MDF for Samsung SyncMaster S24B150 LED monitor
Daveo
Post by Daveo » Mon May 11, 2020 6:31 pm
Hi.
I need a monitor definition file for my Samsung SyncMaster S24B150 LED monitor (see here for specs).
Currently have it configured using the following:
Monitor: Vision Master Pro 450
Res: 1024x768
Colours: 256
Ideally, I would like 1600x900 or 1280x720.
I currently have 1MB VRAM, but have purchased a 2MB VRAM chip, which I'm awaiting delivery of.
- Dave
RiscPC 700 - StrongARM 233MHz, 96MB RAM, 2MB VRAM & 20GB Hard Disc. RiscOS 4.39.
Raspberry Pi 3 Model B - ARM Cortex-A53 1.2GHz (Quad Core), 1GB RAM & 32GB MicroSD. RiscOS 5.27.
acorndave
Re: MDF for Samsung SyncMaster S24B150 LED monitor
Post by acorndave » Mon May 11, 2020 11:05 pm
I have a similar spec monitor its a Hanns rather than Samsung. I run it at 1920 x1080.
You're welcome to try the attached - at your own risk of course !
It would certainly be a good starting point, if you have makemodes or similar to tweak it further. It may just be ok.
It has your preferred defs in also. Although when I tried those on my screen they didn't fill the screen area.
Remove the .txt extension to use (couldn't upload without an extension).
HL274HPB.txt
(14.15 KiB) Downloaded 12 times
Daveo
Post by Daveo » Tue May 12, 2020 1:36 am
Many thanks. Will try that.
With makemodes, where would that be if it's installed (Risc PC 700 running Risc OS 4.39)?
- Dave
Daveo
Post by Daveo » Tue May 12, 2020 3:15 am
Tried file but it made monitor go funny and had to reboot with num pad * so that I could switch monitor back to previous setting.
Think it maybe timings or something, but don't have makemodes to do this myself.
- Dave
helpful
Post by helpful » Tue May 12, 2020 11:59 am
One thing to note while testing monitor settings is that you can simply drag and drop a definitions file into the display manager icon to load it. That way if it all goes wrong a quick reboot will return to your configured monitor settings.
Alternatively, typing blind, press F12 then enter Wimpmode 32
Bryan.
acorndave
Post by acorndave » Tue May 12, 2020 3:19 pm
Theres makemodes to download here. Not sure if it's suitable for RO4.39
viewtopic.php?t=8407
Also another one here
http://www.cjemicros.co.uk/micros/resources/index.shtml
acorndave
Post by acorndave » Tue May 12, 2020 3:24 pm
Daveo
Post by Daveo » Mon May 18, 2020 7:08 pm
Not had much luck with MakeModes even with the instructions.
I've found this model (for Samsung SyncMaster C23A550U), which works in 1920x1080 256 colours, but only has just this resolution.
# Modefile created by John Rickman using !MakeModes version 0.27a (8 Nov 2006)
# Monitor - Samsung SyncMaster model C23A550U Hub monitor
file_format:1
monitor_title:Samsung C23A550U
DPMS_state:3
# 1920 x 1080 (50Hz)
startmode
mode_name:1920 x 1080
x_res:1920
y_res:1080
pixel_rate:148000
h_timings:80,204,0,1920,176,264
v_timings:0,26,8,1080,0,3
sync_pol:1
endmode
# End
Would like to add 1440x900 256 & 1600x900 256, but as I have said I can't make sense of MakeModes.
If anyone could make up a MDF for my Samsung SyncMaster S24B150 monitor, I'll be forever grateful.
- Dave
acorndave
Post by acorndave » Tue May 19, 2020 1:06 pm
Ideally you would make a mode file and test / tweak it on the Monitor concerned. The below hopefully should be somewhere near. I had a lot of trouble making
1600 x 900 for some reason.
But anyway see how it looks
# Modefile written by !MakeModes version 0.26 (14th December 1994)
# Monitor definition file for Samsung C23A550U
file_format:1
DPMS_state:3
# 1440 x 900 (50Hz)
startmode
mode_name:1440 x 900
x_res:1440
y_res:900
pixel_rate:106000
h_timings:56,204,0,1440,176,264
v_timings:60,26,8,900,0,3
sync_pol:1
endmode
# 1600 x 1200 (51Hz)
startmode
mode_name:1600 x 1200
x_res:1600
y_res:1200
pixel_rate:101000
h_timings:10,10,16,1600,0,0
v_timings:10,0,0,1200,0,0
sync_pol:0
endmode
# 1600 x 900 (50Hz)
startmode
mode_name:1600 x 900
x_res:1604
y_res:905
pixel_rate:108000
h_timings:60,204,0,1604,18,264
v_timings:60,26,8,905,0,3
sync_pol:1
endmode
startmode
x_res:1920
y_res:1080
pixel_rate:148000
sync_pol:1
endmode
# End
Daveo
Post by Daveo » Tue May 19, 2020 2:14 pm
Many thanks. Will give this a try and post back results asap.
