Baildon Electronics IDE Interfaces - Replication
Re: Baildon Electronics IDE Interfaces - Replication
Post by RobC » Mon Mar 12, 2018 8:29 pm
daveejhitchins wrote:On their way, Rob . . .
Cheers - I'll let you know when they arrive.
aotta
Post by aotta » Fri Apr 27, 2018 3:35 pm
I am afraid the original project will never get progress... But i have just finished the porting to arduino of the apple ii smartport emulator, and i am quite sure it may be done for emulating a3000 ide podule too... I start studying! ;)
Post by daveejhitchins » Fri Apr 27, 2018 9:36 pm
aotta wrote:I am afraid the original project will never get progress...
Oh yes it will :D - Rob has already sorted out one of the PLDs - the second is registered - so just needs looking at in a different way. I'll get there in the end - just be patient 8) - it's not been 30 years yet!
aotta
Post by aotta » Fri Apr 27, 2018 9:44 pm
Really? if RobC is working in the project, i can believe it... i bought one of his Nula for my Master and it's a masterpiece!
anyway, the emulation on arduino seems a good alternative to me... i'll investigate about the possibility, starting from emulator that supports ICS IDE in software and that are available with source code in C language
VectorEyes
Post by VectorEyes » Tue Sep 04, 2018 9:43 am
Just wondering whether there's been any progress on Risc PC IDE interfaces recently? I just saw a Baildon Arcin v6c go for £70 on eBay!
Post by daveejhitchins » Tue Sep 04, 2018 10:52 pm
Discussions at Cambridge . . .
Trapper
Post by Trapper » Fri Sep 14, 2018 12:07 am
Whoops! That was me!
I've seen them go for well over £100 and they are only getting rarer - bit of an investment!
Post by daveejhitchins » Thu Oct 11, 2018 10:28 am
Update (at last) . . .
I've now been working on the recovery of the 2 PLDs, on and off, for the last week (Mrs H is away for 2 weeks in November :D :oops: ) and, apart from the lost file shenanigans I seem to be making progress.
Although RobC recovered the contents of IC1 (attached) I've decided to see if I can verify this using my own hardware and software. Then I can be more confident of any findings for IC3.
I eventually got the hardware working and saved the data in Address - Data format: 10 bit of address and 8 bit of data (ignoring bit 7). The data collection was carried using an Electron with MRB (Turbo and Shadow mode) and AP5 fitted. Using User-Port B and Clock Out from CB1 with Data being shifted out from CB2 into a serial to parallel shift register (2 x 74LS164). This gave me the 10 bits for the inputs of the PLD. The 7 bits of PLD output were read via the 6522 data input.
Next step (I could have done this in the same program, however, decided to break it down into manageable segments) was to load the data into 2 x arrays Address and Data. Next, (and this is where I am now) is to sort into PLD Output nodes e.g. run through the Data and search for address that have each node valid - all address that have bit 0 = 0 - addresses that have bit 1 = 0 etc. I'll also have to take the OE pin into account. I think the Clock-in can be ignored for IC1.
Then I can sort through the results and hopefully end up with what's needed.
@RobC: I've downloaded your pa.exe program. What format of data does it require?
More later.
IdeAIN V6C IC1.pld.zip
RobC's recovered IC1 PLD data.
(1.52 KiB) Downloaded 8 times
Post by RobC » Thu Oct 11, 2018 1:57 pm
Hi Dave,
The program isn't mine - it comes from here. It's from his post on reading secured PALs.
I built the adapter to read the PAL as an EPROM and then used the PA software to analyse the bin/rom file. The software takes the binary "EPROM" dump and generates a text file in CUPL format as output.
Sorry that I haven't had more time to progress this further but, unfortunately, I've been busy with lots of other things recently...
Post by daveejhitchins » Thu Oct 11, 2018 5:56 pm
Ah! Thanks Rob . . .
So the 'dump' would just be data from the output - no addresses . . . I believe you set-up the inputs and output within the program - but not run it yet, so guessing! I may give that a go
No problem - about time I actually did something . . .
Post by RobC » Thu Oct 11, 2018 6:05 pm
Yes - you just read the PAL as a 27C020 and then pass the "ROM" image to the PA software as a binary file.
In terms of describing inputs and outputs and giving signal names, I can't remember the syntax, but this is what the PA.exe instruction section says:
Analysis software
Running the executable (pa.exe) from the command line shows the following output:
usage: pa [-options]
Available options:
-force : Force processing of registered PAL dumps.
-alloe : Force OE equations to be listed for all pins.
-polarity : Use specified bitmask to force output polarity.
-oepolarity : Use specified bitmask to force output enable polarity.
-ignore : Use specified bitmask to ignore processing outputs.
-signal : Specify user-supplied pin names.
-verbose : Print informational messages.
Type `pa help <option>' for more information on that option.
Results are written to stdout.
