Acorn Ethernet 3 podule EPROM and RISCiX
SteveBagley
Post by SteveBagley » Thu Dec 28, 2017 1:11 pm
Does anyone know what type of EPROM was used in the Acorn/Atomwide Ethernet III podule?
I have one I’m trying to get working under RISCiX (on a heavily expanded A305 no less! :-)) but unfortunately the on-board EPROM is from 1998 and so crashes RISC OS 2 at boot when the modules (MBufManager I think) try to initialise. RISCiX doesn’t recognise it either — which I suspect is again because the ROM is too new.
I want to burn an earlier version of the ROM to see if that works any better but I’m not sure which EPROM the card uses — anyone any idea?
Steve
Re: Acorn Ethernet 3 podule EPROM and RISCiX
Post by IanS » Thu Dec 28, 2017 2:57 pm
It varies, I have boards with 27c020 and 27c1001, it will depend on the link settings.
LK2 - pin 1
LK3 - pin 31
LK4 - pin 30
pin 3 of each link (2,3,4) goes to +5, the middle pin goes to each pin on the rom as listed above. and pin 1 comes from the page latch U14, pins 12, 9 and 15 respectively.
crj
Post by crj » Thu Dec 28, 2017 3:47 pm
I don't believe RISCiX worked (at least, not without some tweaks by Brian Brunswick that I'm not sure ever saw the light of day) with any Ethernet podules other than EtherH and EtherB. And those didn't need a ROM in for RISCiX to recognise them and work with them.
Post by RobC » Thu Dec 28, 2017 5:23 pm
crj wrote:I don't believe RISCiX worked (at least, not without some tweaks by Brian Brunswick that I'm not sure ever saw the light of day) with any Ethernet podules other than EtherH and EtherB. And those didn't need a ROM in for RISCiX to recognise them and work with them.
I have one of these in my R260 and it's definitely recognised by RISCiX:
http://chrisacorns.computinghistory.org ... ernet.html
I can image the ROM if it would help but I've not tested it under RO2.
flibble
Post by flibble » Thu Dec 28, 2017 5:52 pm
I think you mean Ether1 and Ether2, H and B are much later podules that use ROMs.
SteveBagley
Post by SteveBagley » Thu Dec 28, 2017 5:56 pm
RobC wrote:I have one of these in my R260 and it's definitely recognised by RISCiX:
That’s good to hear… I think the problem I’m having is the memory crash leaving the podule paving register in a state so that RISCiX just doesn’t recognise that the podule is present (it doesn’t always register in *podules either after the crash).
That’d be great if you could…
Steve
sirbod
Post by sirbod » Fri Dec 29, 2017 9:10 am
Have you tried unplugging the MBufManager Module, so it's not initialised at power on?
Some of the network modules require an updated CLib, although from memory I don't think MBufManager is one of them...might be wrong though.
Post by RobC » Fri Dec 29, 2017 3:16 pm
Here's the ROM image from my Ethernet III podule. The EPROM was an ST M27C1001.
It's dated from 1992 so I guess there's a good chance it'll work with RO2 as I'm pretty sure I got hold of my first RO3 ROMs in late 92...
ether3.zip
(47.37 KiB) Downloaded 34 times
SteveBagley
Post by SteveBagley » Fri Dec 29, 2017 7:41 pm
RobC wrote:Here's the ROM image from my Ethernet III podule. The EPROM was an ST M27C1001.
Many thanks, I’ll give it a whirl and see what happens…
Steve
SteveBagley
Post by SteveBagley » Wed Mar 04, 2020 2:42 pm
Over two years later, and I've finally got this working by burning RobC's ROM image and installing it into the Ether3. Well, I only burnt the first 32K since I only had 32K ROMs to hand but that seems to have worked. I also think I've sussed the reason it wasn't being recognised before. The podule header in the ROM I had identified itself as an ANT podule, rather than an Atomwide podule (as found in RobC's image).
I'll probably leave it with the 32K ROM in place for now since if I ever use it in RISC OS I'll be loading new modules anyway…
Steve
