Matrix Brandy BASIC VI for Linux with SDL: V1.22.5 released
Richard Russell
Re: Matrix Brandy BASIC VI for Linux with SDL: V1.22.4 released
Post by Richard Russell » Tue Mar 24, 2020 10:17 am
This is possibly a silly question, but can the MODE 7 font be used in any other mode? My thinking is that because it's not tied to hardware, as it was in the BBC Micro, but is just another bitmapped font (albeit, at 16x20, a higher resolution than most) it ought to be possible to use it in any MODE with sufficient resolution, and not be restricted to teletext colour attributes and graphics.
Soruk
Post by Soruk » Tue Mar 24, 2020 3:00 pm
Currently, it's tied to MODE 7 due to the way the code is written. In all other modes, a character is assumed to be 8x8, and line spacing 8 (except MODEs 3, 6, 11, 14 and 17 where line spacing is 10).
Richard Russell
Post by Richard Russell » Wed Mar 25, 2020 9:12 am
OK, understood. In ARM BASIC running on RISC OS there must surely be a way of achieving higher-quality VDU 5 text in a graphics mode, for example if one was trying to write a GUI from scratch and wanted to label a button or something. Or am I wrong?
Soruk
Post by Soruk » Wed Mar 25, 2020 9:33 am
The FontManager modules can do this, it's completely separate from the BBC-style text plotting.
Richard Russell
Post by Richard Russell » Wed Mar 25, 2020 10:18 am
I see, I'm entirely unfamiliar with that. Is there anything comparable available when using Matrix Brandy on Windows (or Linux for that matter)? Could I use the SYS statement to access an API function that would do something similar?
When I wanted to support scalable (e.g. TTF) fonts in my BASICs I just went for an extension of the VDU 5 (print text at graphics cursor) mechanism as that seemed the simplest approach. I miss it in Brandy!
Soruk
Post by Soruk » Sun Apr 12, 2020 10:38 am
At this stage, probably not. Someone with more advanced programming skills than me (not difficult!) could possibly use the new dlopen interface to load SDL_ttf and talk to it that way. But it seems rather messy, in due course after I've had a chance to make friends with the RISC OS FontManager interface (RPCEmu FTW!) I would look to re-implement that interface in Matrix Brandy, insofar as it makes sense for programming in BASIC.
(For example, there is a SYS call that sends the zero terminated string immediately following it to the VDU interface. It makes sense in machine code but when called from BASIC, it sends a snippet of the BASIC ROM code! So, I've opted to not implement that call at all, whereas most of the other SYS calls that send bytes or strings to the VDU interface are implemented.)
Soruk
Post by Soruk » Fri Apr 24, 2020 10:28 am
I've implemented an analogue of OSWORD &0A for the teletext font, as OSWORD &79. It's one that, from what I can find, has never been assigned (and next to &7A which is Teletext related). It requires a block of 41 bytes, ?block%% is the character in question, and ?(block%%+1) to ?(block%%+40) is the character definition. Also, I've slightly redesigned the * character so it's more in keeping with the SAA5050 design. I never did like the RISC OS 5 teletext * shape.
Richard Russell
Post by Richard Russell » Fri Apr 24, 2020 12:41 pm
Am I right in assuming that only values up to 127 are meaningful?
Generally I used the Bedstead-extended font as a reference, which is based very closely on the SAA5050 ('quarter-dot' character rounding added, and then horizontally stretched by a 4/3 ratio I think).
Soruk
Post by Soruk » Fri Apr 24, 2020 12:47 pm
With my redesigned * character, yours and mine now look practically identical. As for valid characters, it's ANDed with &7F so &AA will give the same as &2A (*). However, unlike the display, the shuffle of characters when the high bit is set is NOT done.
Richard Russell
Post by Richard Russell » Fri Apr 24, 2020 2:08 pm
Of course on the BBC Micro (etc.) the 'shuffle' happens when the high bit is not set (setting it gives you the native SAA5050 characters unshuffled).
Soruk
Post by Soruk » Fri Apr 24, 2020 2:17 pm
Quite probably, I shuffle with the high bit because the character symbols are stored in the order they're displayed at 32-127 (127 only displayed with 255).
