New Atom Member
DavidWallis
New Atom Member
Post by DavidWallis » Thu Oct 18, 2018 12:55 pm
Hi all.
I dug my old acorn out from my Mum's loft and got it to boot! Also have a dead atom and a dead BBC master, which I hope to revive.
David
Re: New Atom Member
Post by Elminster » Thu Oct 18, 2018 1:36 pm
Welcome.
You have 2 more Atom's than I have. :)
Re: New Atom Member
Post by davidb » Thu Oct 18, 2018 1:50 pm
Welcome! :D
Re: New Atom Member
Post by oss003 » Thu Oct 18, 2018 2:25 pm
Welcome David,
You came to the right place.
Can you post some pictures from the inside of your Atoms and BBC?
Enjoy the forum......
Multiwizard
Re: New Atom Member
Post by Multiwizard » Thu Oct 18, 2018 4:30 pm
Hi David,
marcusjambler
Re: New Atom Member
Post by marcusjambler » Thu Oct 18, 2018 10:35 pm
Welcome to the forum....
Many Beeb/Electron/Atom owners on here.... :D
Marcus
DavidWallis
Re: New Atom Member
Post by DavidWallis » Fri Oct 19, 2018 8:26 am
This is my original Atom. Bought in December 1982 from a shop in Market Harborough, already assembled. It had the full 12k. I lent it to someone in the 80s and it came back with 3 keys missing, which was a shame. I would like an MMC card board for it, and a colour board. I would also really like to add a 5.25 disk to it, because although modern storage is great, I like the experience of using 5.25 inch disks
https://ibb.co/m6MERL
I bought this one as a non-worker off ebay, mostly for the keys, but I hope to get it working and use it as a test Atom for projects and keep my old one in good condition.
https://ibb.co/fjdHff
Re: New Atom Member
Post by hoglet » Fri Oct 19, 2018 8:35 am
Welcome.
That's only the second "issue 3" Atom I know of, so look after it!
The other one is owned by SirMorris I think.
sirmorris
Re: New Atom Member
Post by sirmorris » Fri Oct 19, 2018 9:38 am
Yup.
DavidWallis
Re: New Atom Member
Post by DavidWallis » Fri Oct 19, 2018 10:16 am
The issue 3 one I bought of ebay. Unfortunately it's rather scruffy and a non runner.
But the first one is one I've had since 82!
Re: New Atom Member
Post by hoglet » Fri Oct 19, 2018 10:25 am
Nothing that can't be fixed - most likely just a RAM fault. :D
DavidWallis
Re: New Atom Member
Post by DavidWallis » Fri Oct 19, 2018 10:38 am
Now I have one to swap with I can debug. Will try a minimal 2k setup first.
I know the graphics 2114s in my old version 4 are OK because mode 4 works fine.
Re: New Atom Member
Post by hoglet » Fri Oct 19, 2018 10:45 am
I'm sure you already know this, but on the Issue 3 Atom it looks like the regulators have been bypassed, so it needs to be fed from a 5V regulated supply (2A or more), not the original 8V one.
DavidWallis
Re: New Atom Member
Post by DavidWallis » Fri Oct 19, 2018 10:47 am
Has anyone tried to pull the PCB layout off a bare atom board? I would possibly be keen on having some PCBs made up. I would sell the surplus at cost if anyone else wanted one.
Is there a solution for the keyboard? Can you buy keys anywhere?
And can you buy the TV modulator?
I have a couple of 6847s (as well as the 2 in the Atoms) but I don't know if they work.
DavidWallis
Re: New Atom Member
Post by DavidWallis » Fri Oct 19, 2018 10:49 am
Thanks hoglet. Yes, I was powering it off a bench supply at 5V and measured 5V on the supply pins on one of the 2114s.
Re: New Atom Member
Post by hoglet » Fri Oct 19, 2018 11:02 am
Do check out the Atom 2015 thread:
viewtopic.php?t=9173&start=240#p109091
I re-purposed the key switches and caps from an old Beeb keyboard and I'm very happy with the result.
This is now my preferred Atom.
DavidWallis
Re: New Atom Member
Post by DavidWallis » Fri Oct 19, 2018 11:06 am
Awesome! Thanks.
Glad I'm back in to Atoms after 35 years. Some great projects out there.
sirmorris
Re: New Atom Member
Post by sirmorris » Fri Oct 19, 2018 11:14 am
I have a few spare keys - you might get lucky and not need to cannibalise the iss.3. Like Dave says - there's no Atom that can't be fixed.
DavidWallis
Re: New Atom Member
Post by DavidWallis » Fri Oct 19, 2018 11:23 am
Thanks sirmorris. Unfortunately I have missing keys on the iss3 too. But it would be nice to make the both complete. I will see what's missing when I get home this evening.
Re: New Atom Member
Post by tricky » Fri Oct 19, 2018 12:00 pm
welcome.
I have had an atom now for about Six months and apart from purchasing a PSU and the mmc and ram/ROM modules that you are after haven't dome much else.
I might take it along to the RISCOS (+8bit) show next weekend, space in the car allowing.
DavidWallis
Re: New Atom Member
Post by DavidWallis » Fri Oct 19, 2018 12:21 pm
So, I have 3 keys missing on my old iss 4, and one on the ebay iss 3. In total I need:
left/right,
copy,
1
2.
I don't suppose you have those ones sirmorris?
Also, (see other thread in 'Atom') I am still unable to send private messages. Sirmorris, do you have any MMC boards also?
Re: New Atom Member
Post by sydney » Fri Oct 19, 2018 1:29 pm
Sorry. Must remember to press confirm in future!
DavidWallis
Re: New Atom Member
Post by DavidWallis » Fri Oct 19, 2018 1:39 pm
Thanks. Now working :)
Re: New Atom Member
Post by roland » Fri Oct 19, 2018 10:24 pm
I think I still have one or two spares....
And please make that issue 3 Atom working again. The mainboard looks good so it will work again :)
bprosman
Re: New Atom Member
Post by bprosman » Sat Oct 20, 2018 12:13 am
I have some HiRes scans taken from an empty PCB.
DavidWallis
Re: New Atom Member
Post by DavidWallis » Mon Oct 22, 2018 4:45 pm
I will bear that in mind! Not promising anything, but perhaps a winter project.
DavidWallis
Re: New Atom Member
Post by DavidWallis » Mon Oct 22, 2018 4:49 pm
I thought the case for the iss. 3 that I bought off ebay was in a poor state, but I have cleaned it up and it'
s not too bad on the top. Damage on the bottom where someone has rested it on their soldering iron, and a badly fitted on/off switch in a cutout at the back. Other than that, not too bad.
Now to get it working!
https://ibb.co/ens5Qq
Re: New Atom Member
Post by flaxcottage » Mon Oct 22, 2018 7:38 pm
Welcome, David. :D
DavidWallis
Re: New Atom Member
Post by DavidWallis » Sun Nov 04, 2018 7:32 pm
I now have my ATOMMC installed. Can't believe I'm running lisp and FORTH on my old Atom. What I would have given to have that in 1982. But I didn't have enough pocket money. And I can save my programs without crossing my fingers every time I press 'record' on the tape recorder.
Now let's see what I can remember about 6502 programming.
janrinze
Re: New Atom Member
Post by janrinze » Thu Feb 21, 2019 9:34 pm
A late welcome from me too.
It's such a great system and i hope you have found replacement keys.
Looks very pretty.
