Odd Peripheral Goings-On With RPi4
Re: Odd Peripheral Goings-On With RPi4
Post by BeebMaster » Fri Feb 28, 2020 8:52 pm
Seems OK at 1900MHz so far. I opened 36 then 55 PDFs, no problem.
Interestingly, when I had it at 2100MHz, the CPU monitor always showed 2.29GHz as the highest available frequency. Now at 1900 it correctly shows 1.9GHz.
dp11
Post by dp11 » Fri Feb 28, 2020 11:11 pm
From what I understand not all frequencies are possible.
scruss
Post by scruss » Sat Feb 29, 2020 3:39 am
The Foundation really doesn't recommend overclocking Raspberry Pi 4s at all. If it's unstable, it's something you did, is their line.
Firefox ESR is nice on the Raspberry Pi 4.
Post by BeebMaster » Sat Feb 29, 2020 10:26 am
Probably pushed it too far then if it went up to 2.29GHz. From what I remember when I was experimenting, it was a little bit sluggish at the original speed and overclocking helped. So far I've not noticed any performance degrade from running it at 1.9GHz.
Return to “off-topic”
