RPC700 CMOS issue
SimonWKing
RPC700 CMOS issue
Post by SimonWKing » Sat Feb 10, 2018 6:44 pm
I recently acquired a RPC700 which had the usual leaky battery, although it didnt look to bad. I removed the old battery, cleaned it up and replace with a new one from RS components - However I am still getting the red screen and floppy code 00010018. Holding Del or R does reset CMOS and it boots OK but I still have to do this every time.
Anyone had the same issue and managed to fix?
How I shaped pins to install
Old Battery
New Battery
Re: RPC700 CMOS issue
Post by danielj » Sat Feb 10, 2018 6:52 pm
Hi there :) - first thing's first. When you cleaned the motherboard, did you do so with distilled vinegar where the battery had leaked? It looks rather grubby, it really needs cleaning up more :?. I suspect the cmos circuit is knackered, but you'll need to get it all neutralised and cleaned up before we can start looking at that bit.
For neutralising the battery goo, first take the new battery off, then use white malt vinegar and an old toothbrush. It'll fizz. Keep going until the fizzing stops and all the green is gone. Wash it well with distilled water (or tap water if you live somewhere with soft water) and leave it to dry somewhere warm for a couple of days.. Do you have access to a multimeter?
SimonWKing
Post by SimonWKing » Sun Feb 11, 2018 1:45 pm
I did wash down with water and used a small paintbrush to work it in but will get some vinegar and try that, thanks.
Post by danielj » Sun Feb 11, 2018 2:33 pm
Plan. Basically if you don't neutralise it, it will keep eating away, water just doesn't cut it on its own.
