how to connect and use this fan timer
duikkie
Post by duikkie » Sat Dec 28, 2019 2:41 pm
see the picture
someone no me [-X disconnected the timer
how to connect we have two red wires soldered on a metal plate ?
a isolation layer with thermal protector 70 C white wire
how to connect on L(live) , N and T
gidandridge
Re: how to connect and use this fan timer
Post by gidandridge » Sat Dec 28, 2019 3:01 pm
Humm,
So I'm not sure on the device in the pictures. Looks like it may be a thermal device of some time? A thermal cut-out or thermostat of some sort? Really not sure. Guess that's step '4' in the diagram. :?
However the wiring diagram seems fairly straight forward. It seems to show AC power going to the fan but diverted via the switched output of a separate timer.
So on the terminal block it seems like 'N' should be connected direct to the Neutral of the AC input. Then the 'L' from the Live AC goes to the supply of the switched output of an external timer. Then the output from that goes to 'T'.
So on the wiring diagram I guess the switch marked 'A' would probably be controlled by a relay in the external timer.
That's how it looks to me. Unless anyone else has another take on it?
EDIT: Okay now I'm starting to think that the photos are of the timer. So perhaps power is applied (from the light?) to the two red leads and then the middle component is thermally activated and act's as a switch? The switch called 'A'? #-o I think we need someone who has has put in one of these before? Sorry! :(
Gav. :D
BBC Model B Sidewise ROM Board, GoSDC, Datacentre, Hybrid Music 5000
Acorn Electron Plus 1, AP6, GoSDC, Slogger Pegasus 400
Post by 1024MAK » Sat Dec 28, 2019 3:20 pm
The following assumes that the fan timer continues to operate the fan for a number of minutes after the user has turned it off with the switch. In other words, a ‘run on’ timer.
The black box does look like a PTC or similar heating element. The white rectangle marked 70 (with the white wires) looks like a thermal switch.
So I making an educated guess that the red wires to the heating element should be connected to the fan thermal block, on the L and N terminals. Then the incoming mains supply ‘L’ wire connects to an external control switch, the other terminal of this switch then connects to the ‘L’ terminal in the fan. The white wires to the black box timer are then wired across the external switch. The incoming mains ‘N’ wire connects to the ‘N’ terminal in the fan.
Usual disclaimer: I’m making a number of assumptions here, if it goes bang and leaves soot skid marks everywhere, at least post photos so everyone can have a laugh :mrgreen:
duikkie
Post by duikkie » Sat Dec 28, 2019 5:46 pm
the wires in picture 7 are maybe wrong. this is blue wires on N and L if you do connect it this way the fan will never stop :shock:
the OP62uchiya is a thermal protector which is very high if temp is to high ?
so one white wire must be on L the other CAN NOT ON N short circuit if normal temp so it must be on T
then the to metal plates i think this is a condensator ? or something like that ??
so i think one red wire on N and the other on T
if your wc light is on this plates will load with T as LIVE
so where to put the bleu wires of the fan one on N and the other on T
if wc light is on fan will turn with N and T=(live)
is light is off no L(=t) from main power broken by A
because the red wires are loaded with power ??? the fan will turn by unloading N and T
what do other people think about that ??? :?:
duikkie
Post by duikkie » Sat Dec 28, 2019 6:08 pm
Post by 1024MAK » Sat Dec 28, 2019 6:13 pm
I’ve never seen a condensator / capacitor like that before...
duikkie
Post by duikkie » Sat Dec 28, 2019 6:34 pm
maybe it is something else :)
but a capacitor is something that load between metal en an isolator
but the blue fan wires must be on T and N and not as picture 7
i can't find a schematic how to connect a thermal protector but i think
it is always in the live line ?
gidandridge
Post by gidandridge » Sun Dec 29, 2019 9:22 am
So turns out that it is indeed a thermally operated switch ...
http://www.uchiya.co.jp/OtherContet/Sei ... hHTML.html
Normally open, the contacts close when it gets hot. The two metal plates must heat it up.
I think the two red leads would be connected to the power across your light. That way when you enter the room and turn on the light the plates get hot and the thermostat closes. The two white leads then go across L and T. This would mean the power would now flow from L to the fan motor.
When you leave the room you switch the light off and the plates now start to cool down. This takes a while (a couple of minutes) and so that fan continues to run. Once the plates are cold enough the thermostat cools and it opens again, cutting power to the fan.
However, like Mark said,if it just goes bang please post the photos. :D
Gav. :D
duikkie
Post by duikkie » Sun Dec 29, 2019 8:10 pm
the op62uchiya can no be connected to L and T
because if the light is switch off (broken by a) and the heat is above 70 C
the light will go ON :(
so i think the white wires must be on T and on a blue wire of the fan ( not connected to T,N or L)
other to N
now how to connect the red wires for warming above 70 C ?
NOT L and N (for ever warm) i think T and N (warm if light is on)
gidandridge
Post by gidandridge » Mon Dec 30, 2019 11:40 am
I don't think it would, the fan would come on yes - but not the light. I Don't think 'a' is the light switch - but I can't see the legend. :) I had read 'a' to represent the thermostatic switch.
