Gotek on A3010 Issues
marcusjambler
Post by marcusjambler » Sun Apr 22, 2018 10:45 am
Hi All
I've fished out my A3010 with a view to installing a mini IDE podule... Which I will do once the IDC adapter arrives :D
In the mean time I'm swapping the Citizen FDD for a Gotek...
Which is not going as planned. It just flags up drive empty.
Gotek flashed with FlashFloppy and works on my Master.
FF.CFG has host = acorn
ADF files are 800k
S0 jumper set
The motherboard has these 2 mods :
Are these known mods? And are they affecting the Gotek install?
So many questions.... Help please!! [-o<
lcww1
Re: Gotek on A3010 Issues
Post by lcww1 » Sun Apr 22, 2018 12:18 pm
Ahhhh! The dread drive empty error with a Gotek :(
Have you got
index-suppression = no
in the FF.CFG file?
And have you got the interface type set to IBM PC rather than shugart (this is done via the jc jumper by default, to allow easy swapping of the drive between different machines, but can be specified in the FF.CFG).
Don’t know about those mods tho’ - have you checked them out against the schematics?
JonC
Post by JonC » Sun Apr 22, 2018 7:18 pm
IIRC the Goteks have a jumper to emulate the drive motor activation line. I beleive the Arcs flag a drive empty if this is not present...
Jon
Post by danielj » Sun Apr 22, 2018 10:58 pm
It's actually about the index pulse being received in a timely fashion. There was a fair bit of testing with the A3010 (and beeb 8271 DFS) before Keir managed to get rid of the drive empty issue. It does work fine on my a3010 and A5000.
marcusjambler
Post by marcusjambler » Mon Apr 23, 2018 8:50 pm
Success =D>
in the FF.CFG file?
I added the index-suppression = no and JC jumper and loaded ELITE.... :D
Thanks Fellas!!
lcww1
Post by lcww1 » Mon Apr 23, 2018 9:36 pm
marcusjambler wrote: and loaded ELITE.... :D
Right On, Commander! :D
marcusjambler
Post by marcusjambler » Tue Apr 24, 2018 7:26 am
Hahaha.... looking very smooth and colourful