Richard Russell
Post by Richard Russell » Fri Apr 24, 2020 3:48 pm
That's what I guessed. It does mean that the character set you store doesn't correspond to any standard: it's not teletext/videotex (because you've shuffled £, # and _) and it's not ASCII/ANSI (because of having fractions, divide symbol etc.). It's only now that you've exposed it with the new OSWORD that it matters (previously it was internal implementation detail hidden from the user).
For the record my internal 16x20 character set is ANSI/CP1252 but that's because it can be used in MODEs other than 7. There are quite a few substitutions necessary in MODE 7 to get the expected characters (some of which are stored in unused locations within the 0x80-0x9F block). So for example if you wanted to redefine the upwards-pointing arrow character in MODE 7 (which you might expect to be 0x5E) the character you'd actually have to change is 0x8D!
Soruk
Post by Soruk » Sat Apr 25, 2020 11:43 am
OK - small change (and rebuilt the nightlies for today), the shuffle is now taken into account, so the character map returned is exactly what is shown for a given code in text mode. It doesn't return graphics but those are easy enough to calculate should a program need them. (Indeed, Brandy uses a function to generate them, it doesn't store them as bitmaps.)
bakoulis
Post by bakoulis » Sat Apr 25, 2020 4:47 pm
last build gives 1 warning on compilation.
$ make
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/evaluate.c -c -o src/evaluate.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/graphsdl.c -c -o src/graphsdl.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/assign.c -c -o src/assign.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/mainstate.c -c -o src/mainstate.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/tokens.c -c -o src/tokens.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/mos.c -c -o src/mos.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/commands.c -c -o src/commands.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/functions.c -c -o src/functions.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/iostate.c -c -o src/iostate.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/variables.c -c -o src/variables.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/fileio.c -c -o src/fileio.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/soundsdl.c -c -o src/soundsdl.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/keyboard.c -c -o src/keyboard.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/miscprocs.c -c -o src/miscprocs.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/editor.c -c -o src/editor.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/stack.c -c -o src/stack.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/mos_sys.c -c -o src/mos_sys.o
src/mos_sys.c: In function ‘mos_sys_ext’:
src/mos_sys.c:501:2: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result [-Wunused-result]
  fgets(outstring, 65534, file_handle);
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/strings.c -c -o src/strings.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/lvalue.c -c -o src/lvalue.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/errors.c -c -o src/errors.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/convert.c -c -o src/convert.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/brandy.c -c -o src/brandy.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/statement.c -c -o src/statement.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/net.c -c -o src/net.o
gcc -O3 -I/usr/include/SDL -DUSE_SDL -DDEFAULT_IGNORE -Wall   src/heap.c -c -o src/heap.o
gcc  -o brandy src/evaluate.o src/graphsdl.o src/assign.o src/mainstate.o src/tokens.o src/mos.o src/commands.o src/functions.o src/iostate.o src/variables.o src/fileio.o src/soundsdl.o src/keyboard.o src/miscprocs.o src/editor.o src/stack.o src/mos_sys.o src/strings.o src/lvalue.o src/errors.o src/convert.o src/brandy.o src/statement.o src/net.o src/heap.o -lX11 -lm -lSDL -ldl
Ubuntu 19.3 64bit
scruss
Post by scruss » Sat Apr 25, 2020 8:53 pm
That warning's been there for as long as I can remember. It is the only use of fgets in the whole system that doesn't assign or check fgets()' return value, though.
Soruk
Post by Soruk » Sat Apr 25, 2020 9:45 pm
I've checked in a change that will hopefully deal with this. None of my machines have that particular compiler version, so I have never seen that warning.
Richard Russell
Post by Richard Russell » Sat Apr 25, 2020 10:00 pm
None of my machines have that particular compiler, so I have never seen that warning.
What's your take on the use of -O3 for everything, as that script shows? I more commonly use -O2 or -Os (or -Oz with clang) since -O3 seems to cause bloat, I presume because of inlining, with negligible if any benefit in speed.
