Odd Peripheral Goings-On With RPi4
Re: Odd Peripheral Goings-On With RPi4
Post by BeebMaster »
I fitted the "fan shim" the other day, which I'd ordered before I ruled out a heat problem. It's now keeping Pipi at a nice consistent 40 centigrade.
The fan assembly also has a little button on it, and I was thinking this would solve my latest problem - "how do I fit a button across 2 GPIO pins to invoke my keybind/shutdown thing?" Currently I am just touching the pins with a jumper header, but I think actually it is causing multiple keypresses when I do that 'cos I'm not quick enough!
After fitting I pressed the button and was surprised to find that the Pi shut itself down! After some investigation it appears that the fan's extra button is already mapped to GPIO 3, so it was doing my shutdown function without me having to change anything. I don't remember reading in the instructions that the button uses GPIO 3, but I am sure it must be documented somewhere.
Anyhow I still have the same problem: HDMI cable plugged into the RPi4 and going to my converter box - button and keyboard/trackerball work.
Cable out - button and keyboard/trackerball cease to function.
Earlier it was suggested a firmware update might help - how do I go about checking and updating the Pi's firmware?
Post by Elminster »
BeebMaster wrote:
Wed Sep 25, 2019 10:37 am
dp11 suggested
new beta firmware for the VLI USB chip.
Not looked at how to do that.
I have now permanently setup my pi4 to replace mediacentre macmini. The files are on a QNAP Nas, Pi4 is the plex server, amazon fire tv 4k is the plex player. So far nothing has hung. But I have the other way around. Key/board mouse is not plugged in, but I left the hdmi plugged into Yamaha home cinema amp so that I can get to desktop/console if I need to without faffing about with wires.
I found because I have a sealed case the shim fan still does not keep it cool, I was going to drill holes but then saw the best cooling soluion for the Pi4 is the FLIRC Case. So I have one of them on order.
If I see any issues I will let you know but I think my setup does not recreate your issue.
Edit: https://github.com/raspberrypi/firmware
Doing a quick google the USB beta firmware was out in Jun, so it maybe in core by now.
Thanks to BigEd, it's now been fixed.
The problem seemed to be that without a display attached, the X server wasn't starting, which I understand also runs the keyboard & mouse, and therefore my keybinds mapped to GPIO pins as well. All it needed was hdmi_force_hotplug=1 uncommenting from config.txt and it's now fine, monitor or no monitor.
Post by Elminster »
Odd as I ran the rpi4 for days (back on post from 13th September) with the hdmi cable unplugged and gui enabled. But never hit issue. not sure the difference,?
Post by BigEd »
It's not clear from your post if you booted without HDMI cable at any point - that, I think, is the thing. Removing HDMI after booting won't, I think, cause any bother.
Post by Coeus »
BeebMaster wrote:
Mon Nov 25, 2019 4:53 pm
Does that also rely on someone being logged on? Does it auto logon?
I can't help the better solution would be to have a daemon that reads the GPIO directly rather than relying on X. Does it appear as an input/event device, i.e. one of /dev/input/event0... up to some number determines by how many input devices there are. There is a program called evtest that can be used to find which events appear on which device and for other things such as working which codes an odd-ball keyboard generate.
Post by Elminster »
BigEd wrote:
Mon Nov 25, 2019 9:24 pm
It ran with nothing but power plugged in for days, and I could always get to it to ssh via WiFi. I was heat soak testing it.
It was tested with no hdmi cable, cable plug into port one, cable plug into port 2. It was also test with/without keyboard& mouse, and test with and without power hub. I could never recreate the issue.
It was always boot from fresh. Was with latest version and updates at the time.
So was the log showing messages from the Xserver failing.
I can easily test again. It will take a moment to yank the hdmi cable, and power it off/on again. It is now using Ethernet rather than WiFi.
Edit: of course it’s feasible the application sets up a pseudo display, not unheard of for headless applications.
Post by BigEd »
Ah, I think we may be talking about different things. Maybe you're investigating the idea of the Pi4 not working well if there's no HDMI cable connected at boot. But I think that's not what Beebmaster's problem was. It was very specifically some facilities he's using which seem to be reliant on the X startup (and indeed, I think I may be right in saying, an automatically started GUI session, so not just X but also a window manager and so on.)
To be honest I am not entirely sure.
But the behaviour I was always getting, with standard Raspbian install, was no HDMI at boot = no display (obviously) but also no mouse & keyboard, and therefore seemingly, also no keybinds to the GPIO pins.
Plugging in a monitor whilst running did not restore any of these missing functions.
We worked out that the X server wasn't starting if it didn't detect anything on the HDMI output, and with the config.txt mod it now works fine.
I am currently running it with no monitor, keyboard or mouse and I can press the button mapped to GPIO keybind that I use to run my shutdown script.
Next to look at is if I can use a GPIO pin to revive from its shutdown-but-still-powered-on state without having to power it off and on again.
Post by Elminster »
Does sound something specific then. Although not obvious why that would be different between a pi3 and a pi4.
scruss
Post by scruss »
BeebMaster wrote:
Tue Nov 26, 2019 10:38 am
This might help: GLOBAL_EN must be shorted to ground to boot. It's a momentary contact that should restart the processor.
I've got another funny going-on, although not peripheral related.
Loading some PDFs makes the Pi 4 suddenly restart!
At first I thought it was a bug in the standard Raspbian install PDF viewer (qdf), so I deleted it and replaced it with Okular. Still it occasionally resets when I load a PDF. More often it resets when I select several PDFs to load. I haven't established a reliable pattern to when or why it does it.
