Today I overclocked my A3010
Re: Today I overclocked my A3010
Post by danielj » Sat Feb 03, 2018 6:51 pm
Here we go! :)
It's got a dirty big "FRONT" on it now :) I'll ping an order at JLC and we'll see if we get something functional back!
oakramv2.zip
(482.46 KiB) Downloaded 77 times
Post by RobC » Sat Feb 03, 2018 8:24 pm
This is great - thanks again for doing this. I'll definitely be interested in a couple of boards (populated or unpopulated) though I've only managed to get one A3010 working thus far.
Post by danielj » Sat Feb 03, 2018 8:28 pm
I didn't cough for DHL, so they'll be a couple of weeks or more. Will let you know when they appear! :)
Edit: progress!
AndyMc1280
Post by AndyMc1280 » Sun Feb 04, 2018 10:28 pm
ooo .... new 4mb boards ?
Please may I have one ? I was on a list..... somewhere. [-o<
Post by danielj » Sun Feb 04, 2018 10:47 pm
Let's see if they work first! :D
AndyMc1280
Post by AndyMc1280 » Sun Feb 04, 2018 10:51 pm
danielj wrote:Let's see if they work first! :D
Mores the point I need to get the A3010 working again... RO3.1 Roms bought so....
Geezerdiamond
Post by Geezerdiamond » Sun Apr 01, 2018 3:37 pm
Hey there!
Just wondering how this project is going? Did the boards work?
Would love to get my mitts on one.
M
danielj wrote:I didn't cough for DHL, so they'll be a couple of weeks or more. Will let you know when they appear! :)
Edit: progress!
Post by RobC » Sun Apr 01, 2018 3:46 pm
Geezerdiamond wrote:Just wondering how this project is going? Did the boards work?
I'm going to make mine up in the next day or so and will report back.
Post by danielj » Sun Apr 01, 2018 3:58 pm
I've got the boards, but still waiting on good RAM!
Post by RobC » Sun Apr 01, 2018 4:34 pm
Spurred on by this, I've just made mine up and it all seems to be working :D
Haven't tried overclocking it yet as I'm just using some 60nS RAM I'd previously salvaged from a RiscPC SIMM.
Many thanks to Daniel for getting the boards made up =D> =D> .
Post by danielj » Sun Apr 01, 2018 4:36 pm
Weee! Great news!
Geezerdiamond
Post by Geezerdiamond » Mon Apr 02, 2018 12:09 am
Well that's great news! :D
Is your intention to sell fully populated boards or can they be bought bare to be built up (or maybe as a full kit)?
Great work by the way!
Post by danielj » Mon Apr 02, 2018 7:51 am
No, I don't have any particular urge to go making boards/kits (the beebscsi effort is me done for a fair while!) - but the designs are in this thread, so anyone can produce them. 10 pcbs from a Chinese fab will be around £1/each or less. You should be able to produce boards for around £10-15 each at cost, unlike the £90 you'd have to pay elsewhere...
Geezerdiamond
Post by Geezerdiamond » Mon Apr 02, 2018 8:40 pm
Ah I see, fab!
I'll go back through the thread and see what's needed.
Cheers!
Post by danielj » Thu Apr 05, 2018 10:35 am
Just tested mine, all good. :) I've got a little bit more RAM, I'll probably make up what I can after these beebscsis. Just to note, soldering SOJs is a bit of a pain as there's not much space. Paste + hot air is probably the way forward on these ones.
marcusjambler
Post by marcusjambler » Thu Apr 05, 2018 11:39 am
Hi Daniel
I'll take a pcb if there are any left.
Marcus
Post by danielj » Thu Apr 05, 2018 1:12 pm
OK - I'll actually scope it out properly after the beebscsis - they're quite a bit of work, and I've got quite a bit on at the moment.
Geezerdiamond
Post by Geezerdiamond » Thu Apr 05, 2018 2:43 pm
I replied to your DM earlier. Hadn't noticed it the other day when you sent it! :D
danielj wrote:OK - I'll actually scope it out properly after the beebscsis - they're quite a bit of work, and I've got quite a bit on at the moment.
Post by danielj » Sun Apr 29, 2018 8:43 pm
I've just updated the A3010 board layout somewhat. It's now 4 layer (in theory should be better when run faster) and I've routed the power in a more appropriate fashion.
See attached zip!
oakramv3.zip
(528.17 KiB) Downloaded 68 times
Geezerdiamond
Post by Geezerdiamond » Mon Apr 30, 2018 9:04 am
Awesome stuff =D>
danielj wrote:I've just updated the A3010 board layout somewhat. It's now 4 layer (in theory should be better when run faster) and I've routed the power in a more appropriate fashion.
See attached zip!
tnt23
Post by tnt23 » Tue May 01, 2018 9:45 am
Hi Daniel, looks good :) You might rotate the credentials too so that they appear in sync with that lovely FRONT label :)
See attached zip!
Regards, Tim
Post by danielj » Tue May 01, 2018 11:29 am
Good plan :)
myelin
Post by myelin » Sat May 18, 2019 7:55 am
Daniel — have you tried out the 4 layer version?
I think I just accidentally ordered a set of the second to last 2 layer version (I was in a hurry...), without the “front” label. Is that version electrically equivalent to the one with the label, or were there copper changes too?
I cloned Tim’s github repo and have added all your zip files, and built the gerbers using my usual scripts — https://github.com/myelin/oakram — so I don’t make that mistake again!
Post by danielj » Sat May 18, 2019 8:00 am
No, but it's a better layout. I'd learnt a bit more by the time I'd done it. The 2-layer works fine at normal speeds, not sure how it'd be at high speed!
myelin
Post by myelin » Sat May 18, 2019 2:21 pm
I'm not too worried about high speeds right now... just doing a big order of PCBs and threw in a set of these so I can make one for a local friend who just acquired an very clean A3010, so the 2-layer version is just fine :)
What kind of headers go in the ZIP sockets, btw? I see the drill holes are 1mm / .039" diameter, which is about right for standard 0.1" pin headers... or did you use the smaller turned-pin headers that can fit into IC sockets?
Post by danielj » Sat May 18, 2019 2:58 pm
Turned pin. :) I lined them up in the actual zip sockets before soldering.
D
myelin
Post by myelin » Sat May 18, 2019 4:29 pm
Excellent :) I could help but jump in and start making some tweaks -- all files here: https://github.com/myelin/oakram/tree/m ... perimental
Post by danielj » Sat May 18, 2019 5:52 pm
Tweak away! :D
iainjh
Post by iainjh » Tue May 28, 2019 10:51 pm
I'm about to order a couple boards and will likely ask Bas the corfiot to make a few up with faster rams.
please could someone point me to the exact post with the BOM/parts I need collate?
Daniel could you please check your PM's? :) I was about to order some of your last 4-layer design (if thats OK?) and wanted to confirm what ram I need order and the other components. Some of the faster ram might take a while to arrive from china!
TIA guys
iain
Post by danielj » Tue May 28, 2019 11:32 pm
The 4 layer design is untested, so seriously proceed at own risk. If you load the design into kicad it should say what the values of everything is? I think there's a 47uF electrolytic and the rest are 100nF caps. Ram is all discussed at the start of this thread? I've never tried it before so I can't recommend a part number myself unfortunately.