- Dave
Daveo
Post by Daveo » Wed May 20, 2020 4:24 am
Ok tested MDF and only the 1920x1080 displayed correctly on screen.
1440x900 & 1600x900 both appeared with black bars down sides and top & bottom of desktop off screen.
1609x1200 resulted in a scrambled display.
I'm guessing it's the timings but as I've said I have no experience with Makemodes or MDFs, so not sure how to self fix the issues.
Sorry for being unable to do this myself, I just can't make much sense of makemodes and the instructions didn't help much either (nothing against anyone, it's just part of my learning difficulties. Some things I can figure out and others I can't, no matter how hard I try).
- Dave
helpful
Post by helpful » Wed May 20, 2020 5:45 am
Some more for you to try!
# 1280 x 720 (50Hz)
startmode
mode_name:1280 x 720
x_res:1280
y_res:720
pixel_rate:74250
h_timings:40,220,0,1280,0,440
v_timings:6,20,0,720,0,5
sync_pol:3
endmode
# 1280 x 720 (60Hz)
startmode
x_res:1280
y_res:720
pixel_rate:74176
h_timings:40,220,0,1280,0,110
sync_pol:3
endmode
# 1280 x 800 (62Hz)
startmode
mode_name:1280 x 800 (16:10)
x_res:1280
y_res:800
pixel_rate:73000
h_timings:32,80,0,1280,0,48
v_timings:5,13,0,800,0,3
sync_pol:3
endmode
# 1440 x 900 (60Hz)
startmode
mode_name:1440 x 900 (16:10)
x_res:1440
y_res:900
pixel_rate:86500
h_timings:32,58,0,1440,0,48
v_timings:5,13,0,900,0,3
sync_pol:3
endmode
# 1600 x 900 (57Hz)
startmode
mode_name:1600 x 900 (16:9)
x_res:1600
y_res:900
pixel_rate:86500
h_timings:36,32,0,1600,0,2
v_timings:7,6,0,900,0,0
sync_pol:3
endmode
Daveo
Post by Daveo » Wed May 20, 2020 7:24 pm
Ok. Will give them a try and post back the results.
- Dave
Daveo
Post by Daveo » Fri May 22, 2020 12:40 am
1600x900: scrambled video
1440x900: jumpy/overlapping display
1280x720: blank then fade in to bright white display
- Dave
helpful
Post by helpful » Fri May 22, 2020 3:58 am
Wow, you have the world's fussiest monitor!
Can you plug it into some other machine and run an EDID reading tool, to see if that gives a clue as to what it expects?
Daveo
Post by Daveo » Fri May 22, 2020 2:37 pm
I have monitor connected via hdmi to a pc. How do I run an edid test?
- Dave
Daveo
Post by Daveo » Fri May 22, 2020 2:50 pm
By the way, I have managed to get the following modes working with different settings...
1920x1080 from original c23a550u MDF I found via Google search
1600x900 from hl274hpb MDF shared by acorndave
1024x768 from Pro 450 MDF already on Risc PC
Still need to find working settings for 1440x900
Here is my current updated MDF...
# Monitor - Samsung SyncMaster model S24B150 monitor
file_format:1
monitor_title:Samsung S24B150
DPMS_state:3
# 1024 x 768 (75Hz)
startmode
mode_name:1024 x 768
x_res:1024
y_res:768
pixel_rate:80310
h_timings:122,86,30,1024,76,0
v_timings:3,28,0,768,0,1
sync_pol:0
endmode
# 1600 x 900 (60Hz)
startmode
mode_name: 1600 x 900
x_res:1600
y_res:900
pixel_rate:118250
h_timings:168,256,0,1600,0,88
v_timings:5,26,0,900,0,3
sync_pol:3
endmode
startmode
x_res:1920
y_res:1080
pixel_rate:148000
sync_pol:1
endmode
# End
- Dave
acorndave
Post by acorndave » Fri May 22, 2020 6:28 pm
Ok looks like your getting close. If you want to get your monitor edid info. Download DumpEDID.
