Vectorlight's A3010 IDE mod : step by step guide
Andy1979
Re: Vectorlight's A3010 IDE mod : step by step guide
Post by Andy1979 » Mon Aug 21, 2017 1:22 pm
=D> =D> =D> =D> =D>
Most impressive work. That's a seriously hardcore mod with all those tiny wires. Great result.
vectorlight
Post by vectorlight » Sat Mar 24, 2018 7:59 pm
I'm having a clearout and have 4 of these boards left, 1 of them is mostly populated but not tested. If anyone wants one send me a PM. Sorry I can only post to the UK. :D
number-one
Post by number-one » Mon Apr 02, 2018 9:02 am
Hello Vectorlight congratulations for your website.
I am not authorised to compose private message for now.
I want to buy one of your A3010 IDE interface.
You can reach me on alouest AT gmail DOT com.
A3010 4 MB Ram
vectorlight
Post by vectorlight » Mon Apr 02, 2018 7:09 pm
number-one wrote:Hello Vectorlight congratulations for your website.
Sure, I will try to email you now. All I ask is you cover the postage (£1). :D
trixster
Post by trixster » Tue Apr 03, 2018 5:04 pm
Hi Vectorlight!
I don't suppose you have an IDE boards left do you? I'd love to get hold of one.
Thanks,
Andy
vectorlight
Post by vectorlight » Wed Apr 11, 2018 7:17 am
trixster wrote:Hi Vectorlight!
Thanks,
Andy
Sorry these are now all gone.
trixster
Post by trixster » Wed Apr 11, 2018 11:37 am
No problemo! :)
number-one
Post by number-one » Sun Apr 22, 2018 8:41 am
Have you a list of know working compact flash / sd card readers and cards with the IDE Mod ?
A3010 4 MB Ram
vectorlight
Post by vectorlight » Sat May 19, 2018 5:13 pm
number-one wrote:Have you a list of know working compact flash / sd card readers and cards with the IDE Mod ?
I tend to stick to 512mb sandisk cards. They usually work, though not all of them I'm afraid.
vectorlight
Post by vectorlight » Sat May 19, 2018 5:22 pm
I haven't done much on my Acorns for a while so yesterday I thought I'd try to apply this IDE modification to an Adelaide machine:
Making it fit with the ARM3 upgrade was a challenge due to the ARM3 board overhanging so much. The IDE mod PCB just about fits, as in it is right up against the Adelaide board. If I were to redo this board I'd move some of the components over to the right-side and reduce the left side a bit.
Other than physically making it fit, when completed if works identically to an ARM250 machine which I'm happy with :D
This must now be one of the most modded A3010s around :D : ARM3 overclocked to 45mhz, 50ns RAM overclocked to 22mhz and now twin IDE drives :D
This was the last IDE board I've got, hope everyone out there with one of them managed to get it working :?:
Post by steve3000 » Sat May 19, 2018 6:56 pm
vectorlight wrote:This was the last IDE board I've got, hope everyone out there with one of them managed to get it working :?:
Great to see you've got it into your expanded Adelaide A3010, what a machine that must be!
Interesting to see also because you have a very low lying Adelaide board, mine is on much higher legs, so my Adelaide PCB sits just below my expansion card PCB (probably about where your Arm3 PCB sits). Even so, I've test fitted your IDE board, and all looks good for the board, but the IDE cable might be a squeeze... I just have to get my computer working now before I can test further, as the battery damage is extensive.
Andy1979
Post by Andy1979 » Sun May 20, 2018 10:05 am
vectorlight wrote: This must now be one of the most modded A3010s around :D : ARM3 overclocked to 45mhz, 50ns RAM overclocked to 22mhz and now twin IDE drives :D
Seriously impressive work - I'm not brave enough to do that to mine! (or good enough at fine soldering) =D>
In terms of further expansion, the only thing the A3010 is missing is the onboard network upgrade connection. Are any of those signals accessible in a similar fashion?
I have one of the Bush Internet boxes, and the way you've used the ROM sockets as a carrier for the board makes me wonder if something similar might be possible for that - effectively turning it into an A7000 class machine? That said, the limited nature of the onboard ROMS would most likely be a problem, and since it's already possible to boot one from a parallel ZIP drive there's not really much point.
number-one
Post by number-one » Sat Jul 21, 2018 8:01 am
Hello I have the regular 1,6 MB floppy drive 0 and a HX Floppy Emulator drive 1 working fine with the lcww1 cable
At the NASS french commodore amiga party my friend Benoit installed the vectorlight ide mod on my A3010.
After the installation
-The floppy drives 0 and 1 where gone on the desk
-Accessing The IDEDDisc 4 on the vectorlight pcb show an error (compact flash taken from working A30x0 IDE Iss 2 mini podule)
What are wrong ?
A3010 4 MB Ram
number-one
Post by number-one » Mon Jul 23, 2018 2:46 pm
A3010 4 MB Ram
Post by danielj » Mon Jul 23, 2018 4:58 pm
OK - first thing first. Let's find out where your floppy drive has gone!
Have you reset the CMOS since doing the mod?
What's displayed next to Floppies if you type *STATUS? What happens if you type *CONFIGURE FLOPPIES 1 with just the internal floppy drive connected?
(the second error is because ADFS doesn't get on very well with lots of compact flash cards, but we'll get on to that - the fact it worked on an IDE podule doesn't mean it'll work with the internal IDE interface)...
This is quite a fiddly mod, so the other thing you want to be sure of is that no connections got bridged on the SuperIO IC (the one that says CHIPS on it)....
number-one
Post by number-one » Wed Jul 25, 2018 1:23 pm
Yes
I have put the single floppy cable with the HXC (jumpers configuration as for one drive know working)
I have put the network card mini podule
The drive 0 re-appeared but not working
Several times on boot the archie doesn't show image on the Monitor BenQ BL912 or doesn't show floppy drive.
Pictures accessing floppy on the HXC SD Card
A3010 4 MB Ram
number-one
Post by number-one » Wed Jul 25, 2018 1:29 pm
What do you means ?
A3010 4 MB Ram
Post by danielj » Wed Jul 25, 2018 8:45 pm
OK - take the network podule out. You need to start from a minimal system -> is it possible to just attach the original floppy drive, nothing else, no minipodule, no CF card, and reboot holding down delete?
If that doesn't work, the next steps are to check 1) that the connections to the floppy connector are still OK, and 2) that the IDE mod has been done properly without any short circuits. That's rather hard to do from a distance but we'll see what we can work out...
alienkidmj12
Post by alienkidmj12 » Sat Jul 28, 2018 11:50 pm
how much are the bare boards ?
Post by danielj » Sun Jul 29, 2018 5:35 am
They weren't a for sale thing, and there unfortunately aren't any left AFAIK (read this page of the thread from the top).
