FPA 10 diagnosis...
AndyMc1280
FPA 10 diagnosis...
Post by AndyMc1280 » Sun Oct 14, 2018 2:05 pm
Hi Guys
Trying to get an FPA 10 working, keeps saying "Not fitted" in benchmarks but figures are way up on standard machine (R260). Machine works fine otherwise and is standard 25 Mhz. I may need to clean the socket. Suggestions ?
SarahWalker
Re: FPA 10 diagnosis...
Post by SarahWalker » Sun Oct 14, 2018 2:19 pm
Probably a stupid question, but are you using the FPA-supporting version of FPEmulator (4.xx)? The standard RISC OS 3.1 version won't work properly.
AndyMc1280
Post by AndyMc1280 » Sun Oct 14, 2018 4:46 pm
Yes I've got 4.36 on a Pi and 4.35 on the 260 (going to update shortly)
Post by steve3000 » Sun Oct 14, 2018 6:32 pm
You're probably fine if you're using a recent version of FPE, but as long as the FPEmulator doesn't have an 'E' in its version number (*help fpemulator) then it should support hardware FPA. You will also need to turn on the FPA test in !Si, if that's what you're using, or it will not even look for it and will just report not present.
AndyMc1280
Post by AndyMc1280 » Mon Oct 15, 2018 12:52 pm
Yeah done that. Will check version (FPEmulator) and clean socket.