For example assuming you have binary output called "paldata.bin" from your device programmer. You can analyze it by typing:
pa paldata.bin > paldata.txt
... and the CUPL output will be written to "paldata.txt". The output is intended for use with Atmel WinCUPL so you may have to edit the source to use it with other HDL software or minimization tools.
I ran some other software to simplify the equations but can't remember what I used. It might have been Logic Friday but I'm away from the machine I used at the moment...
Post by daveejhitchins » Wed Oct 17, 2018 3:16 pm
So that's what I've decided to do. However, instead of trying to read the part on my Programmer (seemingly, may not anyway!) I've put together a quick and dirty adapter that conforms to the requirements in the (RobC's) link above. Instead of using a programmer to do the reading, it connects to the user port. I have a program (needs a little tweak!) that will do the job. The PCB will accept a DIL or PLCC ZIF socket adapter.
The addresses (A0 > A17) are clocked out of CB2 by CB1 into the 3 x 74LS164 (serial to parallel shift registers). The data is then read from the GAL outputs into PB0 > PB7.
I'll order 10 of these. So if anyone would like one - just let me know.
If someone could carry out a sanity check, please.
GAL16V8 Adaptor 17-10-18 - Schematic.zip
(72.16 KiB) Downloaded 12 times
Post by IanS » Wed Oct 17, 2018 3:45 pm
I'll take one if there is one spare.
Seems to be a slightly odd order of address lines out of the shift registers, would be better if you re-ordered to make the shifting out of the value by your program easier.
Post by daveejhitchins » Wed Oct 17, 2018 7:04 pm
On the list Ian . . .
Yes, I know . . . Just copying what I already have working on the breadboard. It seemed to track OK too!
I'll do some work on the software and post it here.
Post by daveejhitchins » Sun Oct 21, 2018 4:53 pm
PCBs ordered for the PLD to 27C020 adaptor. I've also been working on the software to drive this. Currently you can select between BASIC with a display of address and data, BASIC without address and data and I'm now working on a m/c option - need it for speed! Option 1 takes over 5 hours :shock: option 2 under 2 hours - I'm hoping the m/c option will bring it down to under 30min . . . [-o<
PCB update: Getting there . . .
Post by IanS » Sun Oct 21, 2018 6:34 pm
What percentage of the time is re-ordering the address to shift it out in an odd order?
Post by daveejhitchins » Sun Oct 21, 2018 10:11 pm
Hmmm! I'm not sending it out in an odd order! Well, if I am, it's not deliberate! I split the address into high-byte mid-byte and low-byte then send to the shift register in low, mid and high byte order. I set-up the register to shift-out using the 1MHz clock.
I could probably speed-up the "BASIC without display" by not using procedures e.g. unrolling it all into the REPEAT/UNTIL loop. The m/c should be a lot faster! I may need to add some 'wait' to allow the shift register to clock-out before I send the next byte. But in the end I'm only doing two ICs! So even it it takes 24 hours . . .
Post by IanS » Sun Oct 21, 2018 11:12 pm
Not having done much with the 6522 in the past, I'd forgotten about the serial shift register mode. I was assuming you having to manuall toggle each bit out in basic.
It's an interesting PCB, but as you sound like you have a breadboard version up and running, won't you have got all the results you need before the PCB turns up?
I assume you are doing this on your trusty Electron, anything to be gained by doing it on a beeb, or an Arc? (user port podules did exist, I unfortunately don't have one)
Post by daveejhitchins » Mon Oct 22, 2018 5:39 pm
I've just had a message from DHL telling me the boards are on their way :D I only had the bread-board set-up with 2 x 74LS164 - so couldn't take a full read. I now have more 164s so should be able to run it straight away. I'll post the results, when done.
Certainly am using the Electron - with AP5 and BeebSCSI fitted and, of course, a MRB in Turbo and Shadow mode. My Master takes up too much room on my workbench!
Post by daveejhitchins » Tue Oct 30, 2018 6:12 pm
PCB layout complete - just need to add the silkscreen.
Edit: Sorry, really crappy images - I'll get replacements, tomorrow.
Last edited by daveejhitchins on Tue Oct 30, 2018 6:49 pm, edited 1 time in total.
Post by daveejhitchins » Wed Oct 31, 2018 4:53 pm
Final Update - PCB ready for prototypes :D
Attached PDFs of:
Schematic - updated!
PCB top tracking
PCB bottom tracking
3D of PCB top
3D of PCB bottom
3D of PCB angle 1
3D of PCB angle 2
Today I added PLCC sockets - seemed a good idea! Note the schematic update!
ARCIN V6C 31-10-18 - Schematic.PDF
(702.37 KiB) Downloaded 20 times
PCB Print Top.PDF
(532.39 KiB) Downloaded 18 times
PCB Print Bot.PDF
(473.84 KiB) Downloaded 11 times
PCB 3D Print Top.PDF
(1.21 MiB) Downloaded 8 times
PCB 3D Print Bot.PDF
(1.02 MiB) Downloaded 6 times
PCB 3D Print Ang1.PDF
(568.36 KiB) Downloaded 7 times
PCB 3D Print Ang2.PDF
(534.09 KiB) Downloaded 9 times
Post by IanS » Wed Oct 31, 2018 7:34 pm
I'm confused by the LED drive circuitry. Should R30 connect to GND rther than +5V. What is TR1 doing with "activity-1"?