It doesn't say so, but I can confirm it works with Windows 10. It's command line based
This is what mine looks like
C:\dumpedid>dumpedid
DumpEDID v1.07
Copyright (c) 2006 - 2018 Nir Sofer
Web site: http://www.nirsoft.net
Active : Yes
Registry Key : DISPLAY\HSD0000\5&29c1d843&7&UID4865
Monitor Name : HL274HPB PLUS
Serial Number : 1234567890123
Manufacture Week : 8 / 2017
ManufacturerID : 25634 (0x6422)
ProductID : 0 (0x0000)
Serial Number (Numeric) : 0 (0x00000000)
EDID Version : 1.3
Display Gamma : 2.20
Vertical Frequency : 56 - 75 Hz
Horizontal Frequency : 31 - 80 KHz
Maximum Image Size : 60 X 34 cm (27.2 Inch)
Maximum Resolution : 1920 X 1080
Support Standby Mode : Yes
Support Suspend Mode : Yes
Support Low-Power Mode : Yes
Support Default GTF : No
Digital : No
Supported Display Modes :
720 X 400 70 Hz
640 X 480 60 Hz
640 X 480 67 Hz
640 X 480 72 Hz
640 X 480 75 Hz
800 X 600 56 Hz
800 X 600 60 Hz
800 X 600 72 Hz
800 X 600 75 Hz
832 X 624 75 Hz
1024 X 768 60 Hz
1024 X 768 70 Hz
1024 X 768 75 Hz
1152 X 864 75 Hz
1280 X 960 60 Hz
1440 X 900 60 Hz
1280 X 1024 60 Hz
1280 X 1024 75 Hz
1400 X 1050 60 Hz
1680 X 1050 60 Hz
1600 X 1200 60 Hz
1920 X 1080 60 Hz
acorndave
Post by acorndave » Fri May 22, 2020 7:01 pm
Had another bash at 1440x900 for you any good ?
# 1440 x 900 (60Hz)
startmode
x_res:1440
y_res:900
pixel_rate:110000
h_timings:168,256,0,1440,0,88
sync_pol:3
endmode
Daveo
Post by Daveo » Fri May 22, 2020 8:41 pm
OK, will test and post back asap.
Will also run DumpEDID on the PC that's connected to the Samsung monitor and post back it's output asap.
- Dave
Daveo
Post by Daveo » Fri May 22, 2020 11:15 pm
That 1440x900 worked! :D
Here's result from DumpEDID...
Active                   : Yes
Registry Key             : DISPLAY\SAM0983\5&e5bd0ab&0&UID4353
Monitor Name             : S24B150
Serial Number            : H4MF301245
Manufacture Week         : 10 / 2014
ManufacturerID           : 11596 (0x2D4C)
ProductID                : 2435 (0x0983)
Serial Number (Numeric)  : 808596788 (0x30323534)
EDID Version             : 1.3
Horizontal Frequency     : 30 - 81 KHz
Maximum Image Size       : 52 X 29 cm (23.4 Inch)
Support Standby Mode     : No
Support Suspend Mode     : No
Digital                  : Yes
     720 X  400  70 Hz
     640 X  480  60 Hz
     640 X  480  67 Hz
     640 X  480  72 Hz
     640 X  480  75 Hz
     800 X  600  56 Hz
     800 X  600  60 Hz
     800 X  600  72 Hz
     800 X  600  75 Hz
     832 X  624  75 Hz
    1024 X  768  60 Hz
    1024 X  768  70 Hz
    1024 X  768  75 Hz
    1280 X  720  60 Hz
    1152 X  864  75 Hz
    1280 X  800  60 Hz
    1440 X  900  60 Hz
    1280 X 1024  60 Hz
    1280 X 1024  75 Hz
    1600 X  900  60 Hz
    1680 X 1050  60 Hz
    1920 X 1080  60 Hz
- Dave
acorndave
Post by acorndave » Fri May 22, 2020 11:30 pm
Okay so am I right in thinking you now have a working for MDF for the following display resolutions ? :
1024x768
1440x900
1600x900
1920x1080
Is that it or are you after some others ?
Daveo
Post by Daveo » Fri May 22, 2020 11:53 pm
Those are the main ones.
Not sure what modes the games I have on the hard disc need. Games like Lemmings, Crystal Maze, etc. I think they may need 640x480 or 800x600 (but I am only guessing on this).
Thank you for what you've done to help get this monitor working correctly with RiscPC.
Wonder if it's worth softloading RiscOS 6.20. I have 4.39 (ROM) at the moment.
- Dave
