A4000 PSU go pop : replacement fix
IanJeffray
Post by IanJeffray »
A4000. "No power". Sure enough, no power. Open the PSU. Measure the fuse - open. Replace the fuse. Power up. BBAAANNGGG!! And a pretty green flash too. And my new glass fuse now has little metal balls in it. Yay.
Hmm ok that's a shame. Now I have to really try and fix it.
Those don't look good. Pulled them out. I think the brown stuff may be intentional, but may have helped rot/rust/something at the bottom there. Red Red Red. A pair of 2K2 ? Really? What kinda rating? They both measure the same 32,8K ... Ah it'll be orange orange orange then. 33K. Ok, so these are still fine?
But also...
pretty sure that hole's not supposed to be there. Pull it. Reads 8 ohms. Not sure if that's as it should be or not.
Tempted to cut my losses and see if I can wedge another of those nice Meanwell boards in here. I don't like dealing with power electronics. :(
Re: A4000 PSU go pop
Post by danielj »
Meanwell ftw.
cheshirenoir
Post by cheshirenoir »
I'd try and replace the component.
(if it was me, that'd fail and THEN I'd get a Meanwell :-)
Chesh
I like 8 bits, and I cannot lie
https://ilike8bits.wordpress.com/
Post by flaxcottage »
CJE Micros sell reconditioned A4000 PSUs. When mine went they even had a BNIB one for a very reasonable price.
I know this sounds like an advert but I am in no way affiliated with CJE. :lol:
IanJeffray
flaxcottage wrote:
Thu Sep 23, 2021 9:57 am
£50 new or £45 for used. Vs £25 for the meanwell and some fun making it fit. I already ordered the meanwell ;)
Post by daveejhitchins »
IanJeffray wrote:
Thu Sep 23, 2021 10:56 am
Please don't "dump" the real one [-o<
Dave H.
IanJeffray
daveejhitchins wrote:
Thu Sep 23, 2021 12:24 pm
Well the PCB is free to anyone who'd like it... but I don't think it's much use. THe new board will have to be wedged in the existing PSU enclosure, for its rear sockets at least -- I'm hopeful it'll be impossible to tell there's a replacement in there once I'm done :)
Better than my current situation of hanging an old PC AT PSU out of the podule slot anyway :lol:
IanJeffray
Meanwell supply arrived. I always forget how diddy these things are. Sat next to the original A4000 board for reference...
Fits in the case no worries at all of course. Should easily mount with new pillars through the base.
I expect the most annoying part will be connecting the ludicrously thick 14AWG original HD and motherboard cables to the output header.
philpem
Post by philpem »
IanJeffray wrote:
Wed Sep 22, 2021 10:25 pm
But also...
Based on the shape and the PCB markings, that's either a MOV (metal oxide varistor) being used as a surge suppressor, or a thermistor being used as an inrush limiter. Both are known to fail shorted on occasion.
If you're also getting 8 Ohms between live and neutral, it's an MOV. The power supply will work without it, but with reduced surge suppression capability.
They're replaceable and cheap - certainly one of the cheapest PSU repairs going. That said, a shiny new Meanwell will be far more efficient and probably more reliable in the long run!
IanJeffray
Re: A4000 PSU go pop : replacement fix
Mounted the new board on one of the existing pillars, using the board itself as a template for positioning the holes on the underside of the PSU case, drilling through and adding new pillars. Gel superglue as threadlock on the nuts.
The hardest part by far was sorting the cables in to the JST connectors. I soldered the switch cable directly to the input socket, but had to jam the loop-through connector in to the power-input socket on the board (output from the switch). Crimp ring connector for the GND cable.
And then had to grapple with the fankly ridiculous 14AWG mainboard and drive cables, putting pairs in to crimps for all bar one of the 5v, and the -12v. Not easy at all - so stripped back the insulation much further than usual, then applied heatshrink round the combined wires. The wires are also horribly thick even to bend so quickly to escape the PSU box. Happy that these are properly socketed now, but I can see why the original board just used crude wires soldered direclty in to the board.
All running just fine and nobody would have a clue unless you open the PSU cage. Sorted.
a1exh
Post by a1exh »
Looks very good. As always :-)
Principal ASIC Engineer
RetroGeek
Acorn Electron + A5000
http://thalion.atari.org