Edit:
Shouldn't these pins be connected to something else?
T1 signal?
Post by daveejhitchins » Thu Nov 01, 2018 3:02 pm
Thanks for checking, Ian . . . Appreciated =D>
You're correct, on both counts! TR1 collector should be connected to TR2s collector and R30 should be to ground - Both now fixed - But not in time for the prototypes, however, that's what they're for, isn't it?
Edit:
That looks like a typo on the schematic - IC6 pin 17 is nT1 - so should pins 19 on IC4/5 - current schematic shows T1
I also noticed that pin A32 on PL1 wan't connected - should be to +5V. All corrected now.
Post by daveejhitchins » Fri Nov 02, 2018 7:57 am
First: Attached is an updated schematic with all the above changes added. Not too much to change on the prototypes. I'll be able to test with the LED circuit unpopulated, initially, and just one link for the T1/nT1 error.
ARCIN V6C Issue2 01-11-18 - Schematic.PDF.zip
(172.07 KiB) Downloaded 12 times
Next: Update on the PLD decoding. I now have PCBs (let me know if you like one. I'll have them at Leicester.). I've been testing the software and believe it's all working. So next is to decode a known PLD (I'll use the latest ABR).
These ZIF sockets are low cost (from eBay) so I haven't bothered socketing them!
Edit: The PLCC socket is of the "Dead-Bug" type e.g. the device is fitted in upside down!
Last edited by daveejhitchins on Fri Nov 02, 2018 8:00 am, edited 1 time in total.
Post by daveejhitchins » Fri Nov 02, 2018 8:58 pm
Today I've tested the adaptor with my software and everything seem to be OK. I've crunched the BASIC program and now the run takes just over the hour. Gives you time to do all sorts of things :D
I've run both of the PLDs (IC1 and IC6) through the system and attached the files. I won't have time to run them through the Windows software until Sunday - So if anyone want to have a go. . . . On Sunday I'll read the ABR PLD and check the results with that first.
PLDDATAIC1.zip
(7.04 KiB) Downloaded 7 times
PLDDATAIC6.zip
(1.98 KiB) Downloaded 7 times
Post by daveejhitchins » Sat Nov 03, 2018 9:07 am
Here's the BASIC program I'm using to 'scan' the PLDs. It still needs some work e.g. I need to add a m/c section for faster scanning - no rush for that, however!
PLD-Read.ssd.zip
(3.49 KiB) Downloaded 7 times
Edit: Forgot to add - although the code is in there to work with Electron and BBC - The machine detection code isn't in there, as yet. You my also see a double Read from the the User Port B - A single read doesn't read the correct data! Don't know why! - That's one question for Leicester :D
Last edited by daveejhitchins on Sat Nov 03, 2018 9:11 am, edited 1 time in total.
Post by daveejhitchins » Mon Nov 05, 2018 4:58 pm
PCBs have arrived . . .
Had ago with the "Reading Secured PLDs' and analysis 'software', yesterday. Hmmm! From the command prompt: pa does indeed respond as shown in the article, however, the pa help (any option) doesn't, saying 'Unknown Option'!
Another investigation at Leicester . . .
Post by IanS » Mon Nov 05, 2018 6:41 pm
Try it without the hyphen "-"
e.g.
Post by daveejhitchins » Thu Nov 22, 2018 4:06 pm
Just a quick update.
At the suggestion of IanS: Due to issues with IC6 - it compiles to a huge file and thinks everything is registered - which from the schematic is unlikely. So Ian suggested I read the PLD twice and compare to ensure the readings are valid.
IC1 seems to have an issue: The first 19 bytes are different, every time! I'm thinking this is a temperature issue. So the plan is to carry out two cold reads followed by two warm reads. Compile the results and see what appears to make sense.
IC6 - the first reads of this showed 100s of differences. After a a second clean, with IPA, the differences have reduced to 8 (progress!). Before the next run I'll clean the legs with fine emery paper and retry.
Slow progress, I know, however, I now have 2 partly built prototypes (built at Leicester). Once I'm confidant I actually have a working original Interface, I'll remove those PLDs and use in the prototypes to verify the PCBs.
More later - Dave H :D
Post by daveejhitchins » Fri Nov 23, 2018 11:51 am
Update:
I gave IC1 a 'warm-up' before reading, on this run.
IC1 - Still the same first 19 bytes different, but this time with one extra difference.
IC6 - Down to 1 difference now, after a good cleaning with 400 grade emery cloth.
ABR PLD test - 2 x Clean reads, no differences. This, at least says the read-set-up is more than likely working OK. I'll now run this through the decoding software and see if we can get a match with the original PLD.
I think I'll modify the program to take multiple reads of each address location and see if it's consistent - I'll then take the reads that are 2 out of 3 alike.