Next I thought it might be a spurious control code in one of the documents, which was calling my Shift-BREAK restart keybind, so I added a logging file facility to that script to see if it was being called just before the reset happens - but no.
I don't really know how to investigate this further, dmesg is no help as its output starts again on every boot. Anyone else heard of this behaviour or know of a log I can consult which survives a restart?
Post by BigEd »
I'm tempted to suspect the power supply, and the Pi's response to low voltage - it knows about low voltage, and it cares, but it's not clear how well-calibrated it is. It may be perceiving a brownout and rebooting on purpose.
With the latest firmware and the latest OS, you can (and should) update the secondary firmware, to improve the power usage of the Pi 4. See for example here and here.
sudo apt update
sudo apt full-upgrade
sudo apt install rpi-eeprom
Running the rpi-eeprom-update command with no parameters indicates whether an update is required
Reading the EEPROM version
vcgencmd bootloader_version
Interesting...I do have lots of USB devices connected. How do I check how much power is being drawn?
Looks like I'm pretty up to date:
pi@raspberrypi:~ $ sudo apt update
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Fetched 15.0 kB in 1s (23.3 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
pi@raspberrypi:~ $ sudo apt full-upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@raspberrypi:~ $ sudo apt install rpi-eeprom
rpi-eeprom is already the newest version (4.0-1).
pi@raspberrypi:~ $ rpi-eeprom-update
BCM2711 detected
BOOTLOADER: up-to-date
CURRENT: Tue 10 Sep 10:41:50 UTC 2019 (1568112110)
 LATEST: Tue 10 Sep 10:41:50 UTC 2019 (1568112110)
VL805: version unknown. Try sudo rpi-eeprom-update
CURRENT:
 LATEST: 000137ad
pi@raspberrypi:~ $ sudo rpi-eeprom-update
BCM2711 detected
VL805: update required
CURRENT: 000137ab
 LATEST: 000137ad
pi@raspberrypi:~ $ vcgencmd bootloader_version
Sep 10 2019 10:41:50
version f626c772b15ba1b7e0532a8d50a761b3ccbdf3bb (release)
timestamp 1568112110
pi@raspberrypi:~ $
Not sure how I update VL805. I think that's the USB controller, so it may be the culprit to all this (though I don't know why it might only manifest itself when loading PDFs).
Looks like I have to do
rpi-eeprom-update -u <new file>
to update the USB firmware, but I haven't found the file yet!
I think it's here:
https://github.com/raspberrypi/rpi-eepr ... 0137ad.bin
If I go offline for a month, it didn't work.
Yay:
BCM2711 detected
*** UPDATE REQUIRED ***
BOOTLOADER: update required
 LATEST: Fri 17 Jan 17:37:11 UTC 2020 (1579282631)
VL805: up-to-date
CURRENT: 000137ad
 LATEST: 000137ad
pi@raspberrypi:~ $
Unyay:
sudo rpi-eeprom-update -a
BCM2711 detected
FREEZE_VERSION=1
EEPROM version is frozen. Skipping update
dp11
Post by dp11 »
have you rebooted ? I think you might have to reboot for it to take effect.
Post by BigEd »
(I notice this one-line advice on the RPi forums:
Install the rpi-eeprom-images package.
Yes, rebooted. Also rpi-eeprom-images is up-to-date.
I had this "frozen" problem before on a previous attempt to update all the firmware, and went through the rigmarole of extracting and editing the firmware update configuration options. I checked before doing anything today and it was "unfrozen" - so it looks like my manual update of the USB firmware has frozen it again. I'm a bit wary of unfreezing it again in case it does any harm, it must have applied that setting for a reason.
Ahh...got it...another thing I did when trying to get it to auto-update VL805 was change /etc/default/rpi-eeprom-update to make the status "beta" instead of "critical". I've put it back to critical now, and it isn't finding that January 2020 update any longer:
BCM2711 detected
VL805: up-to-date
CURRENT: 000137ad
 LATEST: 000137ad
pi@raspberrypi:~ $
Wow, no longer limited to PDFs, it just reset itself when trying to load this page:
https://www.flickr.com/photos/simoninns ... 334359291/
But hasn't done it when I loaded it again after restarting.
Something seriously wrong here!
Have I got it overclocked too much?
Post by BigEd »
Sounds like you have!
Is a reset triggered by excess overclocking going to be logged somewhere? Or detectable in a definitive way?
dp11
Post by dp11 »
What are your overclock settings ? you may need to up the overvoltage setting.
I've got this in my config.txt:
over_voltage=7
arm_freq=2100
Apart from these occasional (but now seemingly more frequent) sudden resets, it's worked very well with those settings for some time now.
As an experiment, I am trying having my USB3 hub externally powered all the time. Usually I only power it when I connect my portable USB backup drives, which won't spin up without the hub being externally powered. I'm going to run it like that for a few days and see if there are any sudden resets.
None so far!
Post by hoglet »
BeebMaster wrote:
Fri Feb 28, 2020 6:12 pm
arm_freq=2100
:shock:
I just opened 29 Seagate hard drive manual PDFs at once, and it reset itself, so I can rule out powering the USB hub as a solution.
Time to start reducing the overclocking I suppose.
Post by BigEd »
Yes... if you have an unstable machine, and you're overclocking, the first thing is surely to go back to nominal speeds. Then you find out if the machine itself is unstable or if the overclocking is too extreme.
Return to “off-topic”
