Copy BBC disk to PC using Smart SPI
Hi all
I'm new here, please be gentle with me!
I have a BBC Master and loads of my own BBC programs I wrote back in the 80s on 5.25" floppy disk - I would really like to get these onto my PC so I can run them with BeebEm.
I have bought a MicroSPI microSD card based board + Smart SPI ROM from RetroClinic which I have attached to the User Port and I can successfully run games from the BEEB.MMB file on it.
I have acquired MMBImager and DFSImager on the PC so once I get the MMB file back to my PC I believe I will be able to extract the SSD image from it. However, I'm completely stumped about how to copy games from the BBC's floppy drive to the Micro SPI SD card in the first place. The help guide for the SmartSPI software talks about DUTILS but none of them seem to explain how to copy a floppy disk to the "virtual" disks available on the SD card.
Is it possible? Can you help before my BBC Master / floppy disk drive gives up the ghost entirely?
Thanks in advance
Buzby
Thanks in advance
Buzby
Re: Copy BBC disk to PC using Smart SPI
I don’t have one of these devices but I would think you should create some blank disk images in the Beeb.mmb first. Mount your physical floppy disk in one drive and mount a blank disk from the smart spi in a different drive and use the standard commands of dfs\adfs to copy files from one drive to the other. E.g. commands *Backup or *copy.
Richard B
There is some software to do that iirc... Someone will no doubt show up shortly and say what it is.. The issue you're going to have is they're both sort of the same filing system. Have you tried asking Mark (Retroclinic) - he always provides very good support for his products?
- flaxcottage
- Contact:
This is the major weakness of the SPI system I discovered. The filing systems have overlapping workspace.
From experience one can manually copy files by issuing;
*DISC
LOAD "FILENAME"
Break
OLD
*CARD
SAVE "FILENAME"
or use *LOAD/*SAVE
The turboMMC version from IFEL has a copy ROM to do this job but it does not work with the SPI flavour.
*DISC
LOAD "FILENAME"
Break
OLD
*CARD
SAVE "FILENAME"
or use *LOAD/*SAVE
- DutchAcorn
- Contact:
You can also download the MMFS rom for the Master and run that from sideways ram. MMFS is an alternative file system for the same interface.
Use *MMFS to use, it will work instead of Smart SPI.
The tools disk (image) included with mmfs includes a tool called imtod that dumps the disk image to the physical disk.
See here: https://github.com/hoglet67/MMFS/releases
Please read the documentation carefully so that you download the correct version for a real Master 128 computer.
Edit: it is the U/MAMMFS version you need for the Master 128.
- flaxcottage
- Contact:
Now I didn't know that.
Thanks for the tip.
Thanks for the tip.
I can confirm I’ve used this method and it works well. imtod is a BASIC program (I think), and it’s particularly useful.DutchAcorn wrote: ↑Tue May 07, 2019 2:07 pmYou can also download the MMFS rom for the Master and run that from sideways ram. MMFS is an alternative file system for the same interface.
Maybe first *UNPLUG the SPI ROM and do Ctrl-Break, just to be sure SPI’s not active.
EDIT: Actually, isn’t it “dtoim” (disc to image) that Buzby needs, rather than “imtod” (image to disc)? Or does the one program transfer in both directions? I can’t quite remember.
- DutchAcorn
- Contact:
No, you are right, it's IDTOM, I misread Buzby's request. They are separate basic programs.lurkio wrote: ↑Tue May 07, 2019 6:54 pmI can confirm I’ve used this method and it works well. imtod is a BASIC program (I think), and it’s particularly useful.DutchAcorn wrote: ↑Tue May 07, 2019 2:07 pmYou can also download the MMFS rom for the Master and run that from sideways ram. MMFS is an alternative file system for the same interface.
Hi
Thanks for all the replies - I will take a look at MMFS when I get a chance and report back!
Buzby
Buzby
Evening all.
Finally got round to trying it out, and you lot are stars! A few head scratches at the beginning - turns out IMTOD doesn't format the disk it is writing to first and the copy of DUTILS included with MMFS didn't include the *DFORM command, but once I'd sorted that out it was all pretty plain sailing. I have just run a game I wrote on my BBC Micro in 1985 on my Windows 10 PC via BeebEm! Fantastic.
If only I could say the same about the 5.25" floppies - some of them just don't want to be read. Does anyone have any ideas about what to do about fixing disk faults?
Thanks again
Buzby
Thanks again
Buzby
