selection).
Jeff_HxC2001
Post by Jeff_HxC2001 » Sat Apr 28, 2018 6:55 am
Some updates ! :
3 April 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.22.2a
- TI99/4A : V9T9/DSK Loader -> Better disk layout detection.
19 April 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.22.3a
- OLED screen setting sanity check : Do not allow more than 21 characters per line.
26 April 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.22.4a
- 2 Digits screen Gotek : Fix embedded config menu.
28 April 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.22.6a
- HFE files : Fix MPC60 MkII formatted images write support regression.
May also fix possible write issues on HFE files with some others machines/disk formats.
Update recommended.