Post by jgharston » Sun Apr 26, 2020 12:54 am
I've implemented an analogue of OSWORD &0A for the teletext font, as OSWORD &79. It's one that, from what I can find, has never been assigned (and next to &7A which is Teletext related). It requires a block of 41 bytes...
If it needs a 41-byte control block then it must must must must must be OSWORD >&7F. OSWORD calls &15-&7F are defined to have a 16-byte control block, OSWORDs &80+ specify the control block length in the first two bytes of the control block.
Post by jgharston » Sun Apr 26, 2020 12:58 am
Calling for character=&23 should give the pattern for the hash symbol. Calling for character=&A3 should give the pattern for the pound symbol. Similarly for &5F/&DF underline/hash, &60/&E0 pound/underline.
Richard Russell
Post by Richard Russell » Sun Apr 26, 2020 10:23 am
Good catch! Not that Matrix Brandy is ever likely to be accessed via the Tube, but your point is well made.
The 16x20 character set isn't inherently limited to 128 characters (it happens to be currently in Matrix Brandy but it's a full 256 characters in BBCSDL) so I would be loathe to specify the new OSWORD in such a way that the upper half can never be accessed. For example in my case &5F is indeed the underscore but &DF is the Eszett (ß) and &E0 is lowercase a-grave (à).
If the new OSWORD provides a way to read the character patterns, should there not also be a way to redefine them (analogous with VDU 23)? Perhaps a pair of new OSWORDs could be defined: one to read and one to write?
Soruk
Post by Soruk » Sun Apr 26, 2020 10:40 am
And after my check-in yesterday, this is exactly what happens.
Soruk
Post by Soruk » Sun Apr 26, 2020 11:18 am
Moved to &8B (139). ?block% and ?(block%+1) are the size, minimum 43, if too small the call returns doing nothing. ?(block%+2) is the character, and the data is in ?(block%+3) to ?(block%+42).
Richard Russell
Post by Richard Russell » Sun Apr 26, 2020 11:20 am
As they follow consecutively from 'Read teletext pixel' and 'Set teletext pixel' how about &8B for 'read 16x20 character' and &8C for 'redefine 16x20 character'? Both would take a 43-byte block (send length, receive length, character code, 40 bytes of bitmap).
Soruk
Post by Soruk » Sun Apr 26, 2020 11:51 am
There's an idea (but unlikely I'll do that today), and I could extend OSBYTE 20 and 25 to reset the font to the defaults. As Matrix Brandy has a 16x20 font and a 12x20 SAA5050 font (drawn with square pixels, so it's a little narrow), this OSWORD only looks at the 16x20 version The 12x20 font is selectable and that is then returned via this OSWORD call.
Here's a silly demo of OSWORD &8B in use....
   10REM Use MODE 12 for a double-height effect
   20MODE 20
   30DIM b%% 41
   40OFF
   50COLOUR 1:PROCvtxstring("Red")
   60COLOUR 2:PROCvtxstring("Green")
   70COLOUR 3:PROCvtxstring("Yellow")
   80COLOUR 4:PROCvtxstring("Blue")
   90COLOUR 5:PROCvtxstring("Magenta")
  100COLOUR 6:PROCvtxstring("Cyan")
  110COLOUR 7:PROCvtxstring("White")
  120PRINT:PRINT:PRINT
  130ON
  140END
  150:
  160DEFPROCletter(c%)
  170?b%%=3
  180?(b%%+1)=43
  190?(b%%+2)=c%
  200SYS "OS_Word", 139, b%%
  210VDU23,224
  220FOR x%=1 TO 16 STEP 2: VDU?(b%%+x%+2): NEXT
  230VDU23,225
  240FOR x%=1 TO 16 STEP 2: VDU?(b%%+x%+3): NEXT
  250VDU23,226
  260FOR x%=17 TO 32 STEP 2: VDU?(b%%+x%+2): NEXT
  270VDU23,227
  280FOR x%=17 TO 32 STEP 2: VDU?(b%%+x%+3): NEXT
  290VDU23,228
  300FOR x%=33 TO 40 STEP 2: VDU?(b%%+x%+2): NEXT:VDU0,0,0,0
  310VDU23,229
  320FOR x%=33 TO 40 STEP 2: VDU?(b%%+x%+3): NEXT:VDU0,0,0,0
  330VDU224,225,10,8,8
  340VDU226,227,10,8,8
  350VDU228,229,11,11
  360ENDPROC
  370:
  380DEFPROCvtxstring(s$)
  390LOCAL c%, p%
  400FOR p%=1 TO LEN(s$)
  410c%=ASC(MID$(s$,p%,1))
  420PROCletter(c%)
  430NEXT
  440ENDPROC
Edit: OSWORD was mis-implemented. Fixed.
