using iomega jaz on a3000
soviet
Post by soviet » Fri Oct 16, 2020 8:05 pm
Hi!, is possible to use the parallel port version of the iomega JAZ drive on the A3000 ?.
IanJeffray
Re: using iomega jaz on a3000
Post by IanJeffray » Fri Oct 16, 2020 8:13 pm
Sadly not, you need a bi-directional parallel port. A3010, A3020, A4000, A5000, A4, A7000, RiscPC.
kppot
Post by kppot » Sat Oct 17, 2020 7:06 pm
That was the reason I actually upgraded form 3000 to 3020
soviet
Post by soviet » Sat Oct 17, 2020 11:32 pm
So i suppose the zip drive also will not work :(
IanJeffray
Post by IanJeffray » Sun Oct 18, 2020 2:01 am
That's right. Actually I misread "jaz" as "zip" originally. I'd never heard of a parallel jaz drive before - zip is far more commonplace with Acorn kit.
soviet
Post by soviet » Sun Oct 18, 2020 9:44 pm
I know is no the title of thread but i have also this scsi podule.
Can be used on the a3000 ? seem to fit on the expansion port.
IanJeffray
Post by IanJeffray » Sun Oct 18, 2020 10:22 pm
Yes. You can even get metal enclosures to suit holding a podule in the rear socket permanently.
CJE have a manky one for sale just now ... https://www.ebay.co.uk/itm/Acorn-A3000- ... 4127692704
