Open source A3020 RAM
alexgibson
Re: Open source A3020 RAM
Post by alexgibson » Fri Jan 10, 2020 10:18 pm
cmorley wrote:
Tue Jan 07, 2020 7:01 am
alexgibson wrote:
Tue Jan 07, 2020 12:21 am
I like the cut-out for easy prising!
:shock:
Oh that was straight up... :)
I could 3D print a super simple tool that slots into the square hole, expands and lets you pull the board vertically up - really clean, low wear way to remove the part.
cmorley
Post by cmorley » Sat Jan 11, 2020 3:54 pm
Sure take a look. They aren't fun to remove at the moment because of the friction of all the pins in the ZIP sockets.
You can get the exact dimension from the gerbers.... viewmate will export DXF from Gerbers for example. The hole is there to miss the links on the motherboard - you'll need to work around them. I don't know where they are exactly in relation to the hole. I guesses and made the hole "really big" for plenty of clearance!
For a permanent installation swapping the ZIP sockets for turned pin sockets would make it easier.
cmorley
Post by cmorley » Sun Jan 12, 2020 9:42 pm
I tried an overclock today on an A4000. I don't have a range of crystal oscillators so I hooked up an FPGA to use the PLL. I soldered a buffer onto a SOIC breakout board to get a 5V CMOS output and plugged that in X100. It isn't ideal but it will do for testing and I can adjust the clock speed easily from the laptop.
The computer boots and seems stable at an oscillator speed of 75MHz (25MHz CPU speed). At 76 I get some message on boot and a * prompt but the error message is just off the screen on my TV! 77 won't boot.
I've run a few rounds of the IanS RAM test with 0 errors @75MHz osc. I'm not sure it is entirely stable but that could be the signal integrity of my Heath Robinson oscillator module... I've got dangly wires from the FPGA to the buffer - not ideal.
So it seems this RAM is pretty good for overclocking even with the signal buffers. The FPM version of the chip has a faster page mode (20ns vs 30ns) than the EDO chip but I don't have any of those left to test. (I'd have to buy 117 of them!)
cmorley
Post by cmorley » Mon Jan 13, 2020 12:39 pm
I've done some more testing and looked at some of the RAM signals on the scope. It looks good.
The system isn't stable at 75MHz oscillator but I'm not sure the RAM is the limit... the RAM test at 75 works perfectly every time. It might be the limit of this ARM250 or it might be the quality of my generated clock - perhaps a crystal oscillator would be more stable.
Anyway it works fine at 72MHz and the machine seems stable at that. I think that is a 100% overclock on an A4000. The GUI is certainely snappier. I can't try any games because this monitor doesn't support the refresh rate on the VGA input. Perhaps at ABUG it can run some demos and suchlike.
So I think this is pretty much signed off now. I'll sort out a sales thread this week - I will make 1 batch to order and that is it probably.
Post by danielj » Mon Jan 13, 2020 1:31 pm
That's pretty much ARM3 performance minus the the cache. Speedy!
cmorley
Post by cmorley » Mon Jan 13, 2020 3:20 pm
72MHz - I wonder if you could just link the video oscillator over to the CPU clock input?! I looked on mouser and digikey and the DIP type oscillators are not easy to buy anymore.
cmorley
Post by cmorley » Mon Jan 13, 2020 5:47 pm
This thread is to wordy...
RAM in an A4000:
No oscillators so clock from an FPGA:
Bodge a buffer onto a SOIC breakout adapter:
Result!
IanS
Post by IanS » Mon Jan 13, 2020 6:44 pm
Would a solution based on the Si5351 be a possible?
https://www.silabs.com/documents/public ... 5351-B.pdf
Would need initial setup, but could setup a fall-back output, selectable with a link. Make it in-circuit programmable?
cmorley
Post by cmorley » Mon Jan 13, 2020 7:01 pm
I imagine so. Put it and a 25MHz crystal on a small 8 or 14 pin DIP footprint PCB & program with an AT-Tiny USB adapter or something? You'd need a 3v3 reg and a 5V buffer on the output for an archie...
That might be a handy widget Ian. Were you thinking of making one? I might tack some clock generators and crystals onto my next Mouser order and make one if not...
I just used the PLL in the FPGA & buffer because I have them to hand!