Richard Russell
Post by Richard Russell » Sun Apr 26, 2020 12:43 pm
As it's receiving data, shouldn't block%?0 = 3 and block%?1 = 43? If you set block%?0 = 43 and block%?1 = 0 the Tube will (uselessly) send 43 bytes and receive nothing!
Soruk
Post by Soruk » Sun Apr 26, 2020 12:54 pm
Yep, you're right, I completely misunderstood how this works (I've almost never touched OSWORD back in the day, and have never played with a machine with anything on the far end of the Tube. I am so making this up as I go along :lol: )
Code sample above adjusted to what it should be, and I've checked in the change to the code.
Richard Russell
Post by Richard Russell » Sun Apr 26, 2020 1:43 pm
I don't see this being an issue, since we're both using SDL (admittedly SDL1 for you and SDL2 for me), but can I just confirm that in BBC BASIC for SDL 2.0 the 40 bytes would need to be in the order expected for a conventional top-down bitmap/surface, i.e. the top-left 'pixel' of the character corresponds to the MSB (bit 7) of the first byte. I would hate for us both to implement the OSWORDs only to discover they were incompatible in respect of byte order!
Soruk
Post by Soruk » Sun Apr 26, 2020 2:33 pm
That's a very good point. Endianness hurts my head, but the BASIC code snippet above should show you how it works.
I've just rebuilt today's nightlies so the example above should work in them.
Here's my OSWORD definitions:
void osword139(int64 x) {
  char *block;
  int32 offset, i, ch;
  block=(char *)(basicvars.offbase+x);
  if ( ( block[0] < 3 ) || ( block[1] < 43 ) ) return;
  ch=block[2];
  if (ch==163) ch=96;
  if (ch==223) ch=35;
  if (ch==224) ch=95;
  ch = ch & 0x7F;
  offset = ch -32;
  if ((offset < 0) || (offset > 95)) return;
  for (i=0; i<= 19; i++) {
    block[(2*i)+3]=mode7font[offset][i] / 256;
    block[(2*i)+4]=mode7font[offset][i] % 256;
void osword140(int64 x) {
  char *block;
  if (block[0] < 43) return;
  ch=block[2];
  if (ch==163) ch=96;
  if (ch==223) ch=35;
  if (ch==224) ch=95;
  ch = ch & 0x7F;
  offset = ch -32;
    mode7font[offset][i] = block[(2*i)+4] + (256*block[(2*i)+3]);
My font definitions, starts at character &20, storage order is the display order for &20-&7F (last only shown for &FF):
static unsigned short mode7font[96][20];
Richard Russell
Post by Richard Russell » Sun Apr 26, 2020 3:40 pm
With minimum modifications to your code (considering I've not yet implemented the OSWORD call) I get this in BBCSDL, which seems promising:
Will it also work in Matrix Brandy if OSWORD is called in the standard BBC BASIC way (which is how I have to do it) rather than via your SYS extension? If so the degree of compatibility should be good:
A% = 139 : X% = b%% MOD 256 : Y% = b%% DIV 256 : CALL &FFF1
Soruk
Post by Soruk » Sun Apr 26, 2020 4:01 pm
Your example isn't 32-bit safe, let alone 64-bit. My "extension" using SYS "OS_Word" (or SYS 7) is actually the RISC OS way of doing it, which in RISC OS is 32-bit safe, and extended in Matrix Brandy to be 64-bit safe. Setting X%=b%% is at least 32-bit safe. (I've understood in BASIC you can set X% to point to the block and it'll work, whether or not Y% is set to block DIV 256)
Return to “classic languages (e.g. BASIC) on non-acorn platforms”
