Hi!
Aktomairel2012
Hi!
Post by Aktomairel2012 » Sun Dec 21, 2008 12:44 pm
I am from Kiev, Ukraine.
I have still working BBC model B and Master-128
My favorite game is CastleQuest.
Kecske Bak
Re: Hi!
Post by Kecske Bak » Sun Dec 21, 2008 6:57 pm
Welcome to the list - I'm next door, in Hungary!
retroclinic
Re: Hi!
Post by retroclinic » Sun Dec 21, 2008 10:20 pm
Hi.
Welcome on board.
I AM Hungry...but I live in London... :)
Mark.
AndyF
Re: Hi!
Post by AndyF » Mon Dec 22, 2008 10:18 am
Welcome :)
Andy
Re: Hi!
Post by MartinB » Mon Dec 22, 2008 4:47 pm
Ласкаво просимо! :D
Martin
Aktomairel2012
Re: Hi!
Post by Aktomairel2012 » Thu Apr 16, 2009 2:24 pm
I am Acorn BBC user from Kiev, Ukraine
Aktomairel2012
Re: Hi!
Post by Aktomairel2012 » Tue May 04, 2010 8:23 pm
I wan recover files from Econet level 3 SASI hdd
then put on ide flesh card
how torurne recover data ?
also I havr many old 5" floppy with old games an my own programs
i wan recover them
I kno for PC and Amiga 500 was special floppy controller catwizle thet cat read many obsure disk formats direct conriling floppy drive heads an motors modes for read write all iven protected disks
for 8271 fdc was program cyclon copier for copy disk to disk sector by serctor
i had TMS the music system i was protected an can run on 1770 on b+ and master
also I have some original eproms and wany6 get burber for make copy of them
I have MLR rom for russian scrin priter and keyboard ( extept mode 7 :() i patch it for use Ukrainian symbols
in Latvia in Riga state technological university made latvian language patch for View word processor
iomanoid
Re: Hi!
Post by iomanoid » Tue May 04, 2010 10:55 pm
No offence, but this is the best thread on this forum, ever :D
Aktomairel2012
Re: Hi!
Post by Aktomairel2012 » Thu May 03, 2012 6:43 pm
I am interested if retroclinic USB can drive USB WiFi or ethernet adapter.
I know about Commodore C64 IP stack contiki which use trick of 6502 CPU that alove swithable multisking for 8 tasks swapping spu stack to external memory
retroclinic
Re: Hi!
Post by retroclinic » Thu May 03, 2012 7:00 pm
The DC board can talk to almost any USB device, but as with any USB device, you need a driver - modern ones are of course either built into the OS, or supplied on CD/online. If you wanted to use a WiFi or Ethernet adaptor on the beeb, you could, but you'd have to write the driver for it yourself.
Mark.
poink
Re: Hi!
Post by poink » Thu May 03, 2012 11:53 pm
retroclinic wrote:If you wanted to use a WiFi or Ethernet adaptor on the beeb, you could, but you'd have to write the driver for it yourself.
If you're specifically interested in getting Ethernet on your Master, then there's a module available for the Econet slot, but it's more expensive than the DataCentre: http://sprow.co.uk/bbc/projects.htm#Ethernet (AFAIK, it's one of those network stack on a chip things).
In terms of reading BBC floppies, then IIRC, there's no need for special floppy reading hardware. The BBC's formats are pretty normal in terms of how they're written to the disk but it can be difficult to find a PC that has a well implemented floppy controller!
If you've got access to a 5.25" drive on a PC somewhere, then, say Omniflop (Windows) will create a disk image, a DFS image tool will pull your files off. There a few tools that'll do certain conversions, or you could just use the images with an emulator.
EDIT: is that a Cyrillic keyboard on that BBC Master?
moijk
Re: Hi!
Post by moijk » Fri May 04, 2012 7:45 am
Was that a beeb controlled robot?
Owner of Acorn Archimedes a3020, BBC Micro B and countless other computers/consoles
Aktomairel2012
Re: Hi!
Post by Aktomairel2012 » Fri Jan 25, 2013 3:06 pm
Helo again from Kiev.
I search Russian spealing Acorn users.
I know in Latvia in Riga ste technologicall univercity was teaching class BBC econet
Re: Hi!
Post by daveejhitchins » Fri Jan 25, 2013 6:32 pm
Aktomairel: Hi and welcome . . . Good set of gear you have there, looks like you're in for loads of fun . . . :D =D>
Haqa
Re: Hi!
Post by Haqa » Fri Jan 25, 2013 6:50 pm
Hi Aktormariel,
If anyone can answer your BBC questions these guys can I think!
H.
If at first you don't succeed, blame the cat...