I think the light switch could be connected across the two red wires. So when it's on it applies heat to the thermostatic switch. You then use the thermostatic switch to turn on the fan. I think it then means that when the light switch is off you've cut power to the red wires. So it slowly cools down and that takes time. So the fan runs until it cools below 70c.
Of course this is a 'theory' only - I can't see everything that you can. So I would suggest you start with the assumption that I'm wrong!
Plug and pray! [-o<
Gav. :D
gidandridge
Post by gidandridge » Mon Dec 30, 2019 12:08 pm
Something like this perhaps?
Exploding components may come free with this wiring arrangement. I'm making some assumptions to get this far. Things may go bang! :shock: Here ends my disclaimer. :wink:
Gav. :D
duikkie
Post by duikkie » Mon Dec 30, 2019 2:26 pm
NOT working YET #-o
but we are a little bit further
the OP62 is working with a paintstripper(heater)
see picture like above
i still can't see how the two conductive metal plates are warming up ???
i think something is still missing
i don't see how a live power line ( single) will warm the plate ??
the same for the N if on red wire ?
close circuit will give heat ( and bang)
i am thinking about a capitator , somehow over red=live to N ( in or out fase) a little time close circuit ?
red wire on T and other on N do not give heat ( and i can not see why between N and L it will give heat )
red on T and L ( likes stupid two live wires in fase) ??
NO BANG YET [-o<
duikkie
Post by duikkie » Mon Dec 30, 2019 2:28 pm
schematic like below is working , IF the red wire and plates are warming up what is NOT the case
duikkie
Post by duikkie » Mon Dec 30, 2019 2:37 pm
a resistor over N and T will give heat , but how to make that is not to warm and not to cold
that is the big Question
gidandridge
Post by gidandridge » Mon Dec 30, 2019 3:17 pm
Well, to be honest, me neither! :? I'm kind of assuming that they offer some sort of resistance. When you fit it all back together have you tried to measure the resistance with a multi-meter?
Agreed - you could well be missing some components that would be the magic part of the puzzle!
But would be fun to watch! :shock: :lol:
Not sure on that. However I see in one of the photos it looks like all the red/white wires are go to something - but I can't see what. Is there some insulation tape binding them together, or a plug, or small bit of circuit? Can't really see. Just wondering if something is indeed missing from there. :(
Gav. :D
gidandridge
Post by gidandridge » Mon Dec 30, 2019 3:20 pm
:D - Cheers Mark, Seems very likely that it's something like this.
Duikkie - time to connect and pray? [-o<
Gav. :D
Post by 1024MAK » Mon Dec 30, 2019 3:32 pm
gidandridge
Post by gidandridge » Mon Dec 30, 2019 3:35 pm
:D - I think you could be right.
It would all make sense if that was the case.
Gav. :D
Post by 1024MAK » Mon Dec 30, 2019 3:40 pm
In the U.K. fans with a “run on delay” are sold as one unit. As far as I know, most use a small electronic module / circuit board to time the delay time before switch off.
Here is a web page describing the typical wiring http://wiki.diyfaq.org.uk/index.php/Ext ... th_a_timer
The three pole isolation switch is provided so that the fan can be changed, serviced, maintained or cleaned without turning off the lighting circuit. The three pole isolation switch is normally fitted next to the fan.
An alternative is to feed the light and the fan circuit via a two pole isolation switch that is outside the bathroom/shower room.
duikkie
Post by duikkie » Mon Dec 30, 2019 4:35 pm
i did connect the two red wires ONE at T and one at N . leave the light on for a time
but no fan was turning. the black box was not warm :(
but i will look at ptc and the between plate :)
maybe bad connection ?
and how to measure ptc.
what i have seen looks like plastic plate maybe someone lose the ptc plate by opening the box
and replace it with plastic ?
duikkie
Post by duikkie » Mon Dec 30, 2019 6:56 pm
measure the plastic plate give zero ohm
measure the two red wires gives > 10 M ohm
zo bad connection , if you open chinees things you never
get it back :)
also the op62 (1 mm more) than the PTC plate
so pushing on the black box gives 0 ohm on red wire :)
tomorrow i will test with 240 volt
gidandridge
Post by gidandridge » Mon Dec 30, 2019 9:05 pm
Sounds promising. Good luck! [-o<
Gav. :D
duikkie
Post by duikkie » Tue Dec 31, 2019 3:17 pm
NO fireworks or total black out :( :( :( :(
SUCCES
so it was a plate of PTC
the only thing is it has a delay . (yeah)
to start the fan it takes 1 min and 15 sec
after turning off it spins for 1 min 30 sec
i think the startup delay is because i think maybe therminal pasta was used ?
that will allso help if the light is out longer spin.
so the black box contains:
one PTC plate and one OP62
one wire on T , OP62 on L and fan, one wire on N
gidandridge
Post by gidandridge » Tue Dec 31, 2019 4:15 pm
Awesome!! Sounds like that's all good then! :D Well done. 8)
I think the start up delay is a good thing. You don't want it to come on for short trips to the bathroom. If someone just pops in the night for quick use. I think it is better for it to come on only after the bathroom has been in use for a bit. :wink:
Glad you got it to work! :D
Gav. :D
Post by 1024MAK » Tue Dec 31, 2019 5:12 pm
👍 :D =D>
Return to “off-topic”
