viewtopic.php?p=302377#p302377BeebMaster wrote: ↑Sat Jan 09, 2021 1:26 pm..so it would have to be made into a self-extracting archive. How do I do that?
A5000 HDD preparation
Re: A5000 HDD preparation
Almost...HForm failed: Disc error 23 at :4/0F598000 at line 3210
Were my options incorrect?
Mainly looks ok, No need to Format, Initialise should be enough. I probably wouldn't use Verify (not until I was happy the card would work)
I haven't had much luck with Transend devices, and Acorn IDE interfaces are very picky about the cards they work with.
Have you got any other CF cards you can try?
I do have 2 more cards, both S4GB SanDisk - which I assume will not work?
- IanJeffray
Did you mean 4GB? It's worth a shot. My preferred CF for RISC OS 3.1 machines and ADFS is a 512MB Transcend. 512MB "blue" SanDIsc cards also work fine but have proven slower in use (surprisingly!).
I use 4GB "CloudDisc" cards on machines that I can run Wizzo on (A4, A30x0) - complete reliability in my experience.
I meant 4GB.
I tried and received the message that it was greater than 512MB and wouldn't work.
There are quite a few default settings when performing the format:
Sectors per track: 63
Heads: 16
Cylinders: 1006
Drive parameter init flag: 1
Drive lba flag: 1
Parking cylinder: 1005
No more changes to defect list
Large file allocation unit: 1024
Could some of these settings be incorrect for the card?
Heads: 16
Cylinders: 1006
Drive lba flag: 1
Self extracting version.BeebMaster wrote: ↑Sat Jan 09, 2021 1:15 pmHere's HForm 2.19 I just found on my A4000, this is a Sparkplug archive so it should open on the A5000 but may need the file type setting to &DDC.
- Attachments
- hform219.zip
- (18.98 KiB) Downloaded 4 times
Should I give this a try and if so, do I copy the entire file onto a floppy disk and launch from the A5000?
- BeebMaster
Thank you, having a play now. Very useful.IanS wrote: ↑Sat Jan 09, 2021 1:28 pmviewtopic.php?p=302377#p302377BeebMaster wrote: ↑Sat Jan 09, 2021 1:26 pm..so it would have to be made into a self-extracting archive. How do I do that?
- IanJeffray
Well well -- this is great. I'd always been meaning to look in to why HForm 2.19 craps itself when presented with large drives, but never got to it. This HForm 2.48 does run on RISC OS 3.1 and does cope with finding huge disks connected. I've been able to successfully format and use an old 60GB SATA SSD (!) with a £3 eBay-source IDE to SATA adaptor in an A4000. Fantastic. Ridiculous, but fantastic.
It worked!
I bought a 512MB SanDisk CF, followed the same process and it worked straight away!
That sounds like you need to patch ADFS
You folk might want to keep an eye on my Partition Manager threads on ROOL and JASPP as it will replace HForm.
It's in early development, although I aim to start implementing full disc FileCore formatting soon.