IanS
Post by IanS » Mon Jan 13, 2020 7:05 pm
It's not high on my priority list, so go for it. I always thought they would make a good solution for VIDC enhancers.
IanS
Post by IanS » Mon Jan 13, 2020 7:59 pm
Not sure this is possible. To re-program the outputs you have to disable all the outputs. And the power-up state is only One-time programmable. Still a potentially useful device, but not as good as it could be for this application.
Post by 1024MAK » Sun Jan 19, 2020 11:46 am
The following photos show a test fit of a test board in a A3020 and are provided so that Chris can see how the test board fits in practice. This test board may look different to the production boards.
Once fitted and pushed down, the test board is below the level of the metal screening, so there is no issue with the keyboard touching it.
The orientation should be correct (if it is not, let me know, taken using an Apple iPad mini) and ‘up’ is towards the back of the case.
Empty sockets
Test board in left hand sockets
Test board in right hand sockets
Fitting is a little tricky in the left hand sockets, as it is more difficult to see if the pins are correctly aligned. Removal is rather fun as well. But both are possible for this test board without having to remove the metal screen. Of course if you want the easy life, remove the metal screen :mrgreen:
cmorley
Post by cmorley » Sun Jan 19, 2020 12:40 pm
Thanks Mark!
There isn't a lot of room but there is enough it seems... the boards are much harder to install when all the pins are populated - and I left of as many as I could. So I'd say it is a shield off job for all but the most brave soles.
Next weekend at ABUG we'll try a fit & electrical test of a complete set in A3020(s). Since the A3020 & A4000 are so close electrically that should be a box ticking exercise. [-o<
Mark: The solder looks a bit dull around the electrolytic cap in you photo. Not sure if it is the camera angle but it looks like corrosion - have you replaced the caps, they could leaking?
Post by 1024MAK » Sun Jan 19, 2020 3:53 pm
I’ve not done much with this machine (apart from play games :mrgreen: ). I have not replaced any capacitors. The board is a bit dirty in places. It could do definitely do with a bit of TLC.
SimonSideburns
Post by SimonSideburns » Sun Jan 19, 2020 10:48 pm
I have my two A3020s out of the loft, and I've even cut the batteries out and neutralised with vinegar.
I'm hoping they still work and I'll be bringing them either way.
Post by 1024MAK » Sat Jan 25, 2020 8:41 pm
At the ABug meet-up today, Chris provided me with some RAM modules, which I then fitted to my A3020.
You definitely have to remove the metal screen, as very firm pressure is needed to push the modules into the sockets.
Here is a photo showing the two RAM modules in place:
The two RAM modules in place
It may not look any different from the outside...
And here is the result confirming that the OS can see the extra RAM:
Ahh, 4096K of RAM :-)
Thanks Chris :D
cmorley
Post by cmorley » Mon Jan 27, 2020 10:33 am
Thanks Mark. :D
Notes from testing with Mark:
  • Remove the shield so you can get good access & visibility on the pin alignment.
  • Installing in the ZIP sockets requires a scary amount of force - especially if the ZIP have never been populated.
  • Use foam and push down with thumbs on the pins to get vertical force into the pins and to minimise any twisting.
  • Don't try to push holding the edges of the module PCB.
Post by Kazzie » Mon Jan 27, 2020 11:34 am
[*]Installing in the ZIP sockets requires a scary amount of force - especially if the ZIP have never been populated.
Oh, that brings back memories of installing sixteen (actual) ZIP RAM chips into my A420/1: I was glad I bought a bulk batch of chips with a few spares, as I broke two while trying to fit them! :oops:
trixster
Post by trixster » Mon Jan 27, 2020 7:24 pm
When it comes to overclocking then, is it a matter of changing an oscillator on the motherboard?
cmorley
Post by cmorley » Mon Jan 27, 2020 7:54 pm
Not change but fit the missing one & the resistor to the motherboard. It is a 22 Ohm resistor not a 220R... 220 written on an 0805 means 22 * 10^0 not 220R. Vectorlight has an overclock page with some good photos on. You should leave the RAM on the motherboard alone - this upgrade is all 4MB.
The A4000 I've been testing with runs stably with a 72MHz oscillator so I am going to try linking the 72MHz VIDC clock across. I'll post if that works. Was going to try it at ABUG but home time came too soon :(
